Old 10-17-2019, 08:07 AM   #1
ScottP's Avatar
2019 27' Globetrotter
2019 Interstate Lounge Ext
Bend , Oregon
Honda Generator - for ASI
Can we power our ASI power using our 2200i Honda Generator?
2019 AS 27' Globetrotter front bed Queen T/V 2019 GMC 3500 Duramax
2019 AS Interstate (4x4)
Bend, Oregon & Rye, New Hampshire
**Previous AS Interstate's owned:
2014.5, 2015, 2016, 2017 (4x4), 2018 (4x4)
ScottP is offline   Reply With Quote
Old 10-17-2019, 08:25 AM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Yes, with the same limitations as with your trailer.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 10-17-2019, 10:30 AM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Should be about like plugging it into a 15 amp outlet. So it will not be "fully powered".
Old 10-17-2019, 07:12 PM   #4
2011 Interstate Coach
Evansville , Indiana
I use a Yamaha 2400 when tailgating because it is so much quieter than the Onan genset. It will run the air conditioner, microwave, or other items like tv and crockpot, but not at the same time. I'd bet that the Honda would give similar results. (You may need a soft start installed on your AC for it to work with yours)
BurntAsphalt is offline   Reply With Quote
Old 10-18-2019, 12:00 AM   #5
ScottP's Avatar
Bend , Oregon
Thanks everyone - I appreciate the guidance.
10-4 on the “soft start” for the A/C unit.
It’d be neat to remove the Onan and transport the Honda in the Onan location (dream)
Scott
Old 10-22-2019, 07:37 AM   #6
St amant , Louisiana
Scott
While you are dreaming, attach your propane tank to your Honda since its in the Onan’s location
SwampRV is offline   Reply With Quote
Old 10-22-2019, 08:12 AM   #7
ScottP's Avatar
Bend , Oregon
Oh my goodness...now that’s a lovely dream!
Old 10-22-2019, 09:23 AM   #8
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Agree... a propane fueled quiet Honda generator would be great... or diesel...
Just not gasoline...I would hate to have to carry an additional fuel source in my AI
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 10-22-2019, 09:30 AM   #9
2019 22' Sport
Carlsbad , California
Or get a gen that is dual fuel from the factory. Duromax Dual Fuel 2200 $650 from Home Depot.
Prettygood is offline   Reply With Quote
Old 10-22-2019, 10:02 AM   #10
wachuko's Avatar
Orlando , Florida
There is also a Westinghouse dual-fuel that folks in Facebook have been talking about...
https://www.amazon.com/Westinghouse-...a-605056815062
Name:	W-Dual Fuel Gen.jpg
Safe travels!
Wachuko
WBCCI #26769
Old 10-23-2019, 06:51 AM   #11
ScottP's Avatar
Bend , Oregon
But..............
Is it really as quiet as a Honda 2200? We have two of those units (one companion) with less than an hour’s run time accumulated.
PS - I agree about the propane conversion benefit.
Old 10-23-2019, 06:55 AM   #12
wachuko's Avatar
Orlando , Florida
But..............
I do not know first hand... would be great to be able to confirm that. Honda's noise level would be hard to beat...
Safe travels!
Wachuko
WBCCI #26769
Old 10-25-2019, 08:47 AM   #13
Lotus54's Avatar
Port Angeles , Washington
I rarely run the generator, it is too noisy inside- not as bad outside.
Plus the older AI has a tiny propane tank with quite a bit run off of that. (Hot water, refrigerator, stove, generator). But I’ve also only had to fill the propane one time on last years’ 11,000 mile six week trip around the country. And didn’t run out at the end either.
Diesel would be neat- since there is lots of fuel and readily fillable.
But I suspect it would be even noisier- and a LOT more expensive.
Propane burns nice and clean, and does well sitting extended periods of time.
Lotus54 is offline   Reply With Quote
Old 10-26-2019, 03:26 AM   #14
Hawk-ination's Avatar
2014 Interstate Ext. Coach
Cedar Rapids , Iowa
Has anyone hooked up two Honda generators in parallel? Supposed to be able to run the AC then, but I haven't seen a confirmation of that. Are they really worth the money and that much quieter? Agreed on the Onan though, it is so loud we rarely run it. I was somewhat shocked at the noise level between it and the AC unit.
Hawk-ination is offline   Reply With Quote
Old 10-28-2019, 11:03 PM   #15
ScottP's Avatar
Bend , Oregon
We have the pair of Honda’s from our AS Globetrotter, and ran them in parallel successfully.
I believe just one 2200i is all you’ll need to run the AC. Perhaps a soft start device mentioned earlier.
Old 10-29-2019, 06:43 AM   #16
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Came across a Champion 3400, dial fuel generator, that at 59 db's is darn close to the Honda for noise, and powerful enough to run a 15,000 btu A/C. Has a 30 amp RV plug included.
https://generatorgrid.com/reviews/ch...00w-dual-fuel/
Cheers
Sidekick Tony
Old 10-29-2019, 08:14 AM   #17
wachuko's Avatar
Orlando , Florida
Originally Posted by Isuzusweet View Post
Came across a Champion 3400, dual fuel generator, that at 59 db's is darn close to the Honda for noise, and powerful enough to run a 15,000 btu A/C. Has a 30 amp RV plug included.
Cheers
Sidekick Tony
And looks to be more compact than then one I shared (Westinghouse dual-fuel)
Safe travels!
Wachuko
WBCCI #26769
Old 10-29-2019, 08:22 AM   #18
wachuko's Avatar
Orlando , Florida
Not a detailed comparison... but thought I would share:
https://www.chainsawjournal.com/best...ter-generator/
Interesting as these both compared head to head with the Honda in terms of decibels: Honda is 59 decibels at maximum rated load and 53 decibels at quarter load
Safe travels!
Wachuko
WBCCI #26769
Old 10-29-2019, 09:30 AM   #19
Cedar Rapids , Iowa
Good to know all this information. I read the soft start could possibly reduce the life and/or is hard on the AC unit, but I guess why worry really? It’s so loud I’d love an excuse to throw it off on the highway anyway! Ha...
If you’re going to spend that much $$ for a second generator why not use it toward a quieter AC unit IF the soft start would happen to take it out!
Old 10-30-2019, 10:30 AM   #20
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
I am with Isuzusweet - we love our Champion 3400 dual fuel - run it on 20# LP will power everythiing in Blue Streak - as boondocker's this has been a great generator and the Tech Support is Fantastic....
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
Blog Languages: English/French/Spanish
drbrick is offline   Reply With Quote
Manual Shifting ASI transmission ScottP Sprinter and B-van Forum 12 09-22-2018 01:43 PM
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 04:04 PM
Have u sold ASI to dealer ? Lucylaud Sprinter and B-van Forum 28 07-21-2016 08:47 AM
Honda generator suggestions from Honda Tom Lafferty Electrical - Systems, Generators, Batteries & Solar 16 12-17-2015 04:37 PM
