Old 04-25-2016, 05:36 AM   #15
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by bsedor View Post
Excellent. Where is your business located again?
Naples, FL until Sunday and then on the road to Hood River, Oregon with an estimated arrival date of May 15.
Old 04-26-2016, 06:18 PM   #16
Montrose , Pennsylvania
Originally Posted by lewster View Post
Depends on where your Magnum is located. If it's under the rear lounge, then you can reach in and disconnect the RJ-11 plug (phone style) from the inverter. If it's a newer model with the Magnum under the driver side jump seat, remove the ME-MR remote and disconnect there.
A 'hard' reset involves removing the positive battery cable also, which is a bit more invasive. I provide a 300 amp marine switch in my installations for this pour pose, but Airstream does not.
A 'soft' reset involves simply depressing the little grey button on the Magnum above the green LED and holding it in until the LED start to flicker. This will also clear some minor faults.
So I got the dreaded NO COMM error. I disconnected the remote-no luck. Am I correct in thinking that I need to remove the jump seat in my Grand Tour to be able to access the reset button???!!!!
Bob & Margie Sedor
Montrose PA, Williamsburg VA, Auburndale FL
1 nice beagle, 1 mean chihuahua
bsedor is offline   Reply With Quote
Old 04-26-2016, 07:14 PM   #17
lewster's Avatar
You should be able to access the re-set button by lifting the jump set from the front, effectively tilting it back. There is an opening in the top panel that should give you access to the grey re-set button.
The Magnum is oriented so the re-set button and accompanying green LED will be found in the rear right corner of the Magnum. This is where you should also find the opening in the screen cover to allow access.
Remember to press the re-set button and HOLD IN until the green LED starts flickering.
Hope this helps!
Converter/Charger vs. Inverter/Charger moosetags Batteries, Univolts, Converters & Inverters 5 11-22-2013 10:21 PM
Inverter/Charger LRPorter Electrical - Systems, Generators, Batteries & Solar 10 02-18-2006 11:05 AM
Inverter/charger option mcneon Airstream Motorhome Forums 0 03-24-2004 05:37 PM
Adding charger where no charger has gone before Jabba Electrical - Systems, Generators, Batteries & Solar 4 03-08-2003 09:39 AM
hummmmm from the inverter/battery charger? Anna Electrical - Systems, Generators, Batteries & Solar 5 11-25-2002 06:46 AM
