Old 04-10-2014, 11:21 AM   #1
2011 Airstream Interstate
2011 Interstate Coach
Energy , Illinois
HELP, which one should I buy 2010 vs 2013 interstate
Hi,
I have been researching the interstates for some time, and now I need some help.
I have found good deals on both a 2010 and a 2013 model. Cost difference is 14K. Which would you have?
Thanks for the help.
Randy
raddocc is offline   Reply With Quote
Old 04-10-2014, 11:31 AM   #2
David M's Avatar
2013 Interstate Coach
Orange County , California
Hmmm, $14K doesn't seem to be much of a difference (see the thread titled "How many miles do you have..."). Is the 2013 a used unit too?
David M is offline   Reply With Quote
Old 04-10-2014, 11:44 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If the 2010 is based on the Sprinter 2500 (8550# GVWR) then the choice would be obvious to me. Go with the newer one, which is based on the Sprinter 3500 (11030# GVWR).
If the 2010 Sprinter is also a Sprinter 3500, then there are other factors to consider. Such as floor plan (twin bed, lounge, lounge/wardrobe).
Does the 2010 have an onboard generator? Back then generators were optional, I think. What about a solar panel (if that matters to you)?
How old are the tires? If they're nearly 5 years old on the 2010, you'll be buying new ones within a year.
For that matter, how old are the batteries? You might be buying new house AND chassis batteries right away on the 2010.
You may find after looking at these and other factors that the price difference isn't so large after all.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-10-2014, 06:38 PM   #4
73shark's Avatar
Overland Park , Kansas
For $14K and all other things being equal, I'd go for the 2013. In addition to what Protag mentioned, the 2013 has some upgrades such as the nav/radio, Durabright wheels, polished st-st grill, etc. Without knowing more specifics, it's hard to make a more informed choice.
Old 04-10-2014, 07:25 PM   #5
Boxster1971's Avatar
Fulton , Maryland
Also the 2013 likely has a Magnum Inverter/Charger which is much better than the Tripp-Lite in the 2010. But check it to be sure as I learned that not all 2013's necessarily have the Magnum Inverter/Charger.
- - Mike
Old 04-10-2014, 07:46 PM   #6
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Mine 2013 did had the Tripp lite just got changed out by AS to a Magnum.
PSchw is offline   Reply With Quote
Old 04-10-2014, 07:55 PM   #7
73shark's Avatar
Warranty issue on the Tripp-Lite?
Old 04-10-2014, 08:25 PM   #8
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
I also upgraded my charger to a 3 stage smart charger. No warrantee issuers just wanted a better charger to go with my AGM's.
TinCan
graysailor is offline   Reply With Quote
Old 04-10-2014, 08:39 PM   #9
PSchw's Avatar
Livingston , Texas
Not sure if it was warranty or mor operational design faults. I spend a lot of time in it traveling and working on the computer. Looked like the batteries never could keep up with the charge or I needed to readjust the dip switches and that is a job and a half lying on the belly with glasses trying to change settings. I hope it will be better with the magnum I guess I find out soon.
Old 04-11-2014, 07:24 AM   #10
Energy , Illinois
Thanks for the great ideas to ask, I called the owner of the 13 yesterday and she said that she made a mistake, it a 2012, does that change anything. It still seems like a good deal.
What I know of the 2010: 2010 Airstream Interstate 3500 EXT 22' - Convertible lounge - White ext with Sand Pearl int. Included: battery house, AC 13500 w/wall thermostat, Alcoa aluminum rims, video upgrade 19" rear, LP generator, Counter and table top - Corian, Sand Pearl Int Upgrade, coffee maker. No solar panels. needs new tires.
Are the solar panels that much of a benefit for trickle charging?
The 2012: has 22K miles, in-motion satellite, 3M film everything else she said was stock.
Old 04-11-2014, 07:42 AM   #11
PSchw's Avatar
Livingston , Texas
2010 us a extended how about the 2012? The solar would be a no issue for me as you see her on the forum lots of people do upgrade it so having non is as go as the 50w from AS.
Old 04-11-2014, 07:53 AM   #12
Energy , Illinois
2010 has 24k miles.
Old 04-11-2014, 10:37 AM   #13
73shark's Avatar
My stock solar panel keeps my house and chassis batteries at 100% when in storage w/ everything turned off. Of course the BIM and I believe the CO/Propane detector are both still on. Takes about 20-25 amp-hours/day to handle that. So unless you can plug in the shore power or drive it for about an hour, I'd go w/ the solar panel.
They both should have had their Service B done by now.
FWIW, I'd still go w/ the 2012 . BTW I didn't even know they had the Extended version in 2010.
Old 04-11-2014, 11:58 AM   #14
David M's Avatar
Yeah, I think the ETX version didn't come out until 2013. The one Raddoc is looking at might be a 2013 Airstream, built on a 2012 MB chassis.
David
Which mother should I buy? Lumatic Cleaning, Stripping & Polishing 0 04-02-2013 04:25 PM
Should I buy or should I run away ddruker Ribs, Skins & Rivets 16 04-15-2012 10:35 AM
Which One Would You Buy? LittleA Buyer Guidelines 10 04-18-2009 05:28 AM
looking for a used awning? Should we just buy a new one For a 25' Tradwind harestream Awnings 2 07-16-2006 04:53 PM
30 landyatch why should I buy one. poqn2slots Our Community 1 03-03-2003 11:28 AM
