Old 10-29-2015, 01:30 PM   #1
ghaag's Avatar
2014 30' FB FC Bunk
2007 25' Safari FB SE
2014 Interstate Ext. Coach
Jonesboro , Arkansas
Help Please, mechanical issues w Interstate
I was about to leave for Texas and my 2014 Airstream Interstate is dead, battery has full charge but I have no electrical and when key is inserted in the ignition it will not turn. Does anyone have any suggestions?
Thanks in advance!
Greg
ghaag is offline   Reply With Quote
Old 10-29-2015, 01:33 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Step on the brake pedal as you turn the key......really.
Old 10-29-2015, 01:38 PM   #3
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Is the steering wheel turned? Wiggle the steering wheel, step on the brake and see if you can turn the ignition. Happened to me on another type of vehicle.
Kelvin
Old 10-29-2015, 01:47 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Try removing the neg battery cable from the battery, touching it to the positive cable, and then putting the cable back on the battery.
Brevi tempore!
Old 10-29-2015, 01:49 PM   #5
Mjgman's Avatar
2013 Interstate Coach
Bradenton , Florida
Is the coach battery dead as well? The separator might not be working and it drained you car battery.. That happened to mine and they had to replace the separator.. Give it a jump and if it starts, that is most likely your problem..
Mjgman is offline   Reply With Quote
Old 10-29-2015, 01:51 PM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Several things it could be. Listed in no particular order:
1 - Shift lever isn't all the way up into Park.
2 - Steering wheel is locked when the key is off. But it may be binding against the locks. Wiggle the wheel.
3 - Battery is deader than you think, and there is no power to the RFID reader in the ignition switch.
4 - If you have more than one vehicle with RFID-chipped keys, a key from a different vehicle is too close to the ignition switch. I have to keep my two vehicles' keys on separate rings for just that reason.
5 - Chassis battery disconnect down by the accelerator pedal came loose, possibly as a result of accidentally being kicked, which kills power to the ignition system including the RFID chip reader in the switch.
6 - Blown fuse under the dash. Fuse #2 (25A) is electronic steering lock and Fuse #3 (10A) is start switch. Either one could cause the ignition switch not to work.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-29-2015, 03:35 PM   #7
ben322's Avatar
2009 Interstate
Bethesda , Maryland
Maybe a little early for a 2014 but check the Y-Cable which is common failure and a periodic replacement item.
2009 Airstream Interstate
ben322 is offline   Reply With Quote
Old 10-29-2015, 03:57 PM   #8
2015 Interstate Ext. Coach
Chicago , Illinois
In case I have this problem in the future, what's a Y-cable?
Marks71 is offline   Reply With Quote
Old 10-30-2015, 03:59 AM   #9
ben322's Avatar
2009 Interstate
Bethesda , Maryland
The Y cable runs from the battery to the alternator and starter. Check the voltage with the van running, (13.5-14.2), and the clip that attaches to the transmission which tends to fail. Earlier models had more of a problem as the part was improved but can still be a failure point. The symptoms typically are a click when the key is turned to start on a good battery but voltage irregularities can result in a no-charge state as well. Online the OE part is less than $70.
Old 10-30-2015, 05:37 AM   #10
Catch-22. The OP cannot even turn the key in the ignition and so can't tell if the Y-cable is the problem.
WBCCI #1105
TAC LA-4
Old 10-30-2015, 10:40 AM   #11
1994 34' Excella
San Antonio , Texas
Regular issues with auto's not starting . . .
Always check the cables for tightness. You shouldn't be able to turn the cable on the post. That said, I don't own your machine but am only speaking of problems I had in the past with batteries in vehicles.
I wish you the best of luck a remain open so as to consider all suggestions. Correct key - nothing out-of-date if that matters. If using a key fob (push-buttons on plastic key), does it have a battery?
Turn on lights and radio to check power of battery.
Back in the old days some of our vehicles on the farm would lock up where the old starters wouldn't turn until you rocked the vehicle!
Again, I wish you the best. At my age, failure is part of the equation. It all works out though! jd
delongj is offline   Reply With Quote
Old 10-30-2015, 10:46 AM   #12
Lily&Me's Avatar
Normal , Illinois
Thanks in advance!
Greg
Ours has had this problem a few times, and jiggling the steering wheel has resolved it.
Maggie
Old 10-30-2015, 02:07 PM   #13
2014 25' International
2010 22' Interstate
Carol Stream , Illinois
Last year I too had that problem and tried all of the above, to no avail. I even tried a different key fob and key. Nothing worked. Mercedes came out and connected their expensive code reader on (I tried my "cheap" one first). Anyway nothing seemed to happen. The technician tried reading the codes again when some dash lights flashed for no apparent reason, then the vehicle started. The technician had no idea what happened. He thought it may be a computer issue. Since that time I never had another problem with the unit. Who knows? Gremlins perhaps
John Millner is offline   Reply With Quote
Old 11-01-2015, 03:15 PM   #14
ghaag's Avatar
2014 30' FB FC Bunk
I am embarrassed to say I did not know there was a second battery under the drivers seat, which is apparently the main battery. This one was completely dead and as a result nothing worked. As soon as they replaced that battery everything went back to normal. Thanks to everyone for their help!
Mechanical types please look at these pics and give opinion engelken Our Community 7 07-21-2010 10:56 AM
Need help with mechanical jack imeynstein Jacks, Stabilizers, Lifting and Leveling 4 11-09-2008 07:09 PM
Major mechanical renovation.. see it! RealShinyOne Mechanics Corner - Engines, Transmission & More... 13 05-07-2005 08:16 PM
Mechanical reference books/manuals recommendations 1984air310 Airstream Motorhome Forums 3 03-07-2004 10:37 PM
Post rally mechanical repairs PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 16 07-10-2002 04:36 PM
