Old 06-07-2014, 04:24 PM   #1
2014 Interstate Ext. Coach
Spring , Texas
Help Macerator Pump not working
I have a 2014 Interstate and after having dumped Black/Grey tanks 15+ times, today it decided not to work any longer. It appears that the the Macerator pump is not working. I do hear both the Black & Grey Valves open and close independently but when I flip the toggle switch for the pump nothing happens. Could the fuse be blown? Anyone have any idea where the fuse or reset button is? The 800 support could not help out at all. Thanks --- Jim
Cobra1169 is offline   Reply With Quote
Old 06-07-2014, 04:41 PM   #2
Newbie
joemikeb's Avatar
2013 Interstate Coach
Fort Worth , Texas
That happened to me and it was a blown fuse under the lounge in back.
Make errors otherwise the Great Spirit realizes
you have finished your purpose on earth.
Navajo saying
joemikeb is offline   Reply With Quote
Old 06-07-2014, 04:56 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The only fuses I've ever blown on my Interstate are for the macerator pump and the hose reel take-up.
If replacing the fuse doesn't work, there's a slot on the end of the pump that will take a screwdriver, that you can use to manually turn the pump. If the pump jammed on something, a manual assist (or hand-cranking it backwards) might free it up.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-07-2014, 05:51 PM   #4
Spring , Texas
On a 2014 Model does accessing fusebox in the lounge bench require unscrewing the cushions from the frame or is there an easier access point?
Old 06-07-2014, 05:54 PM   #5
Should be a gray or black plastic cover over the fuse panel, right in between the 12v disconnect and the 120v circuit breakers, when you open the door on the front of the seat base.
WBCCI #1105
TAC LA-4
Old 06-07-2014, 05:57 PM   #6
Spring , Texas
Perfect!!! I know where that is!!! I'll go check now.
Old 06-07-2014, 07:07 PM   #7
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
Cobra,
If a fuse has blown it could be that the macerator is stuck or jammed.
If your macerator is like my RV Sani Con there is a slot at the end of the unit. Use a flat screw driver blade to gently turn the shaft counter-clockwise. This may "un-stick" it.
Things like tissue or human hair can cause jamming. Sometimes, in-activity can cause the shaft to seize up too. I always use a screw driver to turn the shaft a few times before using the macerator in such a case.
Here's an owner's manual should your unit be similar. See page 9, TROUBLE SHOOTING for illustration.
OM_SaniConTri_70337B_091809_EFS_P.pdf
Sergei
SmokelessJoe is offline   Reply With Quote
Old 06-07-2014, 07:48 PM   #8
Spring , Texas
Thank you everyone one for your help!!!! One new 20Amp fuse and a few rotations of the macerator and I'm Back in Business (pardon the pun)!!! Ya'll just saved me a 3 hour trip to the Dealer!!!! I love this forum what a life saver!!!
Thanks --- Jim
Old 06-08-2014, 10:59 AM   #9
Boxster1971's Avatar
Fulton , Maryland
Thanks --- Jim
Glad you solved this common problem. Keep extra fuses handy - you will need them again. I've had mine do same thing a few times. It's best to leave the stuff in black tank until it is nearly full and decomposed a bit. When a big chunk hits that macerator pump it will typically get stuck and blow a fuse. Don't ask how I know this.
- - Mike
Old 07-30-2017, 11:47 AM   #10
B.E.A.M's Avatar
2017 Interstate Grand Tour Ext
Cresskill , New Jersey
macerator pump fuse popping
where is the macerator pump located? I am on the road and pump keeps blowing 20 amp fuse. and tanks are full now.
B.E.A.M is offline   Reply With Quote
Old 07-30-2017, 12:30 PM   #11
B.E.A.M's Avatar
Sorry dumb question just needed to lay on my back and there it was staring at me. turned with a flat head screw driver and presto back to normal.
Old 07-30-2017, 01:04 PM   #12
Sorry dumb question
There are no dumb questions. Just dumb answers.
WBCCI #1105
TAC LA-4
Old 07-30-2017, 08:15 PM   #13
Fulton , Maryland
Yup! That solves about 99% of problems with macerators. I agree with Protagonist- no such thing as a dumb question here.
- - Mike
Old 12-19-2017, 01:28 PM   #14
Dallas , Texas
the mascerator pump is located underneath the hose reel and valve panel on the underside of the coach?
and thank you for instructions on the fuse. the pump just froze yesterday so I need to check the fuse. I have not used the pump in some time
stusuz is offline   Reply With Quote
Help Needed: macerator pump on a '68 ambassador etanbf Waste Systems, Tanks & Totes 22 07-07-2012 10:05 PM
Macerator pump lift restrictions? blickcd Waste Systems, Tanks & Totes 2 02-25-2009 12:40 PM
Macerator pump Brad Hunt Waste Systems, Tanks & Totes 10 09-29-2007 10:45 PM
Valve before or after macerator pump? malconium Waste Systems, Tanks & Totes 7 07-29-2004 04:20 PM
Macerator pump uncleneal Waste Systems, Tanks & Totes 4 03-12-2004 09:40 AM
