Old 12-05-2019, 04:48 PM   #1
2011 Avenue Coach
Philadelphia , Pennsylvania
Help identifying 2 wires hanging from Airstream Avenue
Anyone know what these two wires are for? I first thought they were for the Macerator pump that had been removed, but I think those wires are on the right side.
Thanks in advance!
TrailRunner1 is offline   Reply With Quote
Old 12-05-2019, 05:06 PM   #2
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
I believe you are correct that they are not for the missing macerator pump as those wires would be on opposite side of your dump valves and a heavier gauge wire.
On my Avenue, I have two sets of wires in that area (neither of which are cut and hanging like yours). One set goes to the tank heating pad. I assume the other goes to the tank level sensor.
Do you get a reading from your gray tank monitor panel? Does your gray tank heater light come on red when the switch is on? Is the tank heater pad still attached? It is common for them to start to detach from the leading edge. If not caught in time, or if caught on road debris, the pad could have been ripped off completely.
rowiebowie is online now   Reply With Quote
Old 12-05-2019, 05:21 PM   #3
rowiebowie's Avatar
2012 Avenue Coach
Also, I notice there is a flexible connection clamped in your gray piping in that area. Mine has continuous black abs glued pipe. This could be a factory change between our model years, or it could be an indication of a repair, possibly from road damage which could have also taken out whatever the wires connected to. Just speculating, since it looks different than mine.
Old 12-05-2019, 06:21 PM   #4
2011 Avenue Coach
Thanks, I will check the grey tank tomorrow morning.
Old 12-06-2019, 11:37 AM   #5
2011 Avenue Coach
Yes, grey tank heating pad is missing. Thanks for the help!!
Wires hanging under coach. Amg Sprinter and B-van Forum 7 11-06-2017 03:43 PM
7 Wires in, but 4 wires to lights..??? KZGoodchild Lights - Interior & Exterior 1 05-03-2017 05:10 PM
Help identifying wires on 76 26' Argosy 909kenu All Argosy Trailers 18 07-02-2016 08:09 AM
Help Hanging Clock Safely Sharon_Jon General Interior Topics 13 01-22-2015 05:35 PM
Need help seeing a problem with the thing hanging off the axle PoconoAir Axles 12 03-19-2007 02:49 PM
