Old 08-22-2015, 11:44 PM   #1
2012 Interstate Coach
Palo Alto , California
Help: House Air conditioner not working with generator
My generator appears to be running fine. All lights on panel light up. Microwave worked. However, when I pressed the AC on it doesn't start. I could change the clock on the thermostat. But no power or fan goes on. I just had my AI checked out by my mechanic who fixed a faulty wire connection from the inverter to house battery which has not been charging it. Mechanic told me that all units such as AC were now working. AI has been plugged in when not in use since batteries were just checked out as fine. What could be the issue?
roadmama is offline   Reply With Quote
Old 08-23-2015, 06:42 AM   #2
Figment of My Imagination
Protagonist's Avatar
The generator only puts out 20amps, not 30amps. And your Energy Management Center sheds loads in a specific sequence when there isn't enough power to go around. If memory serves, the A/C is the first load that is shed.
So my guess is that since the A/C draws 15 amps all by itself, you've got too many other things running that add up to more than 5 amps between them.
When you start up the generator, check the EMS panel in your overhead locker, and if it hasn't automatically switched to 20amp mode, then manually switch it.
Make sure your water heater is in propane mode, not electric, if it's on at all. And turn off everything else except the fridge when starting the A/C, then turn on one item at a time until you find out which load was the straw that broke Onan the Camel's back, i.e. the one that caused the A/C to quit.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 08-23-2015, 10:50 AM   #3
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
I once had a similar experience. In my case the AC did not come on for about 60 seconds after I turned it on at the thermostat. I assume there some background "staging" taking place....it did start and ran fine. I also noticed an "hourglass" icon on the thermostat panel. It was there until it started.
FMCA # 436814
toskeysam is online now   Reply With Quote
Old 08-23-2015, 12:14 PM   #4
Boxster1971's Avatar
Fulton , Maryland
The EMS on my 2013 has three modes 30 amp, 20 amp and GEN. So it automatically knows when running on limited Generator power. Yes - AC get shed first and there can be minutes of time delay after turning on the AC before it starts.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 08-23-2015, 02:57 PM   #5
toskeysam's Avatar
In retrospect that makes sense.....and I supposedly understood load shedding. Did not pay attention at the time, but I was on 20 amp service, so it would've responded just like the Gen mode. There was a ~12-14DC amp load in the Magnum in Absorb Charge mode at the time. The power mgmt probably held the AC off until the charge current dropped........then again....that was 12 V DC amps......hmmmmmmm
FMCA # 436814
Old 08-23-2015, 05:40 PM   #6
Thanks everyone for your suggestions. I went out to retry the a/c on generator and it worked.
Air Conditioner and Outlets Stopped Working - Need Your Input flyfishrra Electrical - Systems, Generators, Batteries & Solar 17 08-30-2012 02:01 PM
Air Conditioner tripping breaker in my house while on shore power Wgbarrbevco General Repair Forum 10 08-16-2012 06:07 PM
House Air conditioner, anybody do this?? howco Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-15-2010 05:35 AM
air conditioner stopped working richinny Furnaces, Heaters, Fireplaces & Air Conditioning 10 05-03-2010 06:10 AM
Air conditioner thermostat working? nickcrowhurst Furnaces, Heaters, Fireplaces & Air Conditioning 7 03-18-2004 07:37 PM
