Old 11-10-2015, 09:09 AM   #15
2016 30' Classic
Maitland , Florida
Call your insurance company
I just read a blog post with a similar story:
Putting Regular Gas in a Diesel Vehicle | Camper Chronicles
The upshot is that your insurance company will likely cover it under "accidental fuel contamination."
FreshAirStmr is offline   Reply With Quote
Old 11-10-2015, 09:32 AM   #16
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Do you suppose that it is just a coincidence that the dealer has a $9,000 solution to a problem that I have gotten out of for about $200 plus towing three times now?
Sorry about my skepticism, SOMETIMES "the experts" are all about making a buck....
Brevi tempore!
Old 11-10-2015, 10:47 AM   #17
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
A costly fix it can be, my repair bill was over $1500.00 on my RAM ecodiesel. After filling up with DIESEL as I usually do, I drove home, Later that day as I pulled out of my driveway the truck had almost no power & the valves were clanging. Towed to the dealer it was determined that the fuel I got was contaminated and the repairs not covered under warranty so I filed an insurance claim & only had to pay my deductible of $250.00. Allstate is investigating the cause. What I did learn was that even if I had put gasoline in or mixed it with the diesel my insurance would still cover the repairs under the comprehensive part of my policy.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 11-10-2015, 10:49 AM   #18
1977 31' Sovereign
Lynnwood , Washington
Whatever you do, do not start your motor!! Tow your vehicle to the dealer ASAP.
1) Fuel tank will hafta be removed and thoroughly drained.
2) Fuel tank should be sent to a radiator shop for professional cleaning.
3) Whether you started the engine or not, fuel lines should also be thoroughly drained.
4) Replace fuel filter(s).
This is not the time to take short-cuts. If there was ever a time to be thorough, this would be it. Leave no stone unturned.
Tom
TomKirk is offline   Reply With Quote
Old 11-10-2015, 11:03 AM   #19
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Somewhat on the subject they need to get rid of this bio fuel nonsense. Serves no purpose other putting money into someones pocket and just confuses the consumer. Getting fuel use to be a no brainer now we all have to take a double look at the pump to make sure what we are getting is what we want.
Hopefully no damage done.
TinCan
graysailor is offline   Reply With Quote
Old 11-10-2015, 11:06 AM   #20
2015 23' FB Flying Cloud
Redmond , Washington
Been there done that!
I, too, was a victim of momentary inattentiveness due to haste combined with the BP infamous green "branding" on their gasolibe handles. BP uses black handles for their diesel. I learned this from the blogs that are filled with exchanges between BP and unwary consumers. Yes, a standard should be in place. That is routine in most industries regarding safety issues. And being stuck on the freeway is a safety issue.
After putting gasoline in my Jetta Sportswagen TDI I drove for about 4-5 miles onto I-95 in SC and I then felt a sudden engine miss. I stopped immediately and checked my fuel receipt. My heart sunk when it read "Reg" fuel.
I called AAA and was towed on a flatbed 100 mikes to the VW dealer in Fayetteville, NC. They drained the tanks and lines and inspected the injectors, compressor, etc. they said I averted a likely $8 - $10,000 repair bill because I stopped immediately. They said there was enough undiluted diesel in the fuel lines and system to get me the distance I drove, but after that I would certainly have done major damage. Good news: the car is still in great shape after another 50,000+ miles (despite the current VW defeat fiasco).
I now take even more care when fueling my Grand Cherokee Eco Diesel. And my wife and I now are quite deliberate in our language concerning the difference between the words "fuel" vs. "gas" as a frequent reminder.
WestieHouse is offline   Reply With Quote
Old 11-10-2015, 11:12 AM   #21
Parker , williamdcrockett
It should not cost $7500 to repair it. The fuel filters should have alerted you of a problem. I suspect the worse case scenerio would be you burned up a few fuel injectors. The engine is designed so that injectors can be easily replaced. Eventually they fail under normal conditions.
wcrockett is offline   Reply With Quote
Old 11-10-2015, 11:29 AM   #22
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Several years ago my neighbor filled his ford 7.3 powerstroke with gasoline, he drove almost 40 mile,noticed the miss, hauled it to my shop, I drained the tanks, changed the fuel filter, blew out all the fuel lines with diesel fuel, it run fine for 6 weeks, then changed injector pump and injectors, 6 months later it took a reman engine. Very expensive lesson, the new computerized injector are very expensive...
Old 11-10-2015, 12:30 PM   #23
RPB
1964 19' Globetrotter
Auburn , California
I did the exact same thing in Wisconsin with my then new 2011 Sprinter, used the green handle, drove a couple miles, ran funny, went back to station to discover BP used green for gas. Siphoned out the tank, pushed it back to pump, filled with diesel and drove off. Filled again in 100 miles (to delete as much as possible) and kept doing that for the next 500 miles on way back to California. That was 60,000 miles ago, no issues.
Sadly, it had happened once before with my 7.3 Ford in Ashland, Oregon (where they must pump the fuel) the attendant put in gas while I went inside. Droving to California, went about ten miles to border where it quit running. Towed to Ford dealer in Ca. He said it happens @ 20 times a year from Oregon. They flushed system in a couple hrs, assured me there was not any damage and I put another 100,000+ miles on it without any issues.
You SHOULD be fine
RPB is offline   Reply With Quote
Old 11-10-2015, 12:55 PM   #24
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
First time diesel owner here and reading this thread with interest. I'm going to be very careful I read the pumps and will watch who pumps for me in the goofy states.
Kelvin
Old 11-10-2015, 12:55 PM   #25
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I have almost done the same thing a couple of times. I have become a little paranoid about it and now smell the fuel nozzle before putting it in the truck. The smell of diesel is very distinctive. Doing this makes me pay more attention to what I'm doing.
Brian
SuEllyn & Brian McCabe
Old 11-10-2015, 12:58 PM   #26
2dabeach's Avatar
2007 25' Safari FB SE
North/East , New Jersey
I always sniff the nozzle before pumping diesel in my truck or my boat.
2007 Safari 25' FBSE LS
2006 GMC Sierra 2500HD Crew Cab 4WD Duramax
2dabeach is offline   Reply With Quote
Old 11-10-2015, 01:44 PM   #27
2014 Interstate Coach
Arroyo Grande & Central Point , California & Oregon
Brevi tempore!
Same story here, I fueled my VW Jetta Diesel with regular gas, discovered it within a mile and had it towed. Dealer quoted $700. A local German automotive specialist did it for under $200.
c21bill is offline   Reply With Quote
Old 11-10-2015, 03:34 PM   #28
2007 31' Classic
Buhl , Idaho
My wife did the same thing to our pickup - she drove it home and then remembered!!! I drained the tank, refilled it with diesel and all was well - except we did burn the valves a little bit but nothing to worry about. Gasoline floats on diesel so if your tank draws from the bottom - and most do - you should be able to drive it for a little ways without any damage - unless, of course, you're driving on the bumpiest road in the USA!!
goodshepherd is offline   Reply With Quote
Help. AC quit putting out cold air. daveswenson Furnaces, Heaters, Fireplaces & Air Conditioning 25 07-08-2015 10:49 PM
Polishing tip found accidentally Hank A Cleaning, Stripping & Polishing 7 03-01-2007 10:33 AM
using a futon mattress instead of cushions tinsltootsie Interior Restoration Forum 7 05-13-2004 08:01 PM
Delta Faucet instead of the old Moen okay? 73ANDY Sinks, Showers & Toilets 7 05-01-2003 06:21 PM
Pergo or ? instead of carpet Kistler Floor Finishes 38 04-20-2003 08:19 PM
