Old 11-09-2015, 07:00 AM   #1
2015 Interstate Ext. Coach
New York , New York
Heater blowing but no heat?
Hi I have a 2015 Interstate ext. Lounge and I put my heater thermostat on (says Furnace and temp is set higher than internal temp) but the heater isn't blowing hot. I used it twice before and it was fine. My Sprinter is plugged in.
Outside temp is over 60 degrees.
LilyAnder is offline   Reply With Quote
Old 11-09-2015, 07:13 AM   #2
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Did you have the propane turned on?
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 11-09-2015, 07:17 AM   #3
New York , New York
Duh....I did turn it off a awhile ago. I guess I thought the heater when plugged into ac is running on electric only? Like the hot water does....I'm still new at this!!!!!!!!! thank you I'm sure that's what it is...
Old 11-09-2015, 08:25 AM   #4
Fulton , Maryland
No worries - we all have "duh" moments when learning about how these systems work. The furnace in your Interstate is propane only and uses 12V DC for control functions.
- - Mike
- - Mike
Suburban Heater Blowing Cold Air occasionally Cody Madison Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-20-2014 03:39 PM
Oh oh, heat pump only blowing cold air almcate Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-17-2013 03:17 PM
Heat Pump/Air Condition Blowing Hot Air Safari-Rick Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-24-2012 08:30 PM
Heat Pump blowing cool air? craftsman Furnaces, Heaters, Fireplaces & Air Conditioning 11 04-08-2008 06:01 PM
Furnaces blowing but no heat Dave Emmerich General Motorhome Topics 6 01-04-2003 07:53 AM
