Old 11-25-2015, 07:38 AM   #1
Seguin , Texas
Question Heated tanks
I would appreciate any information about using the heated tanks when antifreeze has been added to the tanks. The temps will get down to single digits. My interstate is hooked up to 30amp service but is outside. It has been winterized but the batteries have not been removed. The shop can't get to it for several weeks and I can't do it myself. Should I run the coach heaters also?
Sgkh1947 is offline   Reply With Quote
Old 11-25-2015, 08:05 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
You do not need to use your tank heaters while the plumbing system is winterized.
It may be best to turn off the inverter/charger during such cold temperatures, unless you know for sure that the house batteries have the Magnum temperature probe— some 2015 models have it, and I'm pretty sure the 2016 models do, but "pretty sure" is not completely sure. Waiting until the batteries warm up to recharge them— especially if they're already fully charged and you're not using them— is better than trying to charge them at low temperatures without adequate temperature compensation on the charger.
As for running the furnace while the van is stored, don't. While it will keep the interior warm, it will also lead to condensation on every cold interior surface, such as all of your many windows. While the plumbing system is winterized, your Interstate is just another automobile, albeit a big one. Treat it exactly the same as you would treat your other vehicles in the cold. There's no particular need for it to be kept warm inside if you're not using it.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
"heated tanks"??? tomcook Waste Systems, Tanks & Totes 10 10-12-2016 02:34 PM
Heated Holding Tanks LY-30 jbwsc Land Yacht/Legacy Motorhomes 3 01-24-2016 11:58 PM
Heated holding tanks on 1976 Trade Wind? Patricia720 1970-79 Tradewind 5 01-09-2014 12:01 PM
heated tanks tmtrkingco1 Waste Systems, Tanks & Totes 4 10-25-2007 10:10 PM
Bambi holding tanks..HEATED..CONFIRMED dtbw 1997 - 2004 Bambi 3 06-30-2003 06:47 AM
