Old 04-07-2015, 08:23 AM   #1
2014 Interstate Ext. Coach
Miami Beach , Florida
HDMI Splitter Panel in 2014 Interstate
My battery continues to drain when stored dry, so my dealership and I just went through every power-drawing item in our Interstate and found the only light that remains on is the HDMI splitter box that is mounted on top of the DVD player in the console behind the front TV. Neither of us could figure out how to get those blue and red lights (and the unit) to be powered down so its not draining the battery. The Kenwood radio is off. Both TVs are off. The antenna booster is off. But, we can't figure out how to turn the HDMI panel off. Any ideas? Is it even drawing power or is it fine to stay on? Thanks again in advance.
ATE123 is offline   Reply With Quote
Old 04-07-2015, 01:32 PM   #2
Lineolated's Avatar
2014 Interstate Coach
Centre County , Pennsylvania
We had the same problem. Couldn't find a switch and those lights are annoying at night. My husband pulls the plug from the box.
Lineolated is offline   Reply With Quote
Old 04-07-2015, 01:49 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
It plugs into an outlet, right? If so then the answer is simple, an outlet switch. http://www.amazon.com/Belkin-F7C016q...+outlet+switch
I don't have an HDMI splitter in my 2012, but I use outlet switches like these to power off the televisions when I'm not going to be using them— televisions also draw power when turned off, in order to be able to receive an "on" signal from the remote.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-07-2015, 03:42 PM   #4
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
The BIM (battery isolation module) and solar charge controller also always draw current.
Old 04-07-2015, 04:19 PM   #5
I don't see where it plugs in. The two outlets have plugs for the the TV and DVD player. (I pulled both plugs out, and the lights on the HDMI splitter stayed on.) Not sure how to 'pull the plug from the box', but I can just start pulling plugs and see what works.
Old 04-07-2015, 04:34 PM   #6
73shark's Avatar
My HDMI splitter on my home theater setup is powered by the source device. See if pulling the source HDMI cable causes the LED to go out.
Old 04-07-2015, 04:36 PM   #7
Lineolated's Avatar
Name:	ImageUploadedByAirstream Forums1428442424.358097.jpg
This is our setup - a monoprice HDMI splitter. On the left side is the HDMI output and a 12v power in. The other end with the adapter is buried somewhere in the wall. We just pull the jack from the 12v in.
Old 04-07-2015, 04:48 PM   #8
Awesome- thanks. Same set-up as mine.
HDMI Splitter Cable GerryH Audio, Video & TV 1 12-14-2011 12:26 PM
1983 Antenna System Splitter? jerry d Audio, Video & TV 0 07-09-2011 11:03 AM
TV Cable/Splitter Ugly1 All Squarestream Trailers 2 10-12-2009 01:23 PM
digital tv: splitter or amplifier? Chuck Audio, Video & TV 2 07-08-2007 05:46 PM
Cable Splitter jhobbs Electrical - Systems, Generators, Batteries & Solar 6 10-14-2005 12:02 PM
