Old 06-19-2015, 09:34 AM   #1
ghaag's Avatar
2014 30' FB FC Bunk
2007 25' Safari FB SE
2014 Interstate Ext. Coach
Jonesboro , Arkansas
Has anyone pulled an Airstream Bambi with their AI out west?
I was considering purchasing a Bambi to pull with our 2014 Interstate. I am concerned that either the engine or transmission will not handle pulling thru the mountains out west. Does anyone have experience with this?
Greg
ghaag is offline   Reply With Quote
Old 06-19-2015, 09:38 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Seems every rally I go to there is at least one duel Airstream rig. All have told me great combination with smooth safe towing.
MICHAEL
Old 06-19-2015, 10:27 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Greg,
I towed a 19 CCD for 6 years with my 2004 Sprinter 2500 at it near the CGVW. I eventually went thru a turbo, alternator AND transmission during what was to become the final trip of that rig combo at 115K.
When it ran well, it was great! I would never pull another trailer over 2000lbs without extensive mods to the Sprinter, which I have done to my 2011 service van.
Suspension and cooling system upgrades along with the very necessary aux. transmission cooler.
I might even think of doing it again!!!!
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
Old 06-19-2015, 04:34 PM   #4
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
The later model interstates are built on Sprinter 3500 vans with dual rear wheels and lower axle ratios. They can handle towing better than the older 2500s since the axles, brakes and other component are stronger. They also have a V-6 with more power.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 06-20-2015, 11:07 AM   #5
2014 25' International
2010 22' Interstate
Carol Stream , Illinois
The newer Interstate 3500's are built to tow if you stay within the guidelines. My 2010 towed flawlessly through the mountains with a minor reduction in MPG
John Millner is offline   Reply With Quote
Old 06-20-2015, 11:25 AM   #6
hamiltonmj's Avatar
1965 17' Caravel
Opelika , Alabama
I agree with John. I tow a 1965 17' Caravel with no problems. The 3500 is very stable with the dual rear wheels and was probably built with towing in mind. I also use the Prodigy RF wireless brake controller because I tow the Caravel with two other vehicles and it allows me to plug and go.
Mike Hamilton
WBCCI # 2766
2013 Airstream Interstate (Darth Vader)
1965 17' Caravel (R2D2)
hamiltonmj is offline   Reply With Quote
Old 06-20-2015, 03:54 PM   #7
ghaag's Avatar
2014 30' FB FC Bunk
Thanks to everyone for your insight!
Has anyone worn out their Coupler? thecatsandi Hitches, Couplers & Balls 28 04-02-2012 01:45 PM
Has Anyone Else Had a Bear Climb In Their Airstream? cclarkego Off Topic Forum 117 01-17-2011 08:30 PM
Has anyone put a photo tower on their Airstream? Msmoto Photography 4 12-13-2009 09:28 PM
Who's done their Airstream with their custom style interior? ANY PICS LAWFISH Upholstery, Blinds, Walls & Interior Finishes 1 02-08-2009 05:36 PM
Has anyone ever added on to their airstream wvairstream Full-Timing 18 11-16-2008 09:24 PM
