Old 05-24-2016, 02:39 PM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Our onboard Onan generator runs on propane. If we did replace with a standalone unit transported only when needed, it would have to be propane as well. This is a darned good idea, and not something I've looked into yet. Even when we lose electricity and water because of hurricanes, we tend not to lose gas service unless uprooted trees have damaged the local lines, but still it's less likely (I have vivid memories of helping to cook food for nine local "refugees" on a residential gas cooktop right after Hurricane Rita). If I could ID a unit with an adapter or whatever that could run on both hard-piped natural gas and onboard propane, that would indeed be something to think about.
You can get a propane conversion kit for a Honda Eu2000i. There are several threads on the subject here on the Forums. Not only that, but you could get a Honda companion unit to run two in parallel for home hurricane kit use, that would provide a total 4kW in place of the Onan's 2.5kW, and still weigh 26% less (46# each vs. the Onan's 125#). Really, the only benefit of the Onan is its low height that allows permanent mount underneath a Sprinter. In every other respect it's an inferior product.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-24-2016, 03:55 PM   #16
Natchitoches , Louisiana
I had two Honda 2k's with the parallel kit before buying the interstate. All of protag's comments about the advantages are correct. The Hondas are quieter, produce more power, and can be stuck out away from the van, eliminating the vibration. I'm going to do the propane kit soon, and ditch the Onan.
jdthor is offline   Reply With Quote
Old 05-24-2016, 08:11 PM   #17
Houston , Texas
What about using the space to add Lithium batteries. Increase the Inverter size and you can run the AC for a couple of hours. The Roadtreking Wendland's have stated they have run their's 4 hours.
Protag, do you know if anyone has successfully replaced the Onan and permanently mounted a Honda unit?
Mcrider is offline   Reply With Quote
Old 05-24-2016, 09:42 PM   #18
Bellevue , Washington
How would you carry the two generators? I have a Honda 3000iu so know the huge difference in noise and performance. But don't know how to store them and to some extent, deal with hassles of setting them up, and then tearing back down all the time.
amirm is offline   Reply With Quote
Old 05-25-2016, 12:36 AM   #19
Lithiums can't be charged below freezing so there are additional constraints to consider if you choose to sling any under the chassis.
LB_3 is offline   Reply With Quote
Old 05-25-2016, 04:53 AM   #20
Originally Posted by avionstream View Post
I found info on the 3500 sprinter In 2006 on cars.com
My husband said the same thing - they do exist. When I pull listings it's almost always with the 2500 stock photo (including on cars.com), so I wondered if it were a misprint. Edmunds doesn't list them at all. But if I do a Google image-search, I see a few T1N 3500s. I've never seen one in the wild, and I eyeball every T1N that I pass.
Old 05-25-2016, 05:07 AM   #21
Gainesville , Florida
Most if them are clapped out work trucks now.
Old 05-25-2016, 01:26 PM   #22
PSchw's Avatar
2005 39' Skydeck 390 SD
Livingston , Texas
Yes they do exist I had a 2004 3500 with rear dully wheels. I used it for work it was the long and high version.
It run grade with the 5 cylinder diesel. I always was thinking about making it to a camper van but then things changed and In sold the company with the Sprinter and purchased the Airstream Interstate a few years later.
Peter
PSchw is offline   Reply With Quote
Old 05-25-2016, 05:50 PM   #23
"How would you carry the two generators......" I used to have the 3K, which is actually quieter than the 2k, but traded it for the two smaller models because of the weight. I just throw the two Honda2k units into the back. They are easy to move around, and the parallel kit is easy to connect. The other advantage is that you can leave one of them at home if you know you won't need the ac on your trip. The little Hondas are attractive theft targets, however.
Old 05-26-2016, 07:14 AM   #24
...The little Hondas are attractive theft targets, however.
Ugh... what are these manufacturers THINKING?! First thing I notice when I look at the pic is that it would be ONE MORE challenge for me to lock up. It looks like I might could run a chain through the plastic handle, but that's about it in terms of easy and direct measures. Why can't they bury a friggin' big steel eye-bolt in it or something? Gosh...
Old 05-26-2016, 07:16 AM   #25
Can't mount a Honda underneath the van. The Hondas are too tall and would reduce the Interstate's already low ground clearance. If you want to use a Honda in place of the Onan you'd have to carry it on a hitch-mounted tray, or if you have the propane conversion carry it inside.
WBCCI #1105
TAC LA-4
Old 05-26-2016, 09:49 PM   #26
Sebastopol , California
Interblog, check out the Honda website as they make a few different "theft deterrent" devices for their generators. We've resigned ourselves to the Onan as I don't want to add a rear tray and a Honda can not be practically mounted below as Protagonist pointed out. We try and use our Onan exclusively to charge the battery when boondocking on days when we can be outside and away from the noise. We're fortunate to live close to the Pacific ocean where we rarely need to run the AC. My son has a Honda portable and I must say I admire how quiet it is.
Sebtown is offline   Reply With Quote
Old 06-04-2016, 02:01 AM   #27
1997 21' Excella
Murray , Utah
I just wanted to say something about the CAT Scale portion of your post. A vehicle weigh-in is a great idea for ANY Airstream owner. I will go through the specifics on how to quickly accomplish this at any CAT or (really) any other scale house that is available to you. You do not need to set up an iPhone or other way of payment, when using the following instructions.
At the scale:
• Get in-line with the other vehicles waiting (on the ‘IN’ end)
o The sign over the scale will show which end is the ‘Exit’
• Drive squarely onto the scale, keeping all tires on the platform
o The inside portion of the scale framed with the steel edges
• Go forward until your window is close to the CAT Scale sign post
o There will be a speaker box or phone on this post
• At this point you should quickly look (using your mirrors) to see that:
o ALL the tow-vehicle tires are fully on the first and/or second platform; and,
o ALL your Airstream trailer axle tires are on the next platform.
• Push the button (or pick up the receiver) and it will start ‘ringing’
• When the person on the other end speaks they will say:
o ‘First Weigh or Reweigh’?
• Answer this question by saying ‘First Weigh’
o ‘Company’?
• Answer with your last name
o ‘Vehicle Number’ or ‘Trailer Number’?
• Answer this with ‘999’ or whatever you like.
This requested ‘number’ is used by enforcement agencies to ensure that the CAT scale ticket presented is for the same tractor-trailer equipment the trucker he has stopped is driving. This ‘number’ does not need to be accurately shown on your CAT ticket, because you are not a commercial vehicle (CMV) and therefore usually not subject to Federal Bridge axle-weight or roadway capacity carry limits. You will never be asked to produce a Certified Scale weigh ticket, as this is information only you will find useful. The Maximum weight found on the registration paperwork for the tow-vehicle and trailer, will be used if necessary, for all computations (if any are required) for enforcement purposes.
Having these three pieces of information, the person operates the scale taking the weights from each of the platforms (if you are not fully on the platform, the weight is not accurate). This all takes about 10 seconds and then they will say, over the speaker (or phone) that they have ‘your weight’ and come on in to the fuel-desk or scale masters desk (usually it is the fuel desk).
At the Fuel desk:
• Say you have ‘scale ticket’ for ‘your last name or whatever you said’
The desk person will sign and then present you the shown ‘yellow’ CAT scale ticket, charging you the ‘first weigh’ price. Your Cash or Credit is gratefully accepted (most likely with a smile).
A reweigh (hence the question ‘first or reweigh’, when you were on the scale) is available because large semi-trucks have to generally move the trailer-tandems (the trailer axles) to shift the weight of the vehicle (forward or back) to equalize the weight carried on each axle set. This balancing act may take several ‘attempts’ before this is correctly accomplished, hence the re-weigh provision. This re-weigh may be free for ‘x’ attempts, but it is (almost) always at a price lower than a ‘first weigh’. This re-weigh must be attempted within a specified time frame (usually 24 hours, after the first weight ticket is presented).
If this pass is a subsequent weigh attempt:
• To the Question (once you on the scale and on the speaker or phone), “First or Re-Weigh?”
o Answer: “Reweigh”
• They will ask for ‘Ticket Number’ or ‘Weigh Number?’
o Answer (on a CAT Scale Ticket) is the number found in the lower LEFT corner of the previous ticket you received.
Once they have that number, the scale system again fills in the blanks, weighs the equipment, and they will then say come on in and bring money.
The weight on any vehicle axle, side-to-side, is not considered for valid for legal or for ANY other enforcement compliance review, because of the following reasons. The concern I have is that there is NO reason to attempt to weigh the vehicle side-to-side. What you have described is just dangerous.
If you have ever visited any of the many Facebook pages devoted to commercial trucking (or just browsed YouTube) there are innumerable examples of professional drivers ‘missing the scales’ and destroying their equipment by rolling those vehicles and attached trailers over. I will just call your side weight scale ‘technique’ lucky (being generous). The ‘Sprinter’ frame shown in the on-line pictures of the Airstream Interstate 22 foot vehicle was designed by MB/Chrysler to equalize the weight of the vehicle across the footprint. No matter how the weight is distributed, that being front to back or side-to-side, the overall weight of the vehicle, trailer or the entire combination, it is always, the ‘total weight of the vehicle’.
The ‘name plate’ or ‘manual’ GVWR is calculated by ‘vehicles’ manufacturer (using their engineering calculations) in compliance and guided by Federal Regulations.
Federal safety standards are regulations written in terms of minimum safety performance requirements for motor vehicles or items of motor vehicle equipment. These requirements are specified in such a manner "that the public is protected against unreasonable risk of crashes occurring as a result of the design, construction, or performance of motor vehicles and is also protected against unreasonable risk of death or injury in the event crashes do occur." See: Title 49 CFR Part 571 Et al.
This total ‘vehicle’ gross weight rating (GVWR) is based on:
1) The maximum weight bearing capability of the vehicle frame;
2) The weight bearing capability of the springs and other suspension components, per axle set (meaning across the entire axle); and,
3) When using the recommended tire sizes and load ranges on the manufacturer’s supplied wheels (this includes the proper inflation pressure as shown on the side-wall by the tire manufacturer).
It is assumed (per Regulation) that the vehicle will not be excessively ‘side’ loaded, which would enhance the possibility of roll-over. The design of the suspension is to prevent such side-load conditions (to the extent possible) and equalize the total weight to be carried center-line (middle) of the entire axle set. To an extent this GVWR calculation also provides some (10% or so) ‘side-load’ safety margin in case of suspension component failure. This margin provides for the safe stopping of the vehicle before a roll-over moment develops and any subsequent events are avoided. This does not mean you can exceed the GVWR to any great extent, without damage to the vehicle and the associated suspension components. Do so and you are just asking for trouble (and it gets very expensive, quickly).
bchali is offline   Reply With Quote
Old 06-04-2016, 07:36 AM   #28
Originally Posted by bchali View Post
[FONT="Arial"]...
...The concern I have is that there is NO reason to attempt to weigh the vehicle side-to-side. What you have described is just dangerous.
Welcome to Air Forums. That was quite an elaborate inaugural post.
The Interstate's mass is so incredibly much lower than everything else that pulls onto those scales that we didn't worry about what you describe. Plus the scale was new and built robustly like [a vernacular term that the mods would not allow me to use on this Forum].
The reason we did this is that we're designing a swing-away arm for a hitch carrier. In contrast to most other devices on the market, this carrier will attach on the driver's side rather than at the hitch receiver which is in the middle of the vehicle. We are not talking about a boat-load of mass, but my husband was concerned about the possibility of unequal side loading. Shouldn't be a problem with a small added mass, but if we didn't confirm how the vehicle was balanced to begin with, there was the outside possibility that we could exacerbate an imbalance that was imparted by Airstream, if one had been imparted.
To my knowledge, this subject had never been discussed on Air Forums nor anywhere else, and so we were completely without knowledge. The T1N Interstate is already close to GVWR in its empty as-built config, so any weight that is added should be evaluated from all possible perspectives. And of course in being two feet taller than it is wide, it's got stability issues even at the best of times. My husband is a mechanical engineer, and any design element that CAN be reality-checked WILL be reality-checked, even if the possibility of problem is small.
Anyway, that's the reason why we did what we did. It did not cause any problems for the scale owner, and did not reveal any issues worth worrying about with respect to balance.
Gross weight for a 1975 tradewind CMSmith Our Community 2 10-29-2012 07:59 AM
1980 Excella (31 Ft) Gross Weight/Tongue weight? jnichols 1981 - 1983 Excella 9 07-23-2011 01:54 PM
Finding the gross weight of my '57 FC Airstream slcdogtown 1956 - 1959 Flying Cloud 1 11-19-2005 12:20 PM
What's my GVWR rating? Janets Husband Axles 5 04-30-2004 09:01 PM
gross combined vehicle rating for 1985 - 325 rdm Mechanics Corner - Engines, Transmission & More... 1 10-16-2002 07:01 AM
