Old 04-08-2013, 06:49 PM   #1
2012 Interstate Coach
Front Royal , Virginia
Gray Water Valve
My first BIG problem!!!!!
I dumped my gray water tank and it is stuck in the open position and the red light on the valve switch stays on.
I tried to find the manual overide to close the valve but I can't find it.
HELP!!!!!!!!
SGT DAVE
SGT DAVE is offline   Reply With Quote
Old 04-08-2013, 07:37 PM   #2
rel
2011 Interstate Coach
Garrison , North Dakota
First time I used dumped my gay water had the same problem... Op of switch open valve bottom closes it... Hope you have the same difficulty I did...
rel is offline   Reply With Quote
Old 04-08-2013, 08:29 PM   #3
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
HELP!!!!!!!!
SGT DAVE
Does it "try" to close when you push on the switch? i.e. do you hear any sound of the mechanism trying to close the valve? If not, maybe you have a blown fuse?
In my Interstate manual, the manual override feature for the dump valves is shown on page G-16.
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 04-09-2013, 10:19 AM   #4
Figment of My Imagination
Protagonist's Avatar
My 2012 manual has the same info, so it apparently hasn't changed. Fair warning, you'll have to crawl up under the Interstate to do the manual override. You'll want to drive the front end up onto leveling blocks to get more clearance underneath. That's safer than using a jack.
Side note, thanks to the macerator pump and the ball valve on the end of the discharge hose, it does no particular harm for the valve to be stuck upen for a while, as long as you don't add anything to the gray tank until it's fixed. Just a small drain on your house batteries for that LED light on the switch, which should go out when you turn off the battery disconnect. It would be much more worrisome if you discharged through a slinky.
Old 05-19-2013, 12:01 PM   #5
Well the gray water valve now works!
I had to have the valve motor replaced at 400 dollars.
SGT DAVE
Old 05-19-2013, 07:11 PM   #6
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
Ouch! -- a pricey fix.
- - Mike
Boxster1971 is offline   Reply With Quote
Old 05-23-2013, 07:58 PM   #7
ben322's Avatar
2009 Interstate
Bethesda , Maryland
I just replaced the black tank valve which failed last fall so I opened it manually. It's actually an easy replacement taking only about 1/2 hour. The exact replacement part is $85+ shipping direct from drainmaster. Products | Drain Master
2009 Airstream Interstate
ben322 is offline   Reply With Quote
Old 05-26-2013, 11:59 AM   #8
Tulsa , Oklahoma
SGT DAVE
Should it have been covered by the warranty?
Road Jager
Road Jager
Living On Tulsa Time
RoadJager is offline   Reply With Quote
Old 05-27-2013, 09:47 AM   #9
I bought my 2012 used. But I did purchase an extended care program. My total cost was the 50 dollar deductible.
SGT DAVE
Old 05-28-2013, 09:38 PM   #10
73shark's Avatar
Overland Park , Kansas
I bought mine used and the 3/36 warranty is still good for me.
Checked into an extended warranty and all I could find was for about $3,500 to $6,000. Too steep for me. What did yours cost?
Glass half full or half empty to an engineer is the glass is twice as big as it needs to be.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
73shark is offline   Reply With Quote
