Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 05-26-2019, 07:10 PM   #1
Lady Lake , Florida
Gray Water Drain Valve
Gray water valve will not open with the switch. I can hear the motor run, but no water. The instructions in the manual are of little help. Does anyone have experience opening the valve manually? Thanks in advance!!
M and R is offline   Reply With Quote
Old 05-26-2019, 08:01 PM   #2
2013 Interstate Coach
Waterloo , Iowa
I went on line to find instructions for disconnecting the knife valve from the rod coming out of the motor. A rack and pinion setupI think. Send me a PM with your e-mail if you can't find something on-line, and I'll go out to Titus and find my paper copy and scan it and send it to you. An open end wrench and an allen wrench if I remember correctly.
Titus is offline   Reply With Quote
Old 05-26-2019, 08:17 PM   #3
Lady Lake , Florida
Found a post by Boxter1971 from 2015 He had a pdf link to the Barker schematic. I will try again. Thanks for the help.
Old 05-27-2019, 04:25 AM   #4
Auburn , Georgia
The hose could have a kink in it, let it all the way out and check for a flat spot.
GETRIDAONE is offline   Reply With Quote
Old 05-27-2019, 06:58 AM   #5
Waterloo , Iowa
Try emptying the black tank to be sure that the problem is really in the gray tank valve and not elsewhere.
Old 05-27-2019, 08:41 AM   #6
Lady Lake , Florida
Black dumps ok so hose is ok too.
Can you urinate in shower with gray water drain open? JoePaCO Full-Timing 65 08-21-2014 12:02 PM
Gray Water Tank Slow Drain extiger Waste Systems, Tanks & Totes 14 05-11-2010 09:17 AM
