Old 06-21-2014, 08:52 AM   #1
2014 Interstate Ext. Coach
melrose , Massachusetts
gray water backup
had a kitchen sink backup taht was solved by emptying gray water tank but i have a question on how the drains are connected since the bathroom sink nor the floor drain backed up and both are lower than kitchen sink
jennian is offline   Reply With Quote
Old 06-21-2014, 12:42 PM   #2
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
HEPVO valve
All drains have a HEPVO valve instead of the conventional goose neck trap. So my guess is as you tried to drain a sink water it filled the pipes and would not drain. The HEPVO valves in shower and bath sink prevented a backup in those areas.
Hepvo Waterless Valve
- - Mike
Old 06-21-2014, 12:59 PM   #3
question solved
As a newbie this forum is a great resource
Old 06-21-2014, 03:07 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Wish I'd have known about this before. We don't need to pour RV antifreeze down each drain when winterizing to displace water in a p-trap, just down one drain to get enough antifreeze into the gray tank to protect the seal on the dump valve.
The forums are a great resource for not-so-newbies, too!
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is online now   Reply With Quote
Black Water/Gray Water TimeOut Plumbing - Systems & Fixtures 13 10-18-2015 07:00 AM
Shower water and the Gray Water Tank MIKO92 All Argosy Trailers 16 07-22-2014 12:53 AM
Black water backup in shower or not 67' Caravel 1967-Caravel Waste Systems, Tanks & Totes 12 03-24-2009 10:27 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
Dual Gray Water & Dual Black Water? nvestysly Waste Systems, Tanks & Totes 5 05-09-2003 05:40 AM
