Old 01-30-2019, 08:41 PM   #1
Rig Rat's Avatar
2015 Interstate Ext. Coach
Columbus , Ohio
GPS Antennae Boot Deterioration
Have any of you replaced the rubber boot that the GPS antenna and housing sets on?
If so, is this a DIY project and do you have to take the headliner off the inside to access / loosen the antenna and mount?
Mine is quite deteriorated and I want to replace it.
Mark
ID:	332659   Click image for larger version
Adventure before Dementia!
Rig Rat is offline   Reply With Quote
Old 01-30-2019, 10:37 PM   #2
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
Mark
RIGRAT - fyi, that's not the GPS, that's the MB OEM radio antenna. I don't understand how such a young unit will deteriorate that fast. Be that as it may -
Remove the lens for the right side dome light, sorry don't have a good pic on file and I am not home to go inside AI. Use a nylon flat tool like ones used for trim removal. It easily pops out. Should expose a small portion of the 2 metal tabs that hold entire dome light assembly in place. Press tabs and pull down entire assembly. You will see the nut and other washers holding the antenna. Take note of the sequences of parts so re-installing will be proper. If you do not disconnect any cables connected to dome light (which I did in pic due to re-wire I did), you should be able to just let dome light hang by it's cables. It pretty light, not gonna hurt the cables.
Alex AVI is offline   Reply With Quote
Old 01-31-2019, 05:31 AM   #3
This is also a T1N Interstate issue that every owner should pay attention to. I will have an upcoming project to replace at least one of ours. It's on my spring "to do" list.
IIRC, Maggie had a rust issue develop on her old rig at the site of one of those antennae. This kind of deterioration needs to be taken seriously.
Old 01-31-2019, 05:24 PM   #4
Rig Rat's Avatar
Columbus , Ohio
Thanks Alex for the tutorial on how to access the OEM radio antenna boot!
Weíre wintering in the desert SW but did encounter an overnight rain two weeks ago. We awoke to a steady drip of water coming out of the right side dome light. So when the rain ended, I went looking for the source and saw the cracked boot.
I donít know if Iíll attempt the repair while on the road or wait until we get back to Ohio. In the meantime with rain forecasted for this weekend, Iíve put some silicone around it as a temporary fix.
I too wonder why our boot went to heck in less than 4 years, but as interblog states, it would be prudent to check it periodically!
Old 01-31-2019, 05:48 PM   #5
2007 22' International CCD
The joys of solar exposure
Anything made out of a plastic or rubber polymer material will RAPIDLY deteriorate in the SW Desert sun--the Ultraviolet light levels out here are extraordinarily high and rapidly de-polymerize these materials...add in the ozone and just plain strong sunlight, and stuff falls apart fast. My tire covers lasted just three years before they started shedding chunks of the vinyl covering over the fabric.
Doesn't surprise me one bit it only lasted 4 years or so...when you replace it, try painting it with a good grade of spray paint that does not contain metallic particles. It may slow down the deterioration...a little bit.
The air conditioner shroud is another good thing to paint the same way.
1955 Safari Floor Rot and Frame Deterioration. 5455gypsy Repairing/Replacing Floor &/or Frame 3 04-23-2013 07:58 AM
Rand McNally GPS Rand McNally TripMaker RVND 7710 7-Inch GPS adonh Computers, Internet & Satellite 5 03-26-2013 09:39 AM
Plastic Bedroom Roof Vent Deterioration 2dabeach Roof Vents, Skylights & Fans 29 07-08-2010 03:38 PM
Exterior Deterioration? robbp Clearcoat, Exterior Paint & Trim 2 08-24-2003 08:21 PM
To GPS or not to GPS? autoist Airstream Motorhome Forums 8 02-27-2003 09:03 AM
