Old 01-17-2013, 06:46 PM   #1
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Glow plugs
Read the manual and haven't found how low the temp. has to be before they come on before starting. Check the other morning at +13*F and and they didn't come on. Dealer doesn't know.
Not really much of a problem since don't usually drive it in the winter but would like to know if they're functional.
Anybody know?
Old 01-17-2013, 06:51 PM   #2
gaylejoe's Avatar
2007 25' Safari FB SE
St. Hedwig , Texas
I don't know what you are driving but if it's a Cummings they do not have glow plugs.
gaylejoe is offline   Reply With Quote
Old 01-17-2013, 07:10 PM   #3
Prairie Schooner II
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
You may or may not have a problem. If the diesel is starting ok at 13 degrees f it would seem that the glow plugs are operational but the glow plug indicator light is malfunctioning. If the engine is starting hard, the plugs may not be working and the glow plug light is not working. When the glow plugs are not working, the check engine light normally comes on. Now, if the interstate is not normally equipped with a glow plug interstate light, and the thing is starting ok, don't worry, be happy. The fix for the glow plug light, or the fix for the glow plugs is ridiculously expensive. But don't worry, the dealer most likely wont have a clue how to fix any of this stuff.
Jim Flower is offline   Reply With Quote
Old 01-17-2013, 08:10 PM   #4
robert claus's Avatar
2000 19' Bambi
mt. Prospect , Illinois
I believe the glowplugs in the Mercedes Sprinter will come on anytime the coolant is cold, but they stay on longer to reach the spec temp the colder it is. The little electric coil warning light comes on and stays on until the right temp is reached. When it goes out, you start the engine. The colder it is, the longer that seems to take. If you are not getting the yellow coil light, the glowplug module may be malfunctioning. If you have a Scangauge, you will get the codes (the Scangauge II is great to have-instant mpg readings, as well as other functions). If you are having glowplug issues, you'd be getting a check engine light. For Sprinter mechanical issues, a good site is
sprintervan : Sprinter Van Mercedes Freightliner Dodge
robert claus is offline   Reply With Quote
Old 01-18-2013, 04:41 AM   #5
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Anybody know?
If you had any sort if problem with the glow plugs or the module that controls them, you would get a CEL indication. Interesting question though. My guess is that they come on if the engine is not at operating temp and stay on longer at colder temps.
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 01-18-2013, 07:04 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
In my Interstate, the glow plug idiot light comes on every time I turn the key to the "Run" position before starting. If the temperaturew is warm enough, the light goes out again right away; if it's cold, the light stays on longer. I never turn the key to the "Start" position until the glow plug idiot light goes out.
If the glow plug idiot light never comes on, and there's no Check Engine light, then my best guess is this…
According to my 2011 Sprinter Owner's Manual, there is a "prefuse" panel inside the battery box in the driver's footwell. Fuse #1 (actually relay module #1) on this panel is "preglow relay/secondary air pump", rated 80/40 amps.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-18-2013, 10:56 AM   #7
1988 32' Excella
Robbinsville , New Jersey
Same with my '91 Mercedes turn the key to run, light comes on even at 97F with warm engine (even if it goes off immediately). Stays on longer the colder the engine is.
Old 01-18-2013, 11:04 AM   #8
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
We fire the glow plugs for 30 seconds when the temp is below 40 degrees. We do have a manual push-button switch with an indicator light. Unless the glow plugs are activated, she'll smoke like mad.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 01-18-2013, 11:05 AM   #9
Yep. That's why I didn't spring for the remote-start module that went with my aftermarket Viper alarm system. A remote-starter doesn't know how long to let the glow plugs do their things before starting the vehicle.
WBCCI #1105
TAC LA-4
Old 01-18-2013, 04:11 PM   #10
73shark's Avatar
OK, the "Glow plug" lite comes on when key is turned to "Run" position but goes out w/ all of the rest of the lites after the test is complete. The way I read the manual, it would stay on if the glow plugs were energized and go out when they were turned off. So I'm guessing that either it has to be colder than 13*F to come on or something is wrong but doesn't set the CEL.
Protagonist: Since yours are apparently coming on, what temp. is outside when they do?
Old 01-18-2013, 05:27 PM   #11
1988 32' Excella
The way I read the manual, it would stay on if the glow plugs were energized and go out when they were turned off. nce yours are apparently coming on, what temp. is outside when they do?
That part sounds weird to me, might have changed with the new Mercedes though.
On my car when the engine is cold the light comes on for 5-15 seconds.
According to the service manual the glow plugs come on for 2 minutes 30 seconds, until it starts or the key is turned off.
They do NOT shut off with the light.
The light turns off when the resistance of the glow plugs gets to a certain point which indicates the glow plugs got up to an average of the minimum temperature needed for the engine to fire.
Old 01-18-2013, 07:40 PM   #12
2000 19' Bambi
It has nothing to do with outside temp, only coolant temp. They only function for starting.
Old 01-19-2013, 03:35 AM   #13
I'm not the glow plug expert. What you say sounds right, and I'm certainly not going to dispute it. I will file it away for future reference in the vast empty cavern that was once my mind.
Point of the whole thing is, if everything is working as it should the glow plug idiot light comes on every time you first turn the key to the "run" position regardless of outside temperature or engine temperature, and you should not turn the key to "start" until the glow plug idiot light goes out, indicating the cylinders are warm enough, whether that's one second later or over a minute later.
I still believe that the most likely culprit for 73shark's problem is the "preglow" relay in the battery box under the driver's footwell. A malfunctioning or nonfunctioning relay would certainly explain the symptoms he reported.
WBCCI #1105
TAC LA-4
Old 01-19-2013, 09:56 AM   #14
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
I'm still not sure 73shark has a problem. Assuming your 201? model year sprinter works like mine......
  • Pre-glow light comes ON when you turn the switch to the RUN position
  • Pre-glow light turns OFF when the glow plugs are up to temp. The ON time is a function of engine temperature. On my 2008 MY Sprinter the light turns off quite quickly if the engine is warm.
  • If there is a failure in the glow plug system the Pre-glow light will remain ON.
With all the computerization going on in this vehicle I would be absolutely stunned if you had a failure in the glow plug system and weren't notified via either a CEL or the Pre-glow light remaining ON. This vehicle has so many sensors and computer modules that it can tell me if I have heartburn.
- wayne
AIR #44779
TAC AK-1 !!
