Old 12-09-2014, 08:39 PM   #15
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I'll have to recheck mine but I believe it has a foam filter on the end of the hose. I always wondered what it was for.
Old 07-26-2016, 07:06 PM   #16
2005 22' Interstate
N. Hollywood , California
Just had this problem of not starting I found this thread and inserted a metal tent peg into the vent pipe I saw some spider webbing on the end of the peg when it came out of the vent hose and the generator started first attempt .
This is a great site that has helped me solve a few problems with my van .
Colin
mrcolin2u is offline   Reply With Quote
Old 08-04-2016, 12:27 PM   #17
solar-guy's Avatar
2009 22' Interstate
Covington , Louisiana
Starting problem on Onan 2500 solved
Thank you Thank you Thank you !! The generator on my 2008 Interstate quit a couple of weeks ago and your tip on the plugged vent hose solved my problem in about 1 minute... The mud wasps had plugged the vent, when I cleaned out the mud the generator started instantly! I need to read more of the thread to confirm what that vent actually does.
thanks again!!
solar-guy is offline   Reply With Quote
Old 10-02-2016, 07:22 PM   #18
Evansville , Indiana
thanks again!!
Avanti,
Count me among the grateful folks that found your solution to the "Onan genset cranking but not starting" issue!! Looked under the bus and the vent hose was plugged by a mud dauber just like you described. Thanks!!
BurntAsphalt is offline   Reply With Quote
Generator won't start nancyo Sprinter and B-van Forum 13 07-30-2014 04:51 PM
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 08:47 PM
Generator won't start arifarda Generators & Solar Power 3 09-14-2012 01:38 AM
Generator won't start! Lily&Me Generators & Solar Power 14 09-11-2012 06:23 AM
2000 diesel pusher 35xc generator won't start from inside dhshipley Generators & Solar Power 0 09-18-2009 12:21 AM
