Old 07-28-2014, 06:41 PM   #1
2013 Interstate Coach
Virginia Beach , Virginia
Generator won't start
Went to start my generator and it is completely dead, when I hit start button after priming it, nothing happens, doesn't even make a noise.it has worked like a dream until now. Any suggestions would be appreciated.
I have 2012 airstream sprinter.
Thanks in advance
nancyo is offline   Reply With Quote
Old 07-28-2014, 06:53 PM   #2
Gainesville , Florida
Dead battery. Try starting up the van and then try the genny. Jim
Old 07-28-2014, 07:53 PM   #3
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Put a piece of black tape over the "Prime" label as that is for gas powered generators. It has no function on the propane generators.
Make sure your 12 V Master Switch is ON.
Old 07-29-2014, 04:40 AM   #4
Lily&Me's Avatar
Normal , Illinois
Make sure your propane is turned on.
We almost always have to turn on the ignition to get the generator to start.
Maggie
Lily&Me is online now   Reply With Quote
Old 07-29-2014, 05:11 AM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Possibilities include:
1 - house battery disconnect is off, in which case no power to the starter motor (even if batteries were low, you'd at least hear the click-click-click of the Bendix trying to engage the starter)
2 - low on oil, because there is an internal disconnect that prevents the generator from running (note that if you're not parked reasonably level that can trigger the low-oil disconnect as well). Onan generators tend to use oil when new; it's not uncommon to need to add oil in less than 25 hours of run time, but after they're properly broken in the excessive oil usage should stop.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-29-2014, 10:40 AM   #6
Where would I find the house battery disconnect switch? I am clueless, if you haven't already guessed
Thanks again
Old 07-29-2014, 01:19 PM   #7
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
The disconnect switch is actually a remote switch and its located on the wall behind the folding arm of the curb-side second row passenger seat.
If things are working fine, when the switch is in the on position, your coach electrics (lights, etc) should come on. That is assuming your coach batteries are not flat.
Old 07-29-2014, 02:52 PM   #8
My model isn't old enough to have that, but if memory serves the remote switch on the newer models just turns the big red switch under the sofa, which is still there even on yours.
WBCCI #1105
TAC LA-4
Old 07-29-2014, 04:53 PM   #9
David M's Avatar
Orange County , California
Nancy has a 2012 so the switch is under the rear lounge seat, not by the 2nd row passenger seat.
David M is offline   Reply With Quote
Old 07-29-2014, 05:57 PM   #10
Could it have been the inverter switch?
I have been messing around , and it finally started ......thanks for all the responses .......this forum is the bomb
Old 07-29-2014, 06:30 PM   #11
Lily&Me's Avatar
Normal , Illinois
It's all about the learning curve.
Maggie
Old 07-29-2014, 08:23 PM   #12
73shark's Avatar
Unless the house batteries were down, the inverter being on shouldn't affect the starting on of the generator. Just need the 12 VDC on to get the propane valve to open and the starter to work.
Glad you got it going.
Old 07-30-2014, 01:01 PM   #13
Anacortes , Washington
I have an 07 Interstate which has the propane powered Onan genset.
For an unknown reason and at random time intervals the 5 amp fuse in the generator starter circuit goes bad and so the symptoms are nothing at all happens when you push the start button. Crawl underneath and open the access panel and the 5 amp fuse is located to the right of the (other) start/stop switch located there. Hard to see but after a while one gets good at feeling for it. Change the fuse and all works normally -- that is until the next time.
I had the local Camping World look at it (at enormous expense) -- they checked everything -- even the draw amperage in the starting circuit while cranking -- it was 3.2 amps -- Several hundred dollars later I got it back and within a week the fuse had to be changed again -- Still unresolved -- If anyone has any answers to this would appreciate them. I keep a bunch of 5 amp fuses in the glove compartment and have got very good at changing out the burned fuse. Last time though when it needed changing it had lasted at least 6 months. Go figure?
Interstate20 is offline   Reply With Quote
Old 07-30-2014, 03:51 PM   #14
BikerBill
Poconos of Pa , Pennsylvania
If these are the old glass fuses with the silver ends, they used to make a heavy duty, slow-blow version. If they are the more modern automotive fuses I don't know if they make a heavy duty or slow blow version. You might check at an automotive store to see if they do. I'm wondering if there is a draw that is too close to the 5 amps, once in a while.
Now that doesn't solve the problem of WHY but its a start.
Bikerbill is offline   Reply With Quote
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 07:47 PM
Generator won't start arifarda Generators & Solar Power 3 09-14-2012 12:38 AM
Generator won't start! Lily&Me Generators & Solar Power 14 09-11-2012 05:23 AM
2000 diesel pusher 35xc generator won't start from inside dhshipley Generators & Solar Power 0 09-17-2009 11:21 PM
Help!! Engine Won't Start!! eraffety Mechanics Corner - Engines, Transmission & More... 41 07-05-2006 07:01 PM
