Old 06-27-2013, 04:01 PM   #1
Billshop's Avatar
2013 Interstate Coach
Fairport , New York
Generator noise
A comment in another thread prompts me to ask about generator noise. My generator seems to be very noisy. Onan claims it is the quietest in its category, but it seems quite loud ---quite a bit louder than the quiet diesel I had previously.. The muffler and connections all are tight, but I would hate to run this thing in a crowded campsite even if quiet hours are not in effect. Am I expecting too much, or do others also find their generator to be noisy?
Billshop is offline   Reply With Quote
Old 06-27-2013, 05:12 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Loud from inside, or loud from outside? My generator sounds louder from inside the RV than it does from outside, due to the fact that the generator is tucked up underneath and all the sound that doesn't get out the sides goes up through the floor.
From outside, my generator is about the same decibels as the 3.0-liter diesel engine when the engine's idling, and quieter than the rooftop air conditioner.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-27-2013, 05:32 PM   #3
Steve Bryant's Avatar
1991 34' Limited
Wichita , Kansas
Billshop,
1. What steps have you taken to try to objectively quantify/evaluate the noise produced by your generator?
2. What kind of RV was the quiet diesel generator you're describing installed in.
3. Are there differences in how the generator is installed between the two RVs?
Steve
Steve Bryant is offline   Reply With Quote
Old 06-27-2013, 07:13 PM   #4
norman , Oklahoma
From outside I find the generator to be way louder than the Sprinter's engine or A/C unit. Inside the A/C unit is louder than the generator. I think that's just the way it is. (Hence the Honda EU3000iS I mentioned in what I believe was the other thread you referenced.) I started a thread a while back about making the Onan quieter. http://www.airforums.com/forums/f240...ter-94379.html
I never followed through with the muffler experiment I mentioned there, but if you venture in that direction I'd love to "hear" your results. Good luck!
russ240 is offline   Reply With Quote
Old 06-27-2013, 08:13 PM   #5
1991 34' Limited
Wichita , Kansas
russ240,
Your linked thread has some interesting information and is worth the read for anyone.
Steve
Old 06-28-2013, 03:30 AM   #6
Odd that we have exactly opposite perceptions. But then again, all sound-producing equipment has a "peak" frequency. The generator, air conditioner, and engine all have different peak frequencies, and it's possible that your hearing is more sensitive at the generator's peak frequency than my hearing is. I do have some work-related hearing loss, but not enough to qualify as a disability. My hearing is more sensitive at the air conditioner's peak frequency.
Because of hearing sensitivity, we could both listen to exactly the same unit and have different perceptions of the noise level.
WBCCI #1105
TAC LA-4
Old 06-28-2013, 05:17 AM   #7
Billshop's Avatar
Fairport , New York
I can hear my generator across the parking lot. .It certainly is louder than the engine and/or the air conditioner when outside. When inside, the air conditioner is louder. The diesel generator I mentioned as comparison was a 10kw on a 43foot class A, and I certainly don't expect the smaller Onan to be as quiet as that. But nevertheless it seems it should not be that much nosier.
The noise seems to be more of a rattle than normal exhaust .
I think my next step would be to ask an Onan dealer to determine if my noisy generator is within the specs that Onan states. Thanks for the info. It was helpful to get the different views, and the link to prior discussions was most helpful..... Thanks all
Old 06-28-2013, 05:19 AM   #8
Billshop's Avatar
Fairport , New York
BTW... I have a significant hearing loss, so even normal conversations are difficult for me to hear.
Old 06-28-2013, 05:42 AM   #9
The noise seems to be more of a rattle than normal exhaust.
Unless something is loose, it shouldn't rattle at all. Last time you checked the oil, did you get the enclosure door shut tight? If the enclosure door is open, the generator will sound louder, and the door will rattle.
WBCCI #1105
TAC LA-4
Old 06-28-2013, 06:13 AM   #10
David M's Avatar
Orange County , California
My generator has been very noisy since new (Apr 2013) as well. My wife says it shakes the house when I run it while parked in the driveway. A month ago (May 2013), the exhaust pipe fell (shook) off the generator while parked in a parking lot, and the generator was just as loud without the pipe/muffler as with it on! I had the oil level checked while I had the AS back at the dealer and it was ok. So I'm thinking that the generator just needs a good muffler.
David M is offline   Reply With Quote
Old 06-28-2013, 10:16 AM   #11
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
The heat shield on my generator's exhaust lost a couple of bolts and the vibration noise it created was very loud.
I agree w/ Protagonist's perception re: A/C being louder inside than the generator but may be 70 yr old ears coupled w/ tinnitus. Outside tho, I'd say it's a little louder than the 3.0L diesel @ idle.
Old 06-28-2013, 10:18 AM   #12
Ripple's Avatar
Kaneohe , Hawaii
I have the same problem. Had the experience this morning with other RVs are around with either quiet built in gennys and the portable quiet Hondas and Yamahas. I had it on for 2 minutes to charge the inadequate batteries (longer story) and had to turn it off and start the engine because I was embarrassed from the noise. They put a straight pipe on the thing. I am going first thing next week to a custom muffler shop and finally take care of this. I'll let you know how it goes.
Ripple is offline   Reply With Quote
Old 06-28-2013, 01:50 PM   #13
David M's Avatar
[QUOTE="Ripple;1319338"They put a straight pipe on the thing. I am going first thing next week to a custom muffler shop and finally take care of this. I'll let you know how it goes.[/QUOTE]
So I just went to a muffler shop, and they told me that as far as generators go that can run AC, it is on the quiet side and that it's not going to be any quieter by adding a muffler. I'm not too sure if this is entirely correct so I'm looking forward to what other shops tell you.
Old 06-28-2013, 02:38 PM   #14
1991 34' Limited
Wichita , Kansas
What generator is installed on the Interstates? Does anyone have a drawing of the installation of the generator?
Steve
