Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 09-18-2015, 04:16 PM   #1
Generator low oil pressure
Hello again!
We just bought a pre owned 2014 AI and have only run the generator 20 hours thus far. it is an Onan generator. We intended to warm up some food in the microwave real quick and the generator cut off after about 30 seconds and flashed a "low oil pressure" note. Does this mean I must take it to get maintenanced or can I simply add oil to it? If I can add oil myself, what kind and how do I do it? Thanks! Learning as we go I guess!
Hammertime is offline   Reply With Quote
Old 09-18-2015, 05:38 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
The most likely thing is that it's just low on oil. Generators are usually set up so it's easy to check the oil level and add oil yourself if necessary.
I guess the first thing to do would be to find the generator, get the model number, and then search for the owner's manual on Google.
Old 09-18-2015, 07:47 PM   #3
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
You can get the Onan specified (see owner's manual) oil from Amazon. There's a thread here that shows pics of the operation of filling. For just adding a small amount, the oil squirt can should suffice.
I let mine hang out over the end of the driveway which gives a lot of clearance to get to it.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
Old 09-18-2015, 08:32 PM   #4
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Your Onan Generator is due for an oil change at 20 hours and is probably low on oil.
Might try a search as there are quite a few other threads here regarding adding and changing oil.
You didn't per chance have the rooftop AC going when you tried the microwave?
Oil is 30w if you don't plan on using it in freezing temps or 10w40 if you do.
Ron_CA is offline   Reply With Quote
Old 09-21-2015, 05:19 PM   #5
kfrere's Avatar
2008 31' Classic
Lenoir City , Tennessee
Part of this discussion should probably be how to access the generator to even check the oil. My husband crawled under our new unit to check the oil level. It appears that once you have crawled under the unit you have to find the access panel which is next to the spare tire and facing the rear of our unit. Once the panel was off the dip stick could not be pulled out because the spare tire is in the way. Does that mean that the spare has to be dropped every time we want to check the oil level? For us that means a trip to Freightliner because we have neither the tools nor the space to do that with six wheels sitting on the ground.
Kelly & Matt
WBCCI - #4335
2005 Diesel Excursion
2008 31' Custom Classic "Moonshine"
2016 Interstate "BugOut"
kfrere is offline   Reply With Quote
Old 09-21-2015, 06:53 PM   #6
73shark's Avatar
If you can get under to get the panel off, then w/ the spare dropped, it should be easier. I gain about six inches of extra clearance by letting the rear hang out over the street. But I guess the new Onan must be bigger or they relocated the dipstick since I don't have to drop the spare.
Old 09-21-2015, 09:01 PM   #7
Ron_CA's Avatar
Yep, have to drop the spare a little (a few inches should be enough)to let the tire swing out of the way so you can pull the dipstick out. It is good practice anyway.
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
High Pressure vs. Low pressure Appliances emenriquez General Appliance Topics 2 06-15-2009 01:04 AM
1984 345: low oil pressure light and doorbell jdmii Mechanics Corner - Engines, Transmission & More... 1 05-17-2009 02:55 PM
Does the amount of engine oil increase with the addition of a larger oil cooler? Mr. D Mechanics Corner - Engines, Transmission & More... 5 03-07-2009 08:56 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
