Old 08-20-2018, 12:59 PM   #1
1995 19' "B" Van Airstream 190
Lehigh Acres , Louisiana
Generator cutting out
I have a 1995 B190. The generator will start, but only from the outside switch. It runs for 5-10 minutes and dies out. It will not start from the inside switch. Won’t even turn over from inside switch. Won’t start again from outside switch for a good hour after cutting out.
Any suggestions will be greatly appreciated.
BruceLuh is offline   Reply With Quote
Armstrong cutting out during daylight hours tschat Furnaces, Heaters, Fireplaces & Air Conditioning 1 07-05-2014 04:23 PM
Cutting Out Damaged Flooring? Roadrunner Repairing/Replacing Floor &/or Frame 4 11-08-2012 04:57 PM
Water Pump cutting out DaveT Water Heaters, Filters & Pumps 3 02-04-2011 10:41 AM
454 cutting out choctawmel Mechanics Corner - Engines, Transmission & More... 43 03-14-2009 08:40 AM
Generator Cutting Off swebster Mechanics Corner - Engines, Transmission & More... 17 10-27-2005 07:17 PM
