Old 07-27-2016, 05:30 PM   #1
2017 Interstate Lounge Ext
- , VT, AZ, CA
Generator Control
Has anyone installed a Cummings Onan Energy Command 30 ("EC-30", not the discontinued wireless EC-30W) or some similar device in a late-model Interstate ? https://power.cummins.com/sites/defa.../900-0541B.pdf
This is an autostart control panel that links to the air conditioner's temperature sensor to power up the generator, and turn it off. Certainly an EC-30 should be compatible with the genset, but I'm wondering whether it plays nicely with the Mini-PCS load manager and the installed air conditioner.
I'm awaiting delivery and new to all this, but if I understand correctly the genset needs to be started and left on if there is no shore power and air conditioning is desired. Especially given the relatively small propane tank and relatively loud generator, an autostart control seems almost essential.
Thank you.
don000 is offline   Reply With Quote
Old 07-27-2016, 06:36 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Thank you.
Seems like it ought to work, provided you also include the optional shore power sensor— you don't want the generator to interrupt 30-amp shore power to start a generator that only provides 20 amps when interior temperatures get out of control.
As an aside— Your post is not the first place I've seen reference to a "relatively small propane tank." Given that the propane tank holds 14 gallons or 60 pounds of propane, I'd hardly call that "small." It's as much as two 30# portable cylinders on a typical Airstream trailer.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-27-2016, 07:03 PM   #3
Jacksonville , Jacksonville, Fla, Sautee, Ga, Boca Grande, Fl, Breckenridge, Co
Protagonist you are correct of course, the tank is very adequate for long term use of the stove and the hot water heater, but not so much for the generator especially under a full load like the AC. The comments about the tank size also relate to the relative inconvenience of refilling compared to a diesel powered gen set. So, yes the tank is relatively large but it seems small based on the frequency of refill, if used to fuel the generator, and the inconvenience of refill compared to diesel.
busb2 is online now   Reply With Quote
Old 07-27-2016, 07:43 PM   #4
That was only a side comment. The main point was the necessity for the optional shore power sensor. Don't want to lose sight of what's important.
WBCCI #1105
TAC LA-4
Old 07-27-2016, 08:36 PM   #5
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
The Onan burns about 1/2 gallon per hour under a heavy load (17-20 amps). One reason Airstream doesn't use a diesel generator is the size for equivalent output is too big. At least that's what they said.
Which is better? A sway control hitch or a vehicle with sway-control? Lucky Strike Tow Vehicles 27 08-13-2015 05:34 AM
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Solar or generator or and generator? badkat Full-Timing 15 11-17-2014 09:59 PM
Does Dodge RAM's Integrated Sway Control Work Well With Friction Sway Control? interstateflyer Towing, Tow Vehicles & Hitches 9 08-13-2014 10:05 AM
Uninstalling the Nutone Mixer Control winner Cabinets, Counter Tops & Furnishings 14 12-06-2010 10:47 PM
