08-20-2015, 03:09 PM
2013 Interstate Coach
Sacramento
Generator
Hello experts!
We have a 2013 extended. We're planning a trip to the South and have a question.
We are taking 18 cases of wine all stacked up in the back of the vehicle. There is going to be one day/night that we are not going to be able to plug into a 30 amp, and naturally we do not want to cook our wine.
I'm pretty sure that the "inverter" should be in the OFF position in order to run the generator. Also, we know that the propane must be ON. Please let me know if this is correct, and also what about the red knob? I don't really know what the other switch does in the main control compartment. It seems to me that something there was labeled inverter also.
We will probably run the generator for 16 to 20 hours that night. Do we have enough propane for that amount of time running the air conditioning?
BTW, we have really not used the generator other than to test it. It only has 3 hours on it.
As always, thanks for your help.
08-20-2015, 04:15 PM
1977 Argosy 24
Milltown
, Wisconsin
What campground are you going to be at, and when are you going to NOT be at the trailer? (I could use 18 cases of wine)
08-20-2015, 05:22 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
No. In the "Line Charge" position, the inverter/charger will charge the house batteries while the generator is running, and that's a good thing. In the "Auto/Invert" position, the inverter/charger will detect the source of charging current and automatically switch itself to charge mode to charge the batteries, and that's a good thing. In the "Off" position you will NOT be able to recharge the batteries with the generator running, and that's a bad thing. So put the inverter/charger in any position EXCEPT "Off."
Propane solenoid must be on, yes. Big red knob is your house battery disconnect. It too must be on, otherwise you will not have power to even start the generator.
Barely. If you start with a full propane tank and haven't used any propane for any other purpose, you should just barely have enough propane to run the A/C for maybe 24 hours, possibly a little less. But since nighttime temperatures are cooler, the A/C should not run continuously during the night unless you set the thermostat down in the 50°F range. Still, figure that you'll run out of propane by morning and have someplace in mind where you can refill the tank.
You really should run the generator about an hour a month to make sure it's in good operating condition. It takes about 25 hours of running just to break it in properly.
Be advised that some Onan generators use excess oil during the break-i period until the piston rings seat themselves properly, so your generator may shut itself down due to low oil if you run it all night. If you're trying to keep your wine cool that could be a bad thing.
I strongly recommend going someplace where you can get several hours of generator run time BEFORE your trip, and run the generator as many hours as you can to help break it in, and then check the oil to make sure it has enough, adding more if necessary— and refill your propane tank afterward as well, of course. If it is critical that you have generator power during your trip, that is the wrong time to break it in; so break it in first.
Finally, a handy hint courtesy of Maggie (who posts under "Lily & Me"). Start the generator while your engine is running. The current from the engine alternator will help to "jump start" the generator if the house batteries are low.
08-20-2015, 05:48 PM
Sacramento
Originally Posted by Protagonist
No. In the "Line Charge" position, the inverter/charger will charge the house batteries while the generator is running, and that's a good thing. In the "Auto/Invert" position, the inverter/charger will detect the source of charging current and automatically switch itself to charge mode to charge the batteries, and that's a good thing. In the "Off" position you will NOT be able to recharge the batteries with the generator running, and that's a bad thing. So put the inverter/charger in any position EXCEPT "Off."Propane solenoid must be on, yes. Big red knob is your house battery disconnect. It too must be on, otherwise you will not have power to even start the generator.Barely. If you start with a full propane tank and haven't used any propane for any other purpose, you should just barely have enough propane to run the A/C for maybe 24 hours, possibly a little less. But since nighttime temperatures are cooler, the A/C should not run continuously during the night unless you set the thermostat down in the 50°F range. Still, figure that you'll run out of propane by morning and have someplace in mind where you can refill the tank.You really should run the generator about an hour a month to make sure it's in good operating condition. It takes about 25 hours of running just to break it in properly.
Wow, Protaganist, you're the best! I really appreciate your wealth of knowledge. Just one more thing...the "line-charge" you're referring to is up in the controls where the generator button is right? I understand that should be in the "line charge" position. What about the switch that's down there with the red knob? I think the choices there are off, auto, and on.
Thanks again,
Laura
08-20-2015, 05:50 PM
Sacramento
Also,
08-20-2015, 05:51 PM
Sacramento
Also, how do you add oil to the generator?
2015 Interstate Ext. Coach
San Diego
Will you be running your generator while driving? Or is that the plan?
The reason I ask is I have done it on numerous occasions and the last time was for 1 1/2 hours. However today when I was finishing up an oil change on my generator I notice that my driver side mudflap was partially melted from the generator exhaust. The mudflaps are not that sturdy and evidently they blow back into the generator exhaust. Looks like a fire hazard to me. Not good.
I am probably going to bolt a metal bracket onto the u-bolt clamp to keep the mudflap from blowing into the exhaust. I don't think the heat transfer from the clamp will be sufficient to burn the flap IDK.
08-20-2015, 05:59 PM
From All Over
All praise is cheerfully accepted!
Inverter/charger controls are a bit confusing on the Interstate.
The switch on the inverter/charger itself has three positions.
1 - Line Charge. This causes the unit to charge the batteries if there is a source of 120vAC power, but won't let it invert.
2 - Off. This shuts the inverter/charger off completely.
3 - Auto/Invert. This actually causes the remote control switch to work. If there was no remote control switch, it would let the unit decide for itself whether to invert or charge. But since there is a remote switch in the overhead locker, it activates the remote switch instead.
The remote switch in the overhead locker has two positions. If— and only if— the switch on the inverter/charger is in "Auto/Invert" position, this switch can be used to control the inverter/charger.
1 - Auto/Invert. The unit monitors whether there is 120vAC power available from an outside source, i.e. shore power or generator. If there is, it charges. If there isn't it inverts. It's automatic.
2 - Line Charge. This position allows the inverter/charger to charge the house batteries if there is 120vAC power available, but does NOT allow it to invert if there is no 120vAC power available.
So to keep things simple, when storing your Interstate, turn the switch on the front of the inverter to "Off". When using your Interstate, always turn that switch to "Auto/Invert" and then use the switch in the overhead locker to control the inverter/charger.
08-20-2015, 06:01 PM
Rockwell
, North Carolina
You have to crawl under the motorhome. There is a panel that you must remove to gain access to the oil fill hole and the dip stick to check the oil. There is enough room to remove that panel without lowering the spare tire. However, adding oil is difficult with the spare tire in place, but not impossible. I use an old fashioned oil can squirter. It is a slow process but the generator only holds one quart of oil. The red piece in the photos below is the dip stick.
By the way, Onan wants the oil changed after 20 hours of operation.
08-20-2015, 06:09 PM
San Diego
Good pics Jerry as always (:
On the 2015 Interstates the oil fill tube and dipstick are at an angle facing out and your pics explain why others have not had to drop the spare but on the 2015s (who knows when the generator changed) you have to.
08-20-2015, 08:30 PM
2011 Interstate Coach
Overland Park
, Kansas
On our trip this summer, I ran the A/C and generator when on the road for three days and got about 26-30 hours on a full tank. Ran out about 40 miles from home and had to stop at a KOA to refill. Interestingly only got about 12.5 gallons in the 18 gallon tank. I think you're supposed to get 80% or 14.4 gallons. But it is was very hot so maybe the 80% is at 70*F.
Never have had any problem w/ the mud flap hitting the exhaust but my flaps don't flex. Maybe the newer ones are different.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
08-20-2015, 08:57 PM
San Diego
Are you sure? They seem pretty well built on the outside but inside are pretty flimsy. I never thought mine was touching either and can't see it without climbing underneath.
08-21-2015, 01:05 PM
Overland Park
, Kansas
My flap hits the heat shield that's clamped to the exhaust pipe. I can see how it would hit the pipe if the shield wasn't there because the inner side of the flap is a lot more flexible than the outer part.
08-21-2015, 01:51 PM
San Diego
Here is a bad, too close pic of mine. You can see it melted the mud flap.
[/URL][/IMG]
08-21-2015, 02:37 PM
Overland Park
, Kansas
Looks like they either forgot the heatshield or it fell off. Mine almost did because both nuts came off the muffler clamp that held it on. Fortunately it made such a racket when it was running that I noticed and replaced them.
08-21-2015, 02:41 PM
Len and Jeanne
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley
, British Columbia
Probably you've checked ahead to ensure that the place where you are staying allows you to run your generator all night. Some parks are fussy about their generator hours.
08-21-2015, 02:56 PM
San Diego
I think they stopped putting them on altogether. I have pics underneath a 2014.5 and there isn't a heat shield.
08-21-2015, 03:14 PM
Overland Park
, Kansas
Obviously one is needed as evidenced by your problem. Wouldn't be too hard to fab one from a small diameter duct pipe. Cut it in half lengthwise and use muffler clamps to attach it to the exhaust pipe.
08-21-2015, 03:43 PM
San Diego
I think I am just going to get an angle bracket and attach it to the generator exhaust clamp and use it to keep from hitting the exhaust.
08-25-2015, 10:33 AM
Sacramento
Originally Posted by jerhofer
Just wanted to let you know how helpful your pictures were. We got our oil changed yesterday and the guy was having trouble dealing with the spare. UNTIL I showed him your pictures! He went and got his oil can and job done! Thanks so much for your help.
Laura
