Old 03-22-2013, 12:52 PM   #15
2012 Interstate Coach
norman , Oklahoma
I finally put the shorter legs on. I think they are the better way to go vs. the longer ones. The shorter ones are about an inch from being fully extended when adjusted to fit the RV but the longer ones were in contact with the ground and required a lot of force to swing through their deployment/retraction arc even in the shortest position. I wish they offered a leg that was half way between the two lengths. I am thinking about switching out two of the casters for fixed wheels with brake locks. This thing is large and unwieldy to roll around with no directional stability, I think it will be better with two wheels that are fixed to a straight ahead position (I would put both of the fixed wheels on the hitch side of the box) and since it wants to take off if there is the slightest incline the brakes will be a good addition as well.
russ240 is offline   Reply With Quote
Old 07-08-2013, 10:23 PM   #16
2013 Interstate Coach
Pics on Cargo 34 Let's Go Aero
Back Look
Telescoping rails and wheel drop downs
Door Clearence
Holds 250 lbs of camping stuff, roll away wheels are heavy duty long and works great. Short roll away wheels would work also.
eliasurbina is offline   Reply With Quote
