Old 05-18-2019, 05:44 PM   #1
sheakev's Avatar
2017 Interstate Grand Tour Ext
Madison , WISCONSIN
Fusion Version 3.80
I checked the Garmin website and found an upgrade. It seems to have fixed the issue of not being able to have your co-pilot use the interface whilst underway.
Not certain that the other updates are material, and I believe it is working since we haven't been denied access to the menu to add a location, etc.
It loaded without incident using the Garmin Express update tool and a thumb drive.
Kevin N9JKP
sheakev is offline   Reply With Quote
Old 05-18-2019, 06:52 PM   #2
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
That is great news!! Thanks!
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 05-19-2019, 09:32 AM   #3
wachuko's Avatar
Orlando , Florida
Thumbs up
Done!
ID:	341102   Click image for larger version
Safe travels!
Wachuko
WBCCI #26769
Old 05-21-2019, 05:36 PM   #4
barrie , Ontario
Originally Posted by wachuko View Post
Done!
Great info. We will try the download soon too. The “ no use while driving” safety feature forced us to drive with an old GPS plugged in so that the passenger could access info while the vehicle was not in park. Fingers crossed that this works for us too.
catjer is offline   Reply With Quote
Old 05-22-2019, 04:25 PM   #5
orlik's Avatar
Gulf Breeze , Florida
Thanks for the tip. I completed upgrade without issues but still not able to adjust nav settings while driving. Too bad.
orlik is offline   Reply With Quote
Old 05-23-2019, 03:47 PM   #6
San Diego , California
How about a step-by-step explanation for us tech challenged guys.
Fly.On is offline   Reply With Quote
Old 05-23-2019, 07:43 PM   #7
wachuko's Avatar
Orlando , Florida
Same here. Checked today since I took my AI to work... tested and the message of not being able to change while in motion came up....
Safe travels!
Wachuko
WBCCI #26769
Old 05-24-2019, 12:30 PM   #8
wachuko's Avatar
Orlando , Florida
Safe travels!
Wachuko
WBCCI #26769
Old 05-24-2019, 04:46 PM   #9
orlik's Avatar
Maybe next version
Old 05-26-2019, 07:56 PM   #10
sheakev's Avatar
Madison , WISCONSIN
It won't let one put in a "new" address, but if you have it in there it will let you select a saved or recent destination. Everything else seems to work while moving.
Kevin N9JKP
Old 06-03-2019, 01:36 PM   #11
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Updated
I started two days ago to update my Fusion, using the USB input. I had never used the USB before in the 2018. The USB memory was not recognized, no response at all. I tried several other known good USBs, also with zero response from the Fusion.
I pulled the Fusion and traced the USB wire from the socket in the dash-top compartment. Six feet of wire to go 6"! All appeared to be properly hooked up. I unplugged the 6' Airstream cable from the short wire from the Fusion and plugged the USB in there. Still no response. I unplugged the short wire from the gray connector on the Fusion and metered the signal pair (white/green). That cable appears to be good as well. I have to reluctantly conclude that the Fusion is failing internally.
After 35 years of designing and debugging electronics for IBM, the tangled wad of wiring behind the Fusion dismays me.
I plugged a mini-SD into the front and prepared to download with it. I downloaded both the latest Fusion system and the latest Garmin maps. I applied both updates to the Fusion without problems.
I now have the latest Fusion release and 2018 maps. My maps now even show a new toll road close to my home that just opened to traffic yesterday.
I have decided to simply ignore the USB problem and use the mini-SD from here on. I have a small Atom processor installed in the AI where I can easily write on the mini-SD when I want to update or transfer music to the Fusion.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 06-03-2019, 01:38 PM   #12
wachuko's Avatar
Orlando , Florida
Same here... did not even bother with the USB after the first attempt using it failed... I have been doing the updates via the mini-SD card.
Safe travels!
Wachuko
WBCCI #26769
Old 06-13-2019, 10:11 AM   #13
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
5 New Updates after 3.80 the most important/relevant to us is the
US & Canada Maps version 2019.20
Map Care Expiration Date 5/26/2022
FYI - regarding the "nanny controls" - any choices/options that can be accessed via the touch screen that DOES NOT require one having to type-in an input is accessible. If it requires typing in an input (i.e address or name) it will generate the "Function not available while vehicle is in motion". There were changes to the last update of the VIM file that made/allowed this partial "compromise".
FYI2 - if there are many choices/options necessitating multiple pages to scroll through, the up/down arrows would be disabled (grayed-out). A workaround is to momentarily put van in Park (on next stoplight, obviously not while in motion), then access the scroll arrows. Then place back on Drive and the scroll down arrows remain enabled.
Name:	Fusion Update 01.jpg
ID:	343212   Click image for larger version
Name:	Fusion Update 02.jpg
Name:	Fusion Update 03.jpg
Alex AVI is online now   Reply With Quote
Old 06-13-2019, 12:03 PM   #14
wachuko's Avatar
Orlando , Florida
Great! Will update the maps this weekend!
Safe travels!
Wachuko
WBCCI #26769
Online version of Airstream Life magazine rluhr Commercial Listings 55 05-28-2009 03:02 PM
Safari 25 SE Lounge version--opinions? Fiamma 2008 Safari SE 27 08-22-2008 07:17 AM
fantastic fan install version two Frank's Trailer Works Roof Vents, Skylights & Fans 1 11-23-2007 06:01 AM
Members listing in new version jaco Our Community 14 04-16-2004 12:43 PM
DeLorme Street Atlas version 10.0 Pahaska On The Road... 14 09-07-2002 02:48 PM
