Old 11-12-2019, 08:21 AM   #1
Mansderm161's Avatar
NORTH MYRTLE BEACH , South Carolina
Fusion battery drain
I'm at Mercedes. My original chasis battery was changed soon after I purchased new due to low voltage. Since then, almost 2 years, no problem.
Now all of a sudden after 30 day trip, 4000 miles, I'm noting drain again. Also yesterday screeching noise, I think from fusion, happened when engine started.
No more screeching but fusion seems to be staying lit up and on, like a constant drain unless I manually hit the off button and Mercedes says a "drain" can suddenly start to happen?
Would like thoughts, feed back, and recommendations for who could put in one of those fusion cut off switches for me. Has anyone had airstream do it? Thanks
Mansderm161 is offline   Reply With Quote
Old 11-12-2019, 09:08 AM   #2
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
It might look intimidating, but it is a fairly easy modification to make...
Just get the switches and do it yourself... or, if you are ever in Orlando, FL... I can help you with it.
Link to the switches (need two): https://www.ebay.com/itm/NCV3-Sprint...72.m2749.l2649
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 11-12-2019, 02:44 PM   #3
I'm likely to take you up on that offer. I will be down after Jan 1. For at least a week. Let me know if that would work. Thanks
Debbie
Old 11-12-2019, 03:50 PM   #4
wachuko's Avatar
Orlando , Florida
Sure. Send me a message o text me, when closer to the date. Happy to help.
Safe travels!
Wachuko
WBCCI #26769
For owners with the Fusion Infotainment system - battery saving tip FlyFishinRVr Sprinter and B-van Forum 0 04-20-2017 08:30 PM
Vintage Fusion - the story of our '69 AS Remodel monah 1959-69 Tradewind 255 09-08-2011 11:40 AM
Krylon Fusion Paint? Roadrunner General Interior Topics 24 11-18-2009 12:32 PM
Fusion for Plastic 76sovereign Sinks, Showers & Toilets 11 09-05-2008 02:15 PM
Krylon "fusion" stuart1 Plumbing - Systems & Fixtures 2 06-24-2003 09:36 PM
