Old 07-14-2019, 10:51 AM   #1
2017 Interstate Grand Tour Ext
Denver , Colorado
Fusion alert chimes, how to turn off?
I have the Fusion Infotainment system in my 2017 AS Interstate. It has a feature that warns of weight limits for roads with a chime and a notice on screen. It tells me the weight limit for every city street I cross (7000lb) and that I weigh more than the limit. How can I turn this off? At least can I turn the audible part off? The unit will not let me change the vehicle profile. Thanks.
Mobey is offline   Reply With Quote
Old 07-14-2019, 11:56 AM   #2
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
I assume you have the Fusion RV-IN801 unit. The manual says Airstream should have set the proper profile for your Interstate, but I doubt they do it. That 7000 lb weight setting might also be routing you on less than optimal routes.
Have you tried adding or editing the Vehicle Profiles as outlined in the user manual? Page attached.
I didn't see any clues on turning off the chime warnings in the manual.
- - Mike
Old 07-15-2019, 10:23 AM   #3
Denver , Colorado
Thanks for the advice Mike. That is the unit i have. The vehicle profile is entered and correctly as 11,000 lbs. I have tried to edit the profile but the unit will not allow it for some reason. Any other ideas?
Old 07-15-2019, 12:35 PM   #4
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
MOBEY - I am out of town awhile, so wont be able to confirm. But IIRC the profile installed from manufacturer is not editable unless you go through a total "factory reset" process. Pretty sure I tried editing it when I first took delivery and could not. I do not want to "factory reset" mine since it is working as best as can be expected. Also, since it is correctly set at 11,000 lbs. why the need to edit? And if you really want to have an editable profile, just add a a new profile and use that instead. Accomplishes same thing without destroying the factory profile
Alex AVI is offline   Reply With Quote
Old 07-15-2019, 12:58 PM   #5
Fulton , Maryland
As Alex mentioned best to create a new profile and see if that helps. You said it is set to 11,000 lbs. so if you are driving on streets only rated for 5 tons, which is very common, then the alarm will sound.
- - Mike
Old 07-15-2019, 02:02 PM   #6
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
I have not been able to turn them off for when going into places where it does not know if it is okay for the RV to go into... always get that chime that interrupts the music playing, and also shows the message in the navigation screen...
Do not recall hearing one due to weight limitations in the route... but then again, if it shows a message somewhere, I most likely have missed it all this time...
Subscribed in case we do find a way to quiet that down...
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 07-15-2019, 07:04 PM   #7
Alex AVI's Avatar
WACHUKO, MOBEY - Pretty sure you can not turn off the CHIME or Visual Warning. The whole point of using navi is to have both. Kinda like Lane Assist, if you hate the constant beeping (which I do), turn off Lane Assist (which I also do). In this scenario, turn off navigation, problem solved.
Old 07-24-2019, 10:24 PM   #8
Alex AVI's Avatar
MOBEY - Update & Correction - my Fusion has 2 profiles named Manufacturer & ALEX AVI.
The profile named Manufacturer has it's Audible Alerts Disabled. I now recall and am pretty sure that happened on my very last update when it prompted me for those settings.
But I use my own personal profile named ALEX AVI. By using that, I can pick & choose what audible alerts I want Disabled or Enabled.
If you want to change the Manufacturer profile settings, it looks like you can do it, but need to go through the updates. Probably best to start from Factory Defaults to make sure it updates from a known stable rev. Good luck.
FUSION radio on/off Long Spur Sprinter and B-van Forum 5 05-31-2019 01:33 PM
Google Turn-by-Turn Navigation techiej Electronics & Connectivity 19 12-27-2012 05:55 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
Flamingo Chimes AirHog Link Archive 5 05-31-2005 04:04 PM
Krylon "fusion" stuart1 Plumbing - Systems & Fixtures 2 06-24-2003 08:36 PM
