Old 10-07-2015, 06:11 PM   #1
kfrere's Avatar
2008 31' Classic
Lenoir City , Tennessee
Furnace crackling
If this has been discussed please just point me to thread, but our 2016 AI has exhibited crackling in the furnace. Not all the time, but often enough that it causes concern. Is this a natural occurrence? Or, is something getting ready to ignite? There's no smell associated with it, and no operation failure at all. Just the noise.
Kelly & Matt
WBCCI - #4335
2005 Diesel Excursion
2008 31' Custom Classic "Moonshine"
2016 Interstate "BugOut"
kfrere is offline   Reply With Quote
Old 10-07-2015, 06:50 PM   #2
iaqstuff's Avatar
2013 Interstate Coach
Yarnell , Arizona
Just when you first start it and/or when it shuts down?
iaqstuff is offline   Reply With Quote
Old 10-07-2015, 08:00 PM   #3
1979 23' Safari
Wayland , New York
Does it sound like it's metal expanding or contracting when warming up or cooling down, like a car engine?
Old 10-07-2015, 08:28 PM   #4
kfrere's Avatar
2008 31' Classic
It doesn't happen when we first start it. It runs a while (varies from short while to longer) then we turn it off because don't know what's happening and if it's being harmed. It sounds a bit like a crackling log fire. Like maybe something is getting real hot and popping. It's random, quick crackling sounds; not a steady pattern.
Kelly & Matt
WBCCI - #4335
Old 10-07-2015, 10:30 PM   #5
iaqstuff's Avatar
Yarnell , Arizona
Is there no fan (blower) running?
Old 10-07-2015, 11:23 PM   #6
1979 23' Safari
Wayland , New York
Could be the metal expanding and contracting. It probably wouldn't hurt to just take it to an rv shop for a quick look for safety sake.
Old 10-08-2015, 03:05 AM   #7
kfrere's Avatar
2008 31' Classic
Yes, the fan is blowing out hot air. Since it just woke me up my first thought about a better description is a high pitched pinging sound. We expect to look at the vent and see tiny pieces of metal flying out - but none does. Everything seems to work fine - except for this noise.
We're traveling in Wisconsin (hence the need for heat during these 50 deg nights). Should we try to find an RV repair, or rather an electrician/heater repair?
Kelly & Matt
WBCCI - #4335
Old 10-08-2015, 06:01 AM   #8
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
I have a 2015 model Airstream and the first time I used the furnace it crackled but after using a few hours it went away and has not returned. If I remember correctly also had a slight smell as it was burning off all the new I guess. I do hear the furnace ignite and the fan running.
Ron
Ron A is offline   Reply With Quote
Old 10-08-2015, 12:16 PM   #9
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Could be something in the fan itself bouncing around.
Old 10-08-2015, 05:55 PM   #10
iaqstuff's Avatar
Yarnell , Arizona
Sounds like the fan blade(s) are hitting something. Have a tech take a look at it - probably an easy fix.
Old 10-08-2015, 07:23 PM   #11
1979 23' Safari
Wayland , New York
RV shop would be the better option, it sounds like it's just the metal expanding and contracting, especially as new components get settled from manufacture and are being used for the first time.
Furnace fumes from new furnace rosser7 LP Gas, Piping, Tanks & Regulators 15 06-01-2013 09:17 AM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 03:37 AM
Deactivated Furnace will Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-22-2002 08:19 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 08:29 PM
