Old 04-01-2015, 10:22 PM   #15
weirdstuff's Avatar
2018 23' International
San Diego , California
Originally Posted by 73shark View Post
Unless AS installed the switch upside down.
Good point. A real possibility!!
weirdstuff is offline   Reply With Quote
Old 04-03-2015, 06:18 PM   #16
Newbie
joemikeb's Avatar
2013 Interstate Coach
Fort Worth , Texas
If you remove the front cover of the furnace (it is held on by spring clips) there is a white rocker switch on the right hand side of the furnace. I am not sure what it is, but assuming the LP is on, the thermostat set to furnace, the temperature is above ambient, and the fan set to Auto has not worked, toggling this switch off for several seconds and then back on then waiting a couple of minutes for the furnace to make up its mind and start worked for me.
I nearly froze my backside off before the dealer showed me this little trick.
Make errors — otherwise the Great Spirit realizes
you have finished your purpose on earth.
— Navajo saying
joemikeb is offline   Reply With Quote
Suburban Heater Blowing Cold Air occasionally Cody Madison Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-20-2014 04:39 PM
Oh oh, heat pump only blowing cold air almcate Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-17-2013 04:17 PM
furnace blowing cold air canine camp Furnaces, Heaters, Fireplaces & Air Conditioning 55 07-27-2013 12:14 AM
Heat Pump/Air Condition Blowing Hot Air Safari-Rick Furnaces, Heaters, Fireplaces & Air Conditioning 1 04-24-2012 09:30 PM
A/C not blowing cold anymore hollandranch Furnaces, Heaters, Fireplaces & Air Conditioning 17 09-26-2007 11:44 AM
