Old 01-03-2015, 12:10 PM   #1
Glamper1's Avatar
Furnace
Is programming this thing braindamaging or is it me?
All I want is to be able to turn it on when its cold and off when its not
I have a 2014.5 AI
Thanks!!!!!
Glamper1 is offline   Reply With Quote
Old 01-03-2015, 12:12 PM   #2
Lily&Me's Avatar
Normal , Illinois
I don't know what you have, but my propane furnace has to be pushed to a "click" at the lowest range, to keep it from coming on by itself.
Maggie
Lily&Me is online now   Reply With Quote
Old 01-03-2015, 12:22 PM   #3
Glamper1's Avatar
Im thinking that if im plugged into shore power to just go with my little space heater instead of the furnace....at least while im awake.
They say space heaters shouldnt be used while asleep so I guess while asleep, the propane heater is the safest option on or off shore power.
Is that correct y'all?
THANKS AGAIN !
Old 01-03-2015, 12:28 PM   #4
Lily&Me's Avatar
Normal , Illinois
I didn't realize initially that you are in a Class B.
If you're plugged into electricity, of course use your space heater. We pay the same site fee as bigger rigs, seems to even things out.
We have always run our space heater at night, and never once had a problem. Should there be a problem....there is a front and a back door.
Unless it is bitter cold, the space heater can run you right out, it does such a good job of warming a small space.
Maggie
Old 01-03-2015, 12:41 PM   #5
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
Here's the manual for the Dometic Thermostat:
http://www2.dometic.com/8dc07cfd-4b7...e4e0084e.fodoc
In the Interstate you have just one zone, don't really need any programming; just set it on, then set Mode to either Heat or Cool as required. Then arrows on the right to increase or decrease temperature. Pretty simple. Gas has to be on of course.
But I agree with Maggie, if you're hooked up, use a small ceramic space heater with temperature adjustment, not the furnace. And you can leave it on all night.
Old 01-03-2015, 12:56 PM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by Glamper1 View Post
They say space heaters shouldn;t be used while asleep so I guess while asleep, the propane heater is the safest option on or off shore power.
Electric space heaters are fine while you're asleep— as long as you buy one with a tip-over switch on the bottom so that if it happens to fall over it shuts off.
However, if it's cold enough to also need the tank heaters on the fresh and gray tanks, you shouldn't use an electric space heater or the electric mode of the water heater; you'll be coming perilously close to your 30-amp limit will all of them sucking down electricity at once.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-03-2015, 01:19 PM   #7
Rockwell , North Carolina
If you have accidentally set a program for the furnace, that may be the problem with getting it to turn on. In the thermostat instructions it shows how to remove all programs. Do that and the furnace will work like you think it should. Ask me how I know this!!!
jerhofer is offline   Reply With Quote
Old 01-03-2015, 01:28 PM   #8
2005 22' Interstate
Pittsburgh , Pennsylvania
Well, you should certainly do the math for your own particular situation, but in general, those tank heaters don't draw that much current. It is rare to see one that draws 2 amps @120VAC. A 1200 watt heater would be 10 amps. Generally speaking, I think you would be fine if you have 30 amp service.
Formerly: 2005 Airstream Interstate (2500 T1N)
Now: 2014 Great West Vans Legend SE (3500 NCV3)
avanti is offline   Reply With Quote
Old 01-03-2015, 01:35 PM   #9
Glamper1's Avatar
I didnt know that the 2014.5 AI has tank heaters !
Old 01-03-2015, 02:23 PM   #10
UKDUDE's Avatar
Sedona , Arizona
I plug mine into the socket behind the driver's seat near the floor, so it's well out of the way of night journeys from bed to bathroom. But if you have animals, I definitely wouldn't use an electric space heater.
I have watched the amp usage when turning on the tank heaters and have been surprised to see only a small difference - perhaps one amp.
Old 01-03-2015, 02:59 PM   #11
Lily&Me's Avatar
Normal , Illinois
Lily, and before her, Gus, had no problems wth our space heaters.
Navigated around them deftly, and never knocked them over, even in the Interstate.
Unless you have a particularly rowdy animal, and one which would be so during the night....in which case I, personally, would confine them at bedtime.....I wouldn't let that stop you. Our dogs always slept when we slept, but for the occasional trip for a drink of water.
Do what makes sense to you, for your particular situation.
Maggie
Old 01-03-2015, 07:01 PM   #12
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Maybe Protag was thinking about the amount of current that the tank heaters use at 12V DC which is what they run on even on shore power. (I think)
Old 01-03-2015, 07:22 PM   #13
2005 22' Interstate
Watts are watts. You can do the calculation in 12V amps rather than 120V amps if you like, but you will reach the same conclusion (modulus any conversion losses that may be involved, which will not be material).
BTW: There are three kinds of tank heater pads: 12VDC, 120VAC, and those that take both. They do not use significantly different amounts of power, though. These things rely on low, continuous heat, not at all like a space heater.
Old 01-03-2015, 07:46 PM   #14
The tank heaters on my Interstate are 12vDC, not 120vAC (Page H-10 and H-11 of the 2012 Airstream Interstate owner's manual). The information I got from Foley RV when I bought my Interstate is that the tank heaters would completely deplete my house batteries overnight so I should only use them if hooked up to shore power.
I don't know exactly what the draw is on the tank heaters; they aren't fused, but instead have self-resetting thermal breakers, so I can't even estimate based on fuse capacity. But estimating based on completely draining 160 amp-hours of battery capacity in 8 hours of use tells me about 20 amps.
Y'all do what you want, but I for one do not use a portable electric heater when I'm also using the tank heaters. I'm I'm being overly cautious, then so be it.
WBCCI #1105
TAC LA-4
Furnace fumes from new furnace rosser7 LP Gas, Piping, Tanks & Regulators 15 06-01-2013 09:17 AM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 03:37 AM
Deactivated Furnace will Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-22-2002 08:19 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 08:29 PM
