Old 11-17-2014, 03:05 PM   #1
Glamper1's Avatar
Furnace
Hi
First night in AI
Never had so much fun sleeping and eating.
I have to figure out the thermostat next.
My questiin is, do you experts use the furnace while you sleep?
Propane scares me
Im thinking of getting s high quality electric space heater and just use that til 10-11 pm then shut off
If not on shore power maybe do the same with the propane furnace.
50 watt solar seems useless so at least for now, I dont see myself boondocking but im sure with time, knowledge, and confidence that will change.
All comments appreciated
Including your best pick for a 12 volt mini vacuum.
Glamper1 is offline   Reply With Quote
Old 11-17-2014, 03:25 PM   #2
ottawa (greely) , Ontario
I always use the furnace on all night , if I have electric hook up then I use the heat strip on a.c . Or extra electric heater but turn off the electric heater once in bed and leave furnace on ,if it's cold below freezing the holding tanks are heated on some airstream models from the furnace so you have to leave it on or they will freeze up. And your 50watt solar panel is only good to prolong your boondocking ability unless your very conservative and the panel is in the sun no shade, my wife and I can go 6 days on our 1 battery with no solar panels or electricity , I did upgrade my battery to a real deep cycle battery 129 amp hours a lot better then those crappy interstate batteries.
2012 silverado ext cab 4x4 ,5.3 L , 6 speed trans,3:42 final drive,tow package standard box 6 1/2 foot . 2014 honda forza 300 scooter, #2 2015 honda crf 250 L (Dual sport)
scamp is offline   Reply With Quote
Old 11-17-2014, 03:36 PM   #3
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
I always use a small ceramic heater when hooked up - there are hundreds to choose from on Amazon.
I do use the furnace when dry camping, but set the thermostat pretty low and make sure there's good ventilation from the overhead MaxxFan; and REGULARLY test the smoke, CO and propane detectors. Very important, and for peace of mind too.
Old 11-17-2014, 04:30 PM   #4
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I don't sweat the furnace. They are more reliable than an overtaxed elec system. A DYSON Hot Heater is a great addition.
Old 11-17-2014, 04:44 PM   #5
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
We use a small ceramic heater to maintain a lower overnight setting. We leave the furnace set at 55. We do check all detectors each time out. Used the tank heaters on the last trip, along with a heated hose.
FMCA # 436814
toskeysam is online now   Reply With Quote
Old 11-17-2014, 04:58 PM   #6
terryV's Avatar
2002 31' Classic
Monroe , Iowa
I use the furnace if it's cold. I set it at 68 degrees, which is the temp Joyce likes.
During a sunny day the trailer warms up and the furnace doen't work very hard at all.
I've done a lot of snow camping while hunting over the years. I can go a couple or weeks on the propane on board.
terryV is offline   Reply With Quote
Old 11-17-2014, 05:01 PM   #7
jimmini's Avatar
1989 29' Land Yacht
Mesa , Arizona
Images: 43
Heater
Since we boondock and do not have external power. We set are heater at 50 F at night so we do not use up our battery power and we do not have to worry about freezing water tanks.
We use sleeping bag in our trailer all the time and they are - 20 f so we stay warm all the time.
Use 190 watt solar panel free standing to charge battery's and have Honda 2000 when we need it.
Jimmini :
AKA : TUMBLEWEED. Just an old buzzard with a itch to yonder.
Cowboys have a way of looking at things a little differently than most folks.Their wisdom is simple and more down to earth.
jimmini is offline   Reply With Quote
Old 11-17-2014, 05:50 PM   #8
Bk Yd Safari's Avatar
2008 20' Safari
Tunnel Hill , Georgia
on cold nights we use the furnace, when not so cold we use a small electric ceramic heater purchased from Ace Hardware.
Remember its not the destination, but rather the journey.... its what's in the middle that matters the most!
Bk Yd Safari is offline   Reply With Quote
Old 11-17-2014, 06:23 PM   #9
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
We use a portable space heater for cold nights in most cases. For sub-freezing temps, it's best to use the furnace on later model trailers as it is ducted to areas that contain plumbing between the interior and exterior of the trailer. Running the furnace will help keep the pipes from freezing.
As for a vacuum, we use a Dyson cordless digital slim. Not a direct 12v plug in but rechargeable 120v. Love it.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 11-17-2014, 06:51 PM   #10
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I use a Black & Decker Versa-Pak vacuum. Keep it under the streetside second row seat and plugged in to the nearby outlet.
Old 11-17-2014, 07:11 PM   #11
Glamper1's Avatar
Great advice
Old 11-17-2014, 07:15 PM   #12
Glamper1's Avatar
With electric heater and/or furnace on should I keep max fan door open AND have that fan on low?
Or is it okay to just keep a few side panels open a tad for ventilation?
Thanks all
Old 11-17-2014, 07:50 PM   #13
TinShack's Avatar
2005 28' Safari S/O
Assuming you have a later model trailer, the furnace is vented to the outside, and electric heaters do not consume oxygen, so no need to leave windows or vents open. It will help to help keep the condensation build-up down though. I usually leave a couple windows open a crack on opposite sides of the trailer to help with that.
Steve
Old 11-17-2014, 08:06 PM   #14
Glamper1's Avatar
Thank you CA Streamer
I assume CA is for California
Bay Area by any chance?
Furnace fumes from new furnace rosser7 LP Gas, Piping, Tanks & Regulators 15 06-01-2013 09:17 AM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 03:37 AM
Deactivated Furnace will Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-22-2002 08:19 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 08:29 PM
