08-10-2015, 04:42 PM
2014 Interstate Ext. Coach
Monroe
Front TV fell off, 2014.5 Interstate
The front TV in my 2014.5 Interstate became unattached. The van is a little over a year old. It's the TV mounted in front, overhead, angled down.
The metal bracket mounted to the Airstream is undamaged, but the TV tore loose from that and cannot be repaired. The screws pulled free from the TV and damaged the mounting holes on the TV. I've included pictures. It didn't loosen. Instead, the plastic of the TV tore apart at the screw mounts.
Is this happening to everyone? Am I going to have to replace this TV every year?
08-10-2015, 04:54 PM
2011 Interstate Coach
Overland Park
, Kansas
Assuming no one tried to chin themselves using the TV, that seems unusual as the threaded inserts are molded in on most TVs. Since the plastic failed and the inserts didn't pull out, I'm guessing that it would take a lot of force to cause that kind of failure.
I would try epoxying (JB Weld) a thin (1/16") 2" X 2" piece of aluminum plate w/ a clearance hole for the stud w/ the insert attached on the back side of the plate to the TV. Not sure if it would hold but JB Weld is very good. Just be sure both surfaces are clean (lacquer thinner) and abraded to get good adherence.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
08-10-2015, 05:35 PM
Figment of My Imagination
2012 Interstate Coach
From All Over
, More Than Anywhere Else
I think I can safely say that if it ever happened to anyone else, they didn't report it here on the Forums. Your problem is unique.
08-10-2015, 05:54 PM
begorragirl
2017 25' Flying Cloud
Denville
, New Jersey
Looks like u r under warrenty.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
08-10-2015, 06:21 PM
From All Over
With plastic it's harder to tell if a crack was pre-existing or if it's new than if it was metal (which will show oxidation at an old crack and bright shiny metal at a new break). But save all of the broken plastic pieces anyway, and examine them carefully— you may be able to tell if the plastic was already cracked or if it broke when the television fell.
If you try to fit the broken pieces back in place and they fit flat just like before, then the cracks were pre-existing.
If the breaks show evidence of bending before breaking (the engineering term for that kind of bending is "plastic deformation" and it's why the material is also called plastic), then they happened when the television fell, not before.
My guess is that you'll have some of each type, both pre-existing cracks that weakened the material and deformed breaks from when the television fell.
08-10-2015, 07:14 PM
2024 Interstate 19
Fulton
, Maryland
Never seen this problem. If you are still under warranty get Airstream to give you a new TV. It may have been damaged before you got it.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
08-10-2015, 09:18 PM
Overland Park
, Kansas
From the pictures, it appears that force was exerted as if one was pulling it off the mounting brackets.
08-10-2015, 09:29 PM
From All Over
What happened to the wires when the television crashed to the floor? The power, coax, and HDMI cables had to be yanked pretty hard as well.
08-12-2015, 11:19 AM
2014 25' International
2010 22' Interstate
Carol Stream
Could it be an attempted theft and the thieves got scared off before they completed the crime? Looks like it may have been forced.
08-13-2015, 03:58 PM
Monroe
The dealer ordered a replacement weeks ago.
The last time the van was in for service at the dealer, I asked them to look at was the TV, because 1) it was loose, and 2) had no sound on the right channel. They realized they couldn't tighten it (or fix the sound), and ordered a new one.
Perhaps in earlier years the TVs were smaller. The bottom of this 22" TV extends into the cabin. It includes a nameplate which drops 3/8" inch below the bottom edge of the TV. In the first couple of months of ownership, I whacked my head on the bottom of the TV more than once. More than a dozen times, in fact. OK, probably several dozen times.
Banging into the TV with my head may have contributed.
The bottom of that Samsung name tab is quite sharp. I've hit it hard enough to draw blood, more than once. (I tried to take a picture of the name tab on the bottom of the TV, but I don't think you can really tell from the picture how sharp the tab is.)
08-13-2015, 04:40 PM
2024 Interstate 19
Fulton
, Maryland
Ouch!!
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
08-13-2015, 11:22 PM
2015 Interstate Ext. Coach
Framingham
, Massachusetts
I noticed that in our 2015 AI, there was a crack at the back of the TV. I had it replaced under warranty not because of the crack but it was not turning on
08-14-2015, 03:33 AM
From All Over
My front TV is only 19" and does not extend below the bottom of the storage compartment to which it's attached. But even so, in early days of ownership I still bumped my head on the television, though it was only when I was getting into the cab, not getting out of it.
One fix for the head-bumping might be to do what I did, which was to place a clothes bar across between the clothes hooks on each side.
http://www.amazon.com/Bell-Automotiv...ds=clothes+bar
I still bump by head on the clothes bar from time to time, but it forces me to duck lower, and when I do bump my head, the clothes bar is round and not sharp. I'm sure you'll also find other uses for a clothes bar once you've got one in place.
Another fix might be to get some split foam pipe insulation and pad the bottom edge of the television.
08-14-2015, 10:20 AM
Overland Park
, Kansas
Was yours the same Samsung as the OP had? If so, maybe the Samsung model is not up to the bumps and jolts of going down the road in an RV.
08-14-2015, 10:15 PM
Framingham
, Massachusetts
Yes, 22" Samsung flat screen LED TV
08-17-2015, 09:25 PM
norman
, Oklahoma
I had the same problem with the 19" Sansui in the front of my 2012. Initially my warranty claim was denied but after appealing it was grudgingly covered under warranty. They essentially accused me of causing the problem. I assure you no chin ups were done, and I never even hit my head on it. All I can say is that I did and do drive my bus around town a lot and the road conditions here are not very good ... it probably sees more stress than one that lives it's life on the open road. The rear TV had/has the same problem but had/has not completely failed ... they refused to replace that one. Surprisingly it's still hanging on here three years later. No problems with the new front TV they put in. Here's my original complaint thread ... no one fessed up to having a similar problem then either. Guess we are just lucky. http://www.airforums.com/forums/f240...ing-94594.html
08-23-2015, 05:56 AM
Pensacola
When I purchased my 2015 ASI-EXT used w 8400 miles, the front 22" Samsung tv plastic back plate had been damaged and the previous owner had two pieces of bailing wire securing the tv to the mount. The dealer ordered a new tv under warranty. Due to the delay in the new tv arriving, I removed the old tv from the mount, removed the plastic back plate and found all four mounting holes damaged (cracked with two screw pulled out). I went to Lowes and purchased from the special fasteners drawers two 1.5 inch plastic washers with associated plastic bolts (1/4 x 1) and a plastic wing nut. I sandwiched the "plastic tv back plate" between the two washers, drilled not and bigger 1/4" mounting holes in the back plate (secure but slightly flexible mounting) at all four attachment points. This solution provides for a less rigid mount but more flex with hitting the tv from either direction. At 6'-3" and often wearing a Crimson Tide baseball cap, I repeatedly bump the tv with the top of my head both entering and leaving the cab area. 12,000 miles later and a Pensacola FL trip to the northeast and back and now an almost completed circuit from Pensacola to the west coast and back 4 mounts are holding on the tv repair. BTW I am planning to replace the two 22" tv's with 19" tv's with built in dvd's. In my opinion the rear tv at 22" sticks too far into the aisle and is a real potential hazard for anyone slipping and falling, especially coming out of the head in the middle of the night while completing the final downwind-leg approaching a landing spot in the bed w/o hitting spouse and dogs!
