Old 10-24-2015, 07:59 PM   #1
Front proximity sensor alarming
Just started tonight. My L front proximity sensor started alarming and there is nothing in front of the RV. It is intermittent about every 30 sec to 1 min. Any insights or ideas?
Thank you
ofdcb is offline   Reply With Quote
Old 10-24-2015, 09:10 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
No insights, because my Interstate doesn't even have proximity sensors.
But assuming the sensor actually is detecting something, it might have come loose from its mount so it's pointing at the ground in front of the van. And if it's loose, that would account for the intermittent indication, as vibration might cause it to shift its aim.
Old 10-24-2015, 09:22 PM   #3
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Look under your front bumper to make sure everything is still connected correctly.
Ron_CA is offline   Reply With Quote
Old 10-24-2015, 09:39 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my Lincoln's rear sensors some times sound if there is a metal plate or metal drain grate in store parking lots.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 10-25-2015, 12:52 AM   #5
2014 Interstate Ext. Coach
Aliso viejo , California
Is the front sensor indicator on the dash(by windshield
lighting up)?
Interstate14 is offline   Reply With Quote
Old 10-25-2015, 01:48 PM   #6
Yes it was on the front dash.
I believe I figured out the problem. Maybe someone could verify what I did.
There is a stem behind the front license plate that I believe aims the proximity sensors. I think I must have moved the stem when I put the new plates on yesterday. Drove the AI this morning and no alarm after I repositioned the stem to dead center.
Old 10-26-2015, 08:35 AM   #7
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
Thank you
What year is your Interstate/Sprinter? Over on the Sprinter-Source forum several owners of 2015 Sprinters have reported LH proximity false alarms.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 10-26-2015, 10:56 AM   #8
It's a 2013.
Low Coolant Sensor guy99 General Motorhome Topics 27 10-14-2013 10:47 AM
Smoke alarm keeps 'alarming'... TennisMan 2007 Safari SE 25 05-03-2009 08:51 PM
Smoke Detector alarming with moisture? davidz71 General Interior Topics 1 07-30-2008 08:41 PM
Where is the Speed Sensor? (Allison Tranny Error) Griffin Mechanics Corner - Engines, Transmission & More... 4 12-16-2003 04:57 PM
gas tank sensor wb13798 Mechanics Corner - Engines, Transmission & More... 21 08-21-2003 06:04 PM
