Old 02-02-2016, 11:05 AM   #1
2011 Interstate Coach
CHINO HILLS , California
Front Brake Pads Replacement
Hi! Last Friday I took my 2011 AI (based on 2010 M-B Sprinter Chassis) to the local Mercedes-Benz dealer for replacing 2 front tires and for Service B. The Service Advisor texted me yesterday and told me that they found the front brake pads have 15% life remaining and the rotors measured at 25.4mm (min is 25.0 mm). They recommend to replace the brakes for $1152.47. The AI has about 41,500 miles on it. I called an independent auto repair shop and they quoted me about $270. Does anyone has any experience in replacing the front brake pads? Is M-B Dealer's quote reasonable? Thank you very much for your help!
milkfish888 is offline   Reply With Quote
Old 02-02-2016, 12:17 PM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Did you ask for an itemized estimate on the brakes?
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 02-02-2016, 12:53 PM   #3
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
You can expect a Service B to cost over $1000 at a Mercedes dealer; better to look for a Freightliner dealer for more cost effective service and repairs.
Old 02-02-2016, 12:58 PM   #4
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
When comparing services note that Mercedes standard practice is to replace rotors and brake fluid with every pad change. Mercedes does not recommend "turning" (machining) and re-using the rotors.
The brake shop quote for $270 certainly won't include new rotors.
Still, $1100+ for just the fronts is quite high. Try talking to another MB dealer before you decide.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 02-02-2016, 05:46 PM   #5
73shark's Avatar
Overland Park , Kansas
Sounds high even if it includes rotors but then MB service is always considerably higher than the Big 3.
You might also check w/ a Dodge dealer that was a former Sprinter store.
Old 02-02-2016, 05:52 PM   #6
Mjgman's Avatar
2013 Interstate Coach
Bradenton , Florida
Does sound a bit high even for Mercedes.. New rotors and pads with labor shouldn't be that much..
Name:	ImageUploadedByAirstream Forums1454460718.845680.jpg
Mjgman is offline   Reply With Quote
Old 02-03-2016, 11:59 AM   #7
1977 31' Sovereign
Lynnwood , Washington
Sounds to me like Mercedes is over-selling you.
Q: Does your rig have "composite" rotors?? High end German cars often do. I'm not so sure about German trucks.
FYI - Composite rotors can't be machined (turned).
Plan-B = Go to a Dodge dealership and get an estimate. Mercedes and Dodge are the same commercial van chassis.
Tom
TomKirk is offline   Reply With Quote
Old 02-03-2016, 01:45 PM   #8
1965 30' Sovereign
1969 23' Safari
Redgranite , Wisconsin
Tom
Not any more. MB gutted then sold Chrysler to Fiat who now provides the Ram commercial vans.
Lots to do. Getting there.
65Streamer is offline   Reply With Quote
Old 02-03-2016, 03:30 PM   #9
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
True. But some Dodge dealers can still handle Mercedes repairs. There are still plenty of pre-2011 Dodges out there with Mercedes drivetrain parts in them. And of course there's always Freightliner, the original Sprinter dealer in the US.
Plus Maggie (Lily & Me) has been using Peterbilt for her Interstate service.
Mercedes Benz is not your only option, but you will need to ask around in your local area.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is online now   Reply With Quote
Old 02-04-2016, 07:47 AM   #10
1996 25' Excella
Tillsonburg , Ontario
Any decent repair shop can do brakes on any vehicle. Just be sure you are getting top quality parts. I do my own on my Dodge; 4 wheels with rotors are about $500. Dealership price is $1200 plus. Any time I needed repairs while in Texas for the winter, the dealership always found a way to make it a $500 job. Pep Boys could do the same thing for under $300 and the little Mexican shop recommedned by the locals was under $200. Shop around!
JCW
JCWDCW is offline   Reply With Quote
Old 02-04-2016, 08:17 AM   #11
Well, not really. A service bay big enough to hold a 10' tall and 23'-to-25' long Sprinter van is a prerequisite in this case. Plus they'll need a lift capable of safely handling a 5-ton vehicle.
WBCCI #1105
TAC LA-4
Old 02-04-2016, 11:07 AM   #12
1977 31' Sovereign
From the archives of my memory:
Mercedes Benz has a Corporate "policy" not to machine (aka, turn) brake rotors. Their line of reasoning goes something like this; "We will not make any repair that might compromise your vehicle's braking performance."
And you know what?? They're right!! It's true that "machined" rotors have less metal and as a consequence, will heat up faster. And if rotors are thin enough. and with all that heating and cooling occurring over time, rotors will eventually warp and brakes will "pulsate."
Having said that, I'll say this: Mercedes "assumes" you will be pushing your vehicle's performance envelope to its outer limits, and then some. And IMHO, this is certainly not the case for the vast majority of drivers in America.
In other words, high-performance driving notwithstanding, machining rotors is a perfectly acceptable repair in the automotive industry.
Tom
Old 02-04-2016, 11:17 AM   #13
Originally Posted by Protagonist View Post
True. But some Dodge dealers can still handle Mercedes repairs. ...
I was told that you have to ask whether the given Dodge dealer is "Sprinter-certified". My local Dodge dealer is, and they routinely work on Sprinters. However, they are so much cheaper than the local MB dealership that appointments must be made weeks in advance. I was told this by several sources including by the dealer itself.
Old 02-04-2016, 12:02 PM   #14
Thanks for everyone's input. You guys are great! I was able to talk to the Mercedes-Benz Service Advisor at the dealer to give me a 10% discount for replacing the front brakes and rotors. Just got my AI back this morning.
Disc brake parts, pads and calipers Excella CM Brakes & Brake Controllers 31 04-16-2011 08:37 PM
brake pads/shoes Maya Brakes & Brake Controllers 5 12-01-2005 07:11 PM
Cracked Brake Pads DavidsonOverlander Brakes & Brake Controllers 6 10-31-2005 09:57 AM
Tow Vehicle Brake Pads? y5e06 Tow Vehicles 5 08-12-2004 12:21 PM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 05:01 AM
