Old 05-22-2014, 04:18 PM   #1
2014 Interstate Ext. Coach
Miami Beach , Florida
Fridge Question on 2014.5 Interstate
Another rookie question: We have turned off the fridge and the battery disconnect while our Interstate has been parked in our driveway, but are getting ready to hit the road this weekend. I'm slightly embarrassed to ask this, but what exactly do I need to in order to get the fridge cold starting tomorrow? I think it has to do with turning the switch back on along with the battery disconnect and possibly the inverter...but not sure. Your help is appreciated!
ATE123 is offline   Reply With Quote
Old 05-22-2014, 05:24 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I just did this minutes ago for tomorrow's trip. The fridge works in either 12vDC or 120vAC mode. To pre-cool the fridge, turn the house battery disconnect to "on." Turn on the fridge at the thermostat, and set it in between "3" and "4." That's all you need to do.
BUT, the fridge will cool down better if it's not empty. Fill the fridge with canned soft drinks or something, especially if they're already cold from your home fridge. If the soft drinks are already cold, the Interstate's fridge won't have to cool them, but the canned drinks will provide more thermal mass than would an empty fridge so once it gets cold, it will stay cold with less effort.
Do not turn on the inverter to run the fridge. That's a waste of amp-hours, since the inverter will use power in addition to the fridge using power.
Old 05-22-2014, 06:37 PM   #3
You're pretty much 'the man', Protagonist. Thanks!
Old 05-22-2014, 08:34 PM   #4
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Another little tidbit about the refrigerator is that if 120 VAC is available, it down-converts it to 12 VDC which is a true energy waster if you are running on the house batteries and have the inverter on.
IIRC, at least one poster rewired his to eliminate this problem.
Also on mine, I had to add a spacer to the inside of the outer door to keep the freezer compartment door from swinging open even w/ the outer door closed. Not sure why the freezer door didn't have some kind of catch/latch.
2011 Interstate SOLD! Upfitted 2017 Transit 350. SOLD!
Old 05-22-2014, 09:00 PM   #5
UKDUDE's Avatar
Sedona , Arizona
On mine (Nova Kool R3100), the freezer door is just held in place with gravity so there might be a tendency for it to swing open on sharp left turns but I find that ice build-up inside stops the contents from sliding around.
Old 05-27-2014, 06:52 AM   #6
norman , Oklahoma
Actually it does not even require rewiring. Just pull the 110v plug out of the outlet and it will run on 12v regardless of wether their is 110v available (via shore power or the inverter) or not. I was able to reach mine through the "drawer" under the sink on my '12 Lounge model.
russ240 is offline   Reply With Quote
NorCal : 2014 Jackson Rancheria Rally, October 10-12, 2014 Coastalview Forum Rallies & Meet Ups 240 01-03-2015 02:04 PM
2014 Interstate batteries question Billshop Sprinter and B-van Forum 28 07-12-2013 04:36 PM
2014 Airstream Interstate EXT Lounge New eBay Watch Airstreams on eBay 0 06-21-2013 08:40 AM
2014 Airstream Interstate EXT Lounge New eBay Watch Airstreams on eBay 0 06-09-2013 10:30 PM
Airstream Interstate 2014 versus 2013 Model migriffin Sprinter and B-van Forum 16 05-08-2013 10:53 AM
