Old 09-15-2018, 11:36 PM   #1
OAKDALE , California
Fridge and freezer icing up
We just completed four weeks in our 2018 interstate. About one week into our trip we noticed that the fridge upper cooling component was starting to ice up. Needless to say, it didn’t improve over the course of the trip. We were not in warm climate nor did we leave the fridge open for any length of time...
Thoughts?... is this common? Seems to be a bad situation... as excessive iced up on the components cannot be a good thing!!
jldejong is offline   Reply With Quote
Old 09-16-2018, 12:02 AM   #2
Contributing Member
Pahaska's Avatar
2014 Interstate Ext. Coach
Austin (Hays County) , Texas
Mine does the same thing, even if I let it run in storage with no one opening the door.
My first thought was that with two persons breathing in the cramped confines of the AI, the high humidity hitting the cold plate when the door was opened was the cause. Then, I found that it does the same thing with good ventilation in hot weather.
Frozen foods quickly glue to the plates with ice. The ice on the portion of the thermostat tube that is in the freezer seems to affect the temperature of the box.
John W. Irwin
WBCCI #9632
Old 09-16-2018, 07:14 AM   #3
2013 Interstate Coach
Raymond , Iowa
The freezer in our 2013 AI with Novacool 3.1 fridge/freezer combo frosts over in the freezer dept. too. On a recent 6 week trip the temperature on the top fridge shelf ranged from 31 def F when we started the trip (freezer and fridge was jam packed full, no frost present) to 36 at the end of the trip when the freezer was very frost and unit was only about 1/2 full. All with temp knob set at 4. Not sure how much of the drop in temp was due to frosted freezer compartment. I made a clip to help hold the freezer door shut, but can't tell that it reduced the frost any.
Titus is offline   Reply With Quote
Old 09-16-2018, 10:56 AM   #4
Boxster1971's Avatar
Fulton , Maryland
Totally normal. After a few weeks ice build-up is common. Higher humidity makes it happen faster.
We are all used to the frost-free refrigerators and freezers in our homes. But frost-free uses more energy thus not built into 12V RV/boating refrigerators.
When I shut off the refrigerator after a month on the road I always place a towel on bottom and leave the door open to defrost.
- - Mike
Old 09-16-2018, 11:52 AM   #5
Air99's Avatar
Camas , Washington
As the frost builds thicker around the cooling plate surrounding the “freezer” section of the fridge, causing the flap door to bind and not close properly, this in turn will send more cold air from freezer to lower compartment and vice versa with warmer (and more moist) air into the freezer cooling plate, exacerbating the frost buildups. I put self adhesive weatherstripping tape around the edges of the cooling plate where the swing door closes, this stops the frost from forming next to the door and seemed to help with keeping the freezer solid ice cold yet with less frost buildup.
Air99 is offline   Reply With Quote
Old 09-16-2018, 12:31 PM   #6
Fulton , Maryland
AIR99 - that is a great idea. I also need to add some form of latch to mine as the freezer door always seems to end up opening when driving down the road. That doesn't help the frost issue.
- - Mike
Old 09-16-2018, 12:49 PM   #7
2004 22' Safari
I have found that when not in hot weather I need to adjust the little plastic temp controller that is attached to the fin at the back of the fridge to a lower setting or the freezer will build up frost faster than normal.
Once frost starts to build up in the freezer it will cause temps to rise in the lower section of the fridge.
Northerngirl is offline   Reply With Quote
Old 09-16-2018, 04:17 PM   #8
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
As mentioned, normal for such fridges, though not common anymore for those of us used to frost-free residential units. I want to add, frost-free eliminates frost by shutting of compressor and letting temp rise to around 40-42°F. It does so for a set amount of time and then turns back on. And the cycle continues. Some ubber expensive units like Sub Zero use heaters to accelerate the defrost cycle. Yes, frost free only means YOU do not do the regular defrosting but the fridge still has to defrost by itself. This cycle happens many times in 24hrs. This allows much of the frost to melt. BUT the by product of that is water (lots of it). Do you see any water drain or water catch basin in/under your NovaKool. ZIPPO! If they made this a frosty-free, water would be spilling out the door into the floor or worse hidden under the fridge, unless they put a drain (or 2 in case of separate freezer/fridge & at least 1 catch basin).
MIKE makes a great point about the towels. I keep a shammy in it all the time, on or off. Guess how I learned . . . Luckily it was minimal spillage that stayed on top of vinyl flooring
Alex AVI is offline   Reply With Quote
Old 09-16-2018, 11:23 PM   #9
This is unacceptable!!!
Old 09-16-2018, 11:28 PM   #10
waninae39's Avatar
2017 22' Sport
NCR , Ontario
i added small fans to circulate the air much better
no ice up now
mounted to an alum strip with 3m tape
Name:	2018-09-13 15.43.51.jpg
waninae39 is online now   Reply With Quote
Old 09-17-2018, 12:06 AM   #11
WillieJ's Avatar
Bellingham , Washington
I had a Novakool in my boat (recently sold) as well as the one in my 2013 AI Lounge. Both needed occasional defrosting. Last year on a two month trip in the Interstste we defrosted three or four times.
Incidentally, the Novakool in the boat was original to the boat, a 1998 model, and still functioning just fine.
WillieJ is offline   Reply With Quote
Old 09-17-2018, 12:57 AM   #12
Alex AVI's Avatar
And you are very welcome!!!
You asked if this was common. It is not only common but normal for these types of fridge. If the answers you received here are unacceptable!!! then please contact your dealer, Airstream, and NovaKool. Your 2018 unit is under warranty. You might be able to get your NovaKool replaced with a frost-free unit.
Old 09-17-2018, 11:25 AM   #13
Fulton , Maryland
Interesting reply. You must have never owned a non-frost-free refrigeration device that required routine defrosting. As we have pointed out frost-free comes at a price. First they use more energy and second they create water that must be drained away.
Good luck with finding an RV unit that is frost free.
- - Mike
Old 09-17-2018, 01:35 PM   #14
Raymond , Iowa
'This is unacceptable !!!' means that we are spoiled rotten by frost-free refrigerators. If it is too unacceptable you can take another step back in time and put ice into a cooler. Or take two steps back in time and dig a root cellar under the Airstream.
AC icing up lbdesign Furnaces, Heaters, Fireplaces & Air Conditioning 8 05-04-2017 10:49 PM
Outside fridge and/or freezer ideas? JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 8 04-17-2013 07:55 PM
propane freezer cold, fridge hot rochar3 Refrigerators 9 07-10-2008 08:33 PM
Freezer works on propane - but not fridge adamstarr Refrigerators 2 08-14-2006 01:53 AM
freezer works great fridge to warm connors95 Refrigerators 29 09-30-2005 05:20 PM
