Old 09-17-2018, 01:38 PM   #15
Overkill Pundit
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Put a fan system in your fridge. No more frost.
ID:	322787   Click image for larger version
Old 09-17-2018, 01:39 PM   #16
2013 Interstate Coach
Raymond , Iowa
wanainee,
Is your freezer really at 22 def with your added fan or have you maxxed out the temperature that can be read on your freezer thermometer? I would be concerned that a fan on the freezer plate would turn the freezer compartment into another refrigerator compartment, where you have replaced frost accumulation with condensation that drips off instead of accumulating.
Titus is offline   Reply With Quote
Old 09-17-2018, 03:28 PM   #17
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Originally Posted by jldejong View Post
We just completed four weeks in our 2018 interstate. About one week into our trip we noticed that the fridge upper cooling component was starting to ice up. Needless to say, it didn’t improve over the course of the trip. We were not in warm climate nor did we leave the fridge open for any length of time...
Thoughts?... is this common? Seems to be a bad situation... as excessive iced up on the components cannot be a good thing!!
Hi jldejong,*
We're very sorry to learn about the issue you are having. Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customer_support@airstream.com*
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 09-17-2018, 05:08 PM   #18
Boxster1971's Avatar
Fulton , Maryland
GMFL & wanainee - can your share more details on the fans you have in your refrigerators? In your picture it looks like you both have the same basic refrigerators. I assume they are in AS trailers. It looks like they are in the refrigerator compartment - is that right?
GMFL - yours looks like a purchased item rather than the home made version done by wanainee. Can you share a source? How did you get 12V power to the fans inside the refrigerator?
You are talking to a group of Interstate owners that have some very small refrigerators that don't have much room to add a fan system. The Interstate GT models do have more room, but with separate refrigerators and freezers.
Thanks...
- - Mike
Old 09-17-2018, 09:12 PM   #19
Fulton , Maryland
I've answered my own questions. First the fans shown in photos posted by GMFL & wanainee are in large LP absorption refrigerator/freezers in Airstream trailers. They have little relevance to the 12V refrigerators in late model Interstates.
This YouTube video shows how to install the Smart RV Products refrigerator fan system.
https://youtu.be/X2XY-cisIXU
Note that these fans are typically tied into the interior refrigerator light found on some larger RV units. It also looks like the Smart RV unit is only designed for LP refrigerators.
https://smartrvproducts.com
Our Interstate 12V units don't have interior light - so powering an internal fan won't be easy. This little battery powered model I found on Amazon might work for an Interstate refrigerator.
https://www.amazon.com/Camco-Refrige.../dp/B0006IX7TW
- - Mike
Old 09-17-2018, 09:31 PM   #20
waninae39's Avatar
2017 22' Sport
NCR , Ontario
i used three 80mm muffin fans
wired in series, they spin very slowly and make no noise.
just enough wind to move some air
I did not need one in the freezer as well the freezer is very small
waninae39 is offline   Reply With Quote
Old 09-17-2018, 09:47 PM   #21
Overkill Pundit
GMFL's Avatar
Dadeville , Alabama
Yes mine is in a Dometic 7 cu foot in my 2014 23D. Thanks for the kind words, but I made mine also. Simple 2x3 aluminum extruded tube milled to make an air duct. Two 60mm fans inside pull air into the duct and blows it out the holes in the back of the duct. Blowing the air through the cooling fins in the back of the fridge. A 3 amp breaker two 2x3 plastic end caps and a power switch complete the project. I’ve been using mine for about 3 years now and it helps keep fridge temps low and I never have problems with icing up. 12volt power was obtained by running the 12 volt positive lead out through the drain tube and the ground is attached to one of the cooling fin screws via a eye crimp.
There is a guy now making them and selling them online called “fridge-fix”
https://smartrvproducts.com/
Old 09-17-2018, 09:52 PM   #22
Overkill Pundit
GMFL's Avatar
Dadeville , Alabama
12volt power can be obtain by running a wire out through the drain line.
ID:	322831   Click image for larger version
Old 09-18-2018, 07:13 PM   #23
Fulton , Maryland
GMFL - if you made that fan yourself then the guy making and selling them copied your design. Nice work.
- - Mike
Old 09-19-2018, 03:49 PM   #24
2014 Interstate Ext. Coach
fairfax station , va
R3100 NovaKool
I had a terrible frost/icing problem that was simply solved but it was a pretty specific issue.
The NovaKool R3100 has a reversible door that is hinged on the left.
There is a bottom bracket with a hinge pin on the right that receives the door when the door swing is reversed.
On mine, the bracket was bent up just enough to interfere with the door gasket sealing. I bent the bracket down and made sure the gasket was sealing when the door closed.
Voila...no more icing.
Something to check when troubleshooting.
VAtom is offline   Reply With Quote
Old 09-19-2018, 06:11 PM   #25
Fulton , Maryland
VAtom - good tip. I noticed same problem on mine just before my last trip. That seal has to close tight to keep frost down.
- - Mike
Old 09-19-2018, 06:36 PM   #26
Wannabe RV'er in training
Alex AVI's Avatar
2018 Interstate Lounge Ext
High Desert , Las Vegas , Nevada
VATOM - What MIKE said. No major icing issues here but won't hurt to check. Thanks for tip!
Alex AVI is offline   Reply With Quote
AC icing up lbdesign Furnaces, Heaters, Fireplaces & Air Conditioning 8 05-04-2017 10:49 PM
Outside fridge and/or freezer ideas? JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 8 04-17-2013 07:55 PM
propane freezer cold, fridge hot rochar3 Refrigerators 9 07-10-2008 08:33 PM
Freezer works on propane - but not fridge adamstarr Refrigerators 2 08-14-2006 01:53 AM
freezer works great fridge to warm connors95 Refrigerators 29 09-30-2005 05:20 PM
