Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Sprinter and B-van Forum
Old 09-04-2015, 07:22 PM   #1
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Fresh Water Tank Loose
Decided to flush my fresh water tank today and when removing the drain plug discovered the tank is loose.
I see some perimeter nuts that look like they are attached to some all thread so am guessing these need to be tightened.
Anybody know for sure / have tightened their tank?
Ron_CA is offline   Reply With Quote
Old 09-04-2015, 08:45 PM   #2
Ron_CA's Avatar
I just snugged up the 6 bolts holding the fresh water tank in a sort of cradle. Don't over tighten as there isn't a limit on how much you could tighten, would just end up squeezing and potentially reshaping your tank.
Old 09-05-2015, 11:34 AM   #3
2005 22' Interstate
san clemente , California
Could the loosening be a result of towing or putting it on the flatbed ? If so, you might check other items under that low slung chassis. Hope you find no problems and thanks for the heads-up.
unifreck is offline   Reply With Quote
Old 09-05-2015, 01:12 PM   #4
Vibration causes bolts to loosen.
Check all those things that can cause those vibrations.
The running gear, must be balanced, to start with.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-05-2015, 05:13 PM   #5
Ron_CA's Avatar
I think stuff just vibrates loose as it can on any vehicle.
I just wish I had a big enough lift or a big hole in the ground so That I could check things out more often.
Old 09-06-2015, 08:25 PM   #6
hugheym's Avatar
1961 16' Bambi
1969 27' Overlander
Bonner Springs , Kansas
How about using a nut with a nylon locking feature.
Could that eliminate a recurring problem and ease your mind.
hugheym is offline   Reply With Quote
Old 09-06-2015, 09:31 PM   #7
Nylon nuts are certainly very useful.
But, when vibration is the cause of the issue, then attention should be directed to it's "fix".
If not, then many other things can and will happen, that sometimes cause "big bucks" to correct.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-06-2015, 10:06 PM   #8
Ron_CA's Avatar
That's not a bad idea or I could just double nut them since they will probably jiggle loose again.
Old 09-06-2015, 11:30 PM   #9
2007 22' International CCD
Double nuts will lock, but will not he as strong as a Nylock nut in stainless steel...and double nuts are a pain when they rust and then need to be taken off in the future. It takes two wrenches to get them off, plus a set of locking pliers to hold the all thread. Don't ask how I know this 😀
Old 09-07-2015, 12:29 AM   #10
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
You could also use something like Loctite thread locking fluid. The blue is temp/removable. The red is more permanent. I use it all the time. Also noticed that all those nuts holding tanks and other things under my van are nylon-nuts.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 09-07-2015, 12:51 AM   #11
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Uh - Andy, it's an INTERSTATE... not a trailer.
Old 09-07-2015, 06:06 AM   #12
1978 28' Ambassador
Columbia , Connecticut
Clear tank
Hi all ,just watered up our 28 ' 1978 ambassador for first run to cape cod. I was cleaning clear tank (just because) knowing we are using water hook up . So question is how involve is to change tank next spring? Thanks to all
Ducky2 is offline   Reply With Quote
Old 09-07-2015, 11:09 AM   #13
Those need balancing as well.
Some folks think that heavy duty vehicles are immune to balancing.
Andy Rogozinski
Inland RV Center
Corona, CA
Fresh Water Tank Leak At Bottom of Tank From 1/8" Hole KJRitchie Fresh Water Systems 26 06-21-2022 11:12 AM
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 31 05-15-2022 10:25 PM
Covert fresh water tank to a gray tank cole3444 Waste Systems, Tanks & Totes 3 03-25-2014 06:31 PM
Help!!! Fresh water tank/ black tank meredith Fresh Water Systems 6 09-01-2011 11:51 PM
Using a fresh water tank as a grey tank? Mike&Ali Waste Systems, Tanks & Totes 14 09-16-2010 10:50 AM
