Old 07-16-2016, 11:38 PM   #29
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Try plumber's putty.
Old 07-17-2016, 12:49 AM   #30
2015 Interstate Ext. Coach
Lake Mary , Florida
How about this?
Mr. B is offline   Reply With Quote
Old 07-17-2016, 01:48 AM   #31
Lake Mary , Florida
Yes, small drop is hanging...
Removed, for a tomorrow fix.
I beleive a silicone would work as well, what do you think?
Old 07-17-2016, 05:22 AM   #32
Silicone adhesive would probably work as well but I would be hesitant about using it since if you use too much it could work its way back into the valve at a later date and cause sealing problems.
Pipe dope or other plumbing pastes won't ever solidify and will not cause the same problems if it entered the valve.
LB_3 is offline   Reply With Quote
Old 07-17-2016, 02:27 PM   #33
73shark's Avatar
Remove the thread tape before applying something else.
drain valve on fresh water tank: '79 Argosy 6.0 campman All Argosy Trailers 7 01-26-2009 07:59 PM
Is there a drain for my Fresh water Tank!! Mrcrowley Fresh Water Systems 1 12-02-2008 05:44 AM
Fresh Water Tank Drain NEW94 Fresh Water Systems 5 11-04-2007 09:58 PM
Fresh water tank drain valve location? trilink3 Fresh Water Systems 8 11-04-2007 09:23 PM
Really need a drain on the fresh water holding tank?? SmokelessJoe Fresh Water Systems 16 06-17-2007 08:50 AM
