Old 07-15-2016, 06:05 PM   #15
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by Mr. B View Post
This valve is designed for 3/8 or 1/2 thread. Ours is the bigger one, a half-inch, so you just cut the unnessessary 3/8 portion, and it will fit even with the bottom of tank.
You may also have to cut off a few of the 1/2 threads to get it flush with the tank bottom when screwed all the way in. Don't go by the original plug, which can stick up without affecting anything, go by the number of threads on the tank itself.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 07-15-2016, 06:05 PM   #16
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
How about this one, Marc, it looks like it will be only half of an inch lower then the original plug
Looks like it would work. Let us know how it turns out.
I'm sticking w/ the plug (KISS philosophy).
Old 07-15-2016, 06:20 PM   #17
2014 Interstate Ext. Coach
fairfax station , va
Might be too small
I have that valve and IIRC both sets of threads are too small for the fresh water plug.
VAtom is offline   Reply With Quote
Old 07-15-2016, 07:54 PM   #18
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
Originally Posted by cazual6 View Post
What was your reason for draining it? I refill my fresh water whenever I get back from a trip and keep it full for my next trip. I don't use my fresh water tank to drink. I heard people drain it for winter, but I don't have to worry about snow in LA.
Oh if only I again lived in that perfect climate of California. 😎
I have to drain it during the freezing winters here in Maryland and again when I return form our typical Florida trip in February to unthaw. If it sits full like now at 90-100 degF it tends to grow things so I shock it with bleach, drain and refill before the next trip.
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 07-15-2016, 08:00 PM   #19
2015 Interstate Ext. Coach
Lake Mary , Florida
It was smart!
Mr. B is offline   Reply With Quote
Old 07-15-2016, 08:03 PM   #20
Lake Mary , Florida
Originally Posted by Boxster1971 View Post
Oh if only I again lived in that perfect climate of California. ��
- - Mike
Chlorine smell is difficult to eliminate, and once you shock tank with bleach, it should stinks then?
Old 07-15-2016, 08:15 PM   #21
Fulton , Maryland
I prefer a little chlorine odor to the green slim I've drained from the tank in the past when I let it sit for a few months at end of a summer trip.
- - Mike
- - Mike
Old 07-15-2016, 08:27 PM   #22
Lake Mary , Florida
- - Mike
Make sense indeed )
Old 07-15-2016, 08:29 PM   #23
Teamaron's Avatar
Boca Raton , Florida
I always add a little bleach Each time I fill.
As far as wrench use, NO WAY. I use some plumbers tape also and just tighten and undo by hand. It's very easy to strip drain plug or tank threading.
Teamaron is offline   Reply With Quote
Old 07-15-2016, 08:40 PM   #24
According to both the EPA and the World Health Organization, a chlorine residual between 1% and 4% is drinkableó and chlorine is recommended for emergency treatment of water suppliesó but some people can taste concentrations as low as 2%. A 1% concentration is virtually undetectable by human taste buds. But as long as there is any chlorine residual in the water, no microorganisms can grow in it.
Note that even 4% chlorine is way less than the concentration used to sanitize your tank.
Also, with a vented tank, the concentration of chlorine in a tank of fresh water should drop by about 1% per day because chlorine gradually evaporates out of the water. If you add 4% chlorine when you fill the tank, then by day 5 all of the chlorine should be gone.
WBCCI #1105
TAC LA-4
Old 07-15-2016, 09:16 PM   #25
Lake Mary , Florida
You appeared to be the most correct in regards of the plug size.
Our fresh water drain plug is 3/4 inch, so the above pictured plastic crap wound not fit.
I bought today the brass one of the correct size at a local Home Depot (pictured), however it sticks down for two inches.
No good also.
Thus, if nobody have any other advise, I will follow recommendations of the majority - will use the stock plug.
Old 07-16-2016, 06:35 AM   #26
socket, no wrench
You are right, but if you use the 1" giganto deep socket it makes a great "hand tightener" without an actual ratchet.
Old 07-16-2016, 06:19 PM   #27
Lake Mary , Florida
The update.
I found the solution by cutting with Dremel a half of the new brass socket, right to the place of switching ball. So, now the total length down from the factory water tank cap collar is 1 inch, which is not dangerous to scratch it, though I do not drive on havy terrains.
Old 07-16-2016, 06:34 PM   #28
Lake Mary , Florida
But I still have a concern.
The original screwed tank cap had traces of green mold and algae, that means the water always had some leak through the cap thread although I had found it on a Teflon tape.
I put a lot of new Teflon tape on the brass thread, and I made several attempts to screw in the new facet to avoid water drops. My concern is that there were always a hanging drop of water from between the threads. Finally I put almost half of a roll of Teflon tape to avoid water drops, however I don't want to brake the tank because the mother thread made of plastic. Will see and keep you updated.
Should the water drop anyway will appear there, is any other method exist to patch between the threads? I would like to put it permanently but with ability to unscrew it if needed, so JB-weld epoxy would not be a solution.
drain valve on fresh water tank: '79 Argosy 6.0 campman All Argosy Trailers 7 01-26-2009 06:59 PM
Is there a drain for my Fresh water Tank!! Mrcrowley Fresh Water Systems 1 12-02-2008 04:44 AM
Fresh Water Tank Drain NEW94 Fresh Water Systems 5 11-04-2007 08:58 PM
Fresh water tank drain valve location? trilink3 Fresh Water Systems 8 11-04-2007 08:23 PM
Really need a drain on the fresh water holding tank?? SmokelessJoe Fresh Water Systems 16 06-17-2007 07:50 AM
