Old 09-22-2016, 08:55 PM   #15
Genoa , Nevada
Thanks to all of you for your insight and suggestions. This is our first motorhome as such, I'm going through a steep learning curve. In retrospect, avionstream's question is fair and I expect with good intention.
As a postscript, I had my final conversation with the manufacturer's technical department head in Manitoba Canada. After a brief discussion to satisfy his curiosity regarding our two candidates, we agreed on the solution. Specifically, I will install a quarter-turn shut off valve at the overflow tube.
The only potential problem with this is, I have a senior moment and forget to open the valve once I arrive at a destination. There is, according to the manufacturer, "no chance of a pressure build up while driving..."
Tomorrow morning I will install the device, after I go to the vitamin store and buy all their Omega-3 supplements to boost memory. If you don't mind I will report back next week as we are taking a short trip over to the Lake. This entails going up and down many hills, which will be the acid test.
Thanks again...
Dave
Tahoe Dave is offline   Reply With Quote
Old 09-22-2016, 10:08 PM   #16
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
Woe to the person who leaves their keys in the hanging door hatch, because those all-important electronic fobs will get soaked.
Mine was exposed, just a screw on/off cap w/ a retention chain. No keys req'd.
Old 09-30-2016, 09:49 AM   #17
Genoa , Nevada
As promised, I would report the results from temporarily closing off the drain tube while in transit, I filled the fresh water to 100% at home, drove to Camp Richardson which was a 3K foot climb. Arrived with 100% and no unintended consequences.
Problem solved!
Old 10-04-2016, 09:11 PM   #18
Lakes Region , New Hampshire
Excellent! Just remember, if you have problems with the water pump, open the valve before you come and ask on here why it won't pull water...
Actually, now that I think of it, there must be something that can be put inline that allows bidirectional flow with just a minimum pressure trigger, say 5psi, so that it would allow the over flow to work and wouldn't completely allow the pump to suck the sides of the fresh tank in. Time to Google.. good luck, with yours
RandyNH is offline   Reply With Quote
City Water Hooked Up Making Fresh Water Tank Leak/Overflow??? Wgbarrbevco Fresh Water Systems 18 11-24-2017 04:45 AM
Sprinter Fresh Water Siphon Leak Tahoe Dave General Repair Forum 0 09-20-2016 09:32 PM
Water dripping from fresh water overflow? craftsman Fresh Water Systems 10 10-09-2010 11:58 AM
Siphon fresh water tank? Chip Arnold Fresh Water Systems 13 05-06-2009 10:09 PM
Filling fresh water tank- overflow normal? John Fresh Water Systems 20 02-23-2003 01:43 PM
