Old 03-24-2016, 10:30 AM   #1
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Formica Delamination
I noticed early indications of this issue shortly after delivery of my van. I should have mentioned it then but didn't.
Now, all six of the curved doors for the upper lockers are showing this problem. The top and bottom edges of the Formica are coming loose from the plywood. Some doors are worse than others.
Has anyone else see this? If yes, what did you come up with for a solution?
TIA,
Wayne S.
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
wayneskid is offline   Reply With Quote
Old 03-24-2016, 02:16 PM   #2
Ron_CA's Avatar
2015 Interstate Ext. Coach
San Diego , California
Laminates are generally applied with contact cement. Unless you can easily and without damage pull the whole piece of laminate off, contact cement won't work very well to reattach.
If I were going to attach loose pieces I would use power grab by loctite. It comes in a can with an open and close lever and has amazing instant sticking power. It is white but dries clear.
If you can lift up the edges of your laminate and squirt some in the gaps it will do the trick. I forget what you need to clean up but I think denatured alcohol or maybe lacquer thinner.
Ron_CA is offline   Reply With Quote
Old 03-24-2016, 02:31 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Plain old Gorilla glue works pretty well too. Since it doesn't cure instantly I've used masking tape to hold a corner piece in place until the glue dries.
Paula
Old 03-24-2016, 02:59 PM   #4
UKDUDE's Avatar
2014 Interstate Ext. Coach
Sedona , Arizona
I've had small areas of laminate come adrift such as on curved edges. And I've put it down to the excessive heat buildup here in Arizona loosening the glue. I've successfully glued all of them back with superglue.
Old 04-02-2016, 06:58 AM   #5
wayneskid's Avatar
2010 22' Interstate
Anchorage , Alaska
Update:
All loose laminate is now fixed. I used Loctite Ultra Gel Control superglue. The nozzle tip is small enough to get into the gap where the laminate is loose. To insure best bond I clamped with a caul for a full 5 minutes. Now we'll see how it holds up over time.
- wayne
AIR #44779
TAC AK-1 !!
LY fiberglass side delamination Santart Land Yacht/Legacy Motorhomes 27 11-26-2012 04:15 PM
Exterior delamination repairs gloran Land Yacht/Legacy Motorhomes 6 02-15-2009 05:51 AM
Delamination repair flashgrbiv Upholstery, Blinds, Walls & Interior Finishes 1 12-27-2008 05:46 PM
delamination fixes ? myfirstrv General Motorhome Topics 6 12-22-2006 07:53 PM
Ceiling Delamination gunworks Land Yacht/Legacy Motorhomes 4 10-19-2006 11:55 PM
