02-14-2018, 10:55 AM
2015 Interstate Ext. Coach
Columbus
, Ohio
Fixed vs Portable solar panels
I've read the many posts about adding solar panels to the roof of our AI's and upgrading the controller to a MPPT to solve boondocking battery issues.
Have any of you considered the option of doing portable solar panels instead of fixing additional panels to your roof?
Mark
Adventure before Dementia!
02-14-2018, 10:59 AM
Contributing Member
Austin (Hays County)
I would worry about the security of portable panels.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Oswego
I have both. 100w on roof and 160w portable...since I camp mostly under tree cover, I need to have the capability to chase the sun spots.
-Rich-
02-14-2018, 11:55 AM
League City
One of the nice things about class Bs is the ability to move on quickly which can be adversely impacted by having to set up portable solar panels (not to mention how much of our precious stowage space they consume). But the ability to tilt a portable solar panel can significantly increase it’s effectiveness in winter or early/late in the day and could low for a small portable panel to out perform significantly larger roof top panels.
02-14-2018, 12:48 PM
Prof. of Pending Projects
2018 Tommy Bahama Interstate
Orlando
Storing these would be an issue... I can see the need, when boon-docking, to be able to seek the sun...
For those with roof racks, this would be easier... you can make it so that they are mounted on the roof for when under direct sunlight, and remove/relocated with an extension cord when parking under the shade... that way there are no storage concerns...
Just thinking out loud
02-14-2018, 01:09 PM
Cincinnati
, Ohio
I have the Zamp 120w portable and like them a lot. Plug and play, very easy and handy since the newer Airstreams come prewired at the tongue for them and this saves having to drill potential leak holes in the roof to mount permanent panels.I only bring them when I know I'll need them for boondocking, which is infrequent for me. They fold into their own built in suitcase-type container for easy transport. Portable setup is less expensive, too.
02-14-2018, 01:33 PM
2017 Interstate Grand Tour Ext
Dayton
, Montana
Portable solar panel plug in point 2017 AI
Where does the portable solar panel plug into? I am very interested information from anyone with a 2017 AI with only the one 100w solar panel on the roof.
A portable flexible (roll up panel) would be a great addition for me. I find myself starting the generator in the morning just to bring the batteries back up from 50%. The ability to place and tilt the panel would be great.
02-14-2018, 02:01 PM
Cincinnati
, Ohio
Pez Vela, sorry I was talking about a trailer not and Interstate coach.
02-14-2018, 02:24 PM
2017 Interstate Lounge Ext
Northern
And that's the fly in the Chardonnay with respect to adding a "solar suitcase" to the Interstate. First you would need to rig up some sort of connector/adapter to the existing panel(s) on the roof. This wouldn't be too difficult (could be done with a MC4 Y cable and a length of cable that you could run from the roof to the suitcase), but then you're still stuck with the craptastic Atkinson solar charge controller that comes standard on our rigs.
I've said it before, and I'll keep saying it: The single biggest positive change you can make to the Interstate with respect to the charging sources is to replace the OEM-provided Atkinson solar charge controller with something better. I did this to mine for $175 all-in, and it made a HUGE difference.
02-14-2018, 04:01 PM
J&J In A Can
Cottonwood
Mark
I added 200 Watts of portable without disturbing the existing solar. I ran 10AWG wires from the terminals on one of the AGM batteries to a connector beside the rear hitch. I plug the output from the new controller into that connector. The controller goes to two flexible 100W solar panels in parallel. I use a ladder to put the panels on the roof behind the AC while parked. They are stuck down with suction cups so they don't blow away. They can also be placed on the ground if desired. Just remember to take it down before driving away.
It's not highly optimized but it buys a good amount of time while boon-docking. It's simple and can be upgraded easily.
2016 Interstate GT Twin
02-14-2018, 05:00 PM
League City
Note to longer-term subforum participants... Mister B and Mr. B are two different users, two different Interstate owners. I had me a proper head-scratchin' moment there, before I figured this out.
02-14-2018, 05:58 PM
Columbus
, Ohio
I appreciate all of your replies and suggestions.
I was planning on doing something similar to what lovetowander posted.
The Zamp panels I am considering have their own controller so I will bypass the Atkinson and the fixed roof system and wire a plug n play harness directly to the airstreams batteries. I then can plug the wires that come from the Zamp panels into that harness.
I plan to set them up on the ground and move them to track the path of the sun.
As for storage, the panels when folded will fit behind the 2nd row drivers side captains chair.
We currently rotate that seat 90 degrees to the right and pull it as far forward as possible to store camping chairs. We'll need to relocate those chairs somewhere else. We've even toyed with the idea of taking one or both of the second row seats out. That will be a project for later.
We're currently snowbirding it and enjoying the warmth and sun of the desert southwest.
Since we're doing a lot of boondocking out here on BLM land, we're going to upgrade our solar capabilities next week.
02-14-2018, 07:03 PM
League City
If they really have their own controller there is no need to wire them into the battery. Just get a cigarette lighter adapter and plug it into the exterior 12v outlet.
02-14-2018, 07:16 PM
2024 Interstate 19
Fulton
, Maryland
This sounds like a great solution. Could you please post some photos of your setup?
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
02-14-2018, 07:55 PM
2015 Interstate Grand Tour
Lake Oswego
, Oregon
Wait... wha ? I had to go re-read my owners manual... it says that the exterior 12v port is an outlet, which I assume is only for delivering 12v to a device other than the coach, but you're saying you can push power INTO the coach through this 12v outlet ? If so, it's probably limited to 10A, right? But what about a panel that's putting out 20v... do you need to do anything about plug it in? or does the extra voltage just spill off into the ether if you don't utilize a MPPT controller?
Pardon me if I just exposed my ignorance.
02-14-2018, 09:33 PM
Northern
A solar controller will limit the voltage to what's appropriate for the batteries selected, so while the panels can put out up to 20v "open circuit", the controller will limit that to what the batteries can handle.
Having said that, I would have 2 cautions re. using that outlet as an input. First, as you guessed, it's likely limited to 10A. 200W worth of panels could push 12A or more into it depending on the controller type. Second, are we sure that outlet isn't tied into the MB chassis CAN-Bus system? If it is, I would avoid using it as a power input and do as LoveToWander has done to avoid any problems. CAN-Bus can be finicky as hell if it sees current where, and in a direction, that it's not expecting to see it. DAMHIK.....
02-15-2018, 06:01 AM
Sneedville
, Tennessee
We used portables in our trailer. Only had one time where someone tried to steal them. We were lucky as we scared them off when we returned to the trailer from a restuarant. This was at Theodore Roosevelt Lake in Arizona. They also had our bicycles ready to go as well. The thieves did make off with a Honda generator that was cabled and locked, they simply cut the cable.
Having the ability to set the panels out in the sun and move them to follow the sun allowed us to maximize charging. Most times, we were fully charged by 11 am. I question the suitcase versions with the controller on the solar panel. The voltage drop is too great to get a good charge. I removed mine and added a controller and monitor in the trailer.
02-15-2018, 06:10 AM
KW
, Ontario
There is no way that the Can-Bus would be affected. The Can-bus is a communication protocol which is used between the modules (i.e. temperature control, steering wheel communications, dash display and the front and rear SAM's along with the ECU and other modules). Yes it can detect loads on light circuits, but the power circuit of a an auxiliary power system would not be directly (if all) connected to the system. This system should be stand alone. If it is connected it is only to charge the auxiliary batteries through MB's system.
Another source of portable panels is to use flex panels. They don't break and are easy to store. You just need to rig a stand.
02-15-2018, 06:16 AM
KW
, Ontario
02-15-2018, 09:08 AM
Northern
FWIW, I've personally seen CAN-Bus shut down circuits because it detected a current higher than what that circuit was programmed for. If that external plug is connected in any way to that bus, there could be issues.
Folks can do what they wish, but I won't be pushing current into that plug on my coach.....
