Old 06-19-2015, 08:59 PM   #1
2015 Interstate Ext. Coach
New Orleans , Louisiana
Finding Acceptable Diesel?
Hi,
We're in Rantoul, Il, heading to Chicago for a few days. After stopping at multiple stations all sporting the same "between 5 and 20% biofuel" stickers on the pump I gave up and did a partial fill. (I saw some mention on the web that the norm here is 11%, but who knows?) I found a map showing lots of B5 or lower stations around Chicago, but I'm not sure we have the range. Spending a day stopping at every station with diesel and looking for stickers doesn't sound fun. How do you folks handle this? And extra points for a station twiixt here and Joliet that meets Mercedes perhaps unreasonable standard (he says surrounded by corn)....
thanks/r
NOLA_russ is offline   Reply With Quote
Old 06-19-2015, 09:59 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
In the part of the country I've traveled so far (all of the Gulf Coast states, plus Georgia, Oklahoma, and Arkansas) it hasn't been a problem finding B5 or less. The only stations I've encountered that have carried B20 are Love's Country Stores. So I never really considered "B5 or less" to be an unreasonable standard.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-19-2015, 11:34 PM   #3
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I use a diesel fuel additive such as Power Service Silver at every fill to ensure consistent fuel performance. I don't worry at all about B20 or down, just fuel freshness as the concern. HOWES my second choice off the shelf. I ignore the others. At 80k miles/yr I've tried them all in the late model Peterbilt. Have a way to measure amount, or over treat to a point.
National chain truck stops are the thing, and I prefer Flying J. I drive for work, and the J is almost always best in terms of services and amenities. I also frequent AMBEST independents.
LOVES as third choice.
Carry some extra fuel filters (Baldwin or Donaldson), buy the tools and know how to change it.
POWER SERVICE Fuel Fresh every once in a while. Can be combined with whatever is still in tank.
SCHAEFFERs Diesel Treat the best fuel additive out there (including Stanadyne) , but not usually seen on road. Order in bulk to carry along. Regular jet fuel results, so to speak.
Biodiesel is not the worry some make it out to be, IMO. Clean treated fuel has meant consistent results for whether at work or in my DODGE.
Old 06-20-2015, 05:27 AM   #4
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Recently I installed a factory oem secondary fuel filter on the pickup. The new filter is 20 micron with water stripping capabilities and a water in fuel sensor. The existing factory filter is 5 micron with water stripping and water in fuel sensor. According to the documentation this set up will handle B20. There are many aftermarket or possibly a oem set up like I did to protect the fuel system.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 06-20-2015, 05:38 AM   #5
Gainesville , Florida
Toured an Interstate across the country and now a dodge cummins and on only one occasion found too high biodiesel. That was at a Walmart in Georgia. Put a few gallons in and went on my way. If you fill when you are at a quarter tank or more just putting a few gallons in is okay. It dilutes down to a safer level. Just fill up at your next chance.
Old 06-20-2015, 05:48 AM   #6
Lily&Me's Avatar
Normal , Illinois
I have to admit.......I put in whatever diesel I find, and didn't know to be discretionary.
Corn and soybeans here, NOLA russ.
Maggie
Lily&Me is online now   Reply With Quote
Old 06-20-2015, 06:24 AM   #7
2015 27' FB International
Newmarket , Ontario
The concern over biodiesel is that >5% may contaminate / manufacture engine oil. Apparently regular diesel also gets into the oil but is boiled off while operating. The Biodiesel fuel has a higher evaporation point and is harder to remove than regular diesel. A small amount of >5% probably is not an issue but a steady diet might cause problems.
Mike
Newmarketca is offline   Reply With Quote
Old 06-20-2015, 06:34 AM   #8
Lily&Me's Avatar
Normal , Illinois
Hmmmm.....I will start paying attention.
Thanks for the info.
Maggie
Old 06-20-2015, 07:36 AM   #9
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
My 2013 Ram manual says 5% bio or less. The 2014 manual says if you use between 5 and 20 you have to shorten the oil service interval which also changes the fuel filter. My manual doesnt mention that option. I have also read on turbodiesel register (forum) that you can add or change to a different filter setup but i dont think i can do that and maintain my warranty.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 06-20-2015, 07:47 AM   #10
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
1972 Magnuson Act covers that. And an additional filter shouldn't be a problem. But I'd imagine that the Severe Duty filter Dodge now has should cover it.
Biodiesel degrades more rapidly. Thus more problems with water. More algae.
One can also read on marine forums to see what the guys in hot/humid FL do with big tanks and long times between engines being run.
I used Startron from West Marine back when I became the second owner of this pickup as a result of those forums
Old 06-20-2015, 08:40 AM   #11
Boxster1971's Avatar
2013 Interstate Coach
Fulton , Maryland
The info found on the Mercedes web site may help.
http://mercedes-benz.custhelp.com/ap...in-illinois%3F
This is the latest publication from Mercedes on biodiesel.
http://www.mbusa.com/vcm/MB/DigitalA..._Brochure5.pdf
- - Mike
2013 Lounge EXT on 2012 Sprinter
- - Mike
Old 06-20-2015, 09:15 AM   #12
k9jackie's Avatar
Great Falls , Virginia
I had no idea... Thanks for the info. I will be passing through Illinois this summer.
Airstream Interstate Facebook group
https://m.facebook.com/groups/1399633380341777
2014.5 Airstream Interstate Ext.
k9jackie is offline   Reply With Quote
Old 06-20-2015, 09:17 AM   #13
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
I am a Bio diesel maker. The biggest problem for the fuel system is the Methanol that is used with NaOH to create the methyl esters (Bio Diesel). Unless the methyl alcohol is sufficiently removed after fractionation, It will cause problems with every rubber component in the system.
The percentage of alcohol contained in the finished product is the result of titrating the oil for calculated quantities of Methoxide (MeOH + NaOH) to add to the batch.
Alcohol remaining in a 5% by volume BioDiesel would be negligible, especially with the relatively clean feedstock. Fryer grease is another animal all together. You can run it with little worry of accelerated wear. I do not know what their industry standard is. I know what works for me. Biodeisel can also be manufactured using Sulfuric acid.
The father of the Diesel engine, Rudolph Diesel, designed his engine to run on Peanut oil, not Petroleum Oil or a variation thereof
NavyCorpsman is offline   Reply With Quote
Old 06-20-2015, 03:39 PM   #14
2011 Interstate Coach
Muskogee , Oklahoma
I won't use biogreaso after it caused me a two day stay to replace various components at a dealer caused by using it in the first place. I don't care what anyone says, I just won't use it, again, unless I absolutely have no other choice. So far, that has not been the case, including a 6000 mile trip from one side of the country to the other.
MurphyUSA branded stations around the midwest are common near Wal-Marts and carry pure diesel. On the road, I start looking when I am about 1/4 full until I find a station that carrys pure diesel.
2011 Interstate WD/Lounge
gmillerok1 is offline   Reply With Quote
Acceptable voltage drop on 12V? ESCAPE POD Batteries, Univolts, Converters & Inverters 16 02-24-2011 09:41 AM
Acceptable propane leakdown rate? Jabba LP Gas, Piping, Tanks & Regulators 7 04-18-2003 06:49 PM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
