Old 03-28-2016, 10:40 AM   #505
2015 Interstate Ext. Coach
Lake Mary , Florida
Which one the oil from Walmart I can use?
Mr. B is offline   Reply With Quote
Old 03-28-2016, 10:43 PM   #506
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
I believe you have to use the Mobil 1 ESP. Check your manual for the correct weight.
Old 03-29-2016, 05:42 AM   #507
Presumably that owner's manual is going to give you a range of options that include both conventional and synthetic oil (?). As with a passenger car, the synthetic is generally more expensive. We used Mobil 1 5W-40 turbo-diesel truck motor oil, which is about $27 per gallon. My husband is of the opinion that if we are going to invest our time to do the job, we might as well use the best available materials.
Old 03-29-2016, 05:20 PM   #508
2012 Interstate Coach
Virginia Beach , Virginia
Fans of Airstream Interstate
If you want to stay with the longer service interval, 14 quarts Mobil 1 0w30 oil, which is replacing Mobil's 5w40 is an option. I obtained it from the MB dealer, I think it was about 9 dollars a quart. The Mobil 1 ESP is the correct oil.
Johnvabeach is offline   Reply With Quote
Old 03-29-2016, 09:44 PM   #509
Lake Mary , Florida
Preparing for oil change after couple thousand miles and searching to choose the right oil for all future DIY changes.
In Walmart today have found four different oils.
Which one is the best from them for our applications?
PS: I will make pictures in separate posts because I cannot insert images in one post.
Old 03-29-2016, 10:06 PM   #510
Lake Mary , Florida
One more picture
Old 03-29-2016, 10:07 PM   #511
Lake Mary , Florida
More picture
Old 03-29-2016, 10:08 PM   #512
Lake Mary , Florida
And one more to choose from
Old 03-29-2016, 10:26 PM   #513
Figment of My Imagination
Protagonist's Avatar
One more picture
This one, I think.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-29-2016, 10:26 PM   #514
More picture
These last two are the same oil, just different sizes.
WBCCI #1105
TAC LA-4
Old 03-29-2016, 10:54 PM   #515
Lake Mary , Florida
However, on the last two it is stated there for Mercedes 229.3 and 229.5 - these numbers are in our manual.
So why you think that another, because it is written for Diesel engines?
Old 03-30-2016, 08:14 AM   #516
The one Protag tagged is the one we use, which is a synthetic. I don't always understand the marketing hype and it's not always immediately apparent to me which oils are synthetic or conventional (it's in the fine print somewhere). It's also not apparent to me whether synthetics are genuinely superior - but it is true that in most cases I've seen, it can be a longer time between oil changes without imperiling the warranty if synthetic oil is used (I use it in my daily driver for that reason - 10,000 miles vs. 3,000 to 5,000 miles between oil changes).
Generally, I don't over-think this issue; husband said to use that formulation of turbo diesel Mobil 1 in the Interstate, so that's what we use.
Old 03-30-2016, 09:07 AM   #517
Here are your approved motor oils:
https://bevo.mercedes-benz.com/bevol...228.51_en.html
LB_3 is offline   Reply With Quote
Old 03-30-2016, 10:06 AM   #518
Mjgman's Avatar
2013 Interstate Coach
Bradenton , Florida
When synthetic first came out my auto shop teacher put some in a Honda drove it around for a bit then drained the oil and left the oil plug out..
He then drove the car down to San Diego and back, over 200 miles round trip.. There was not a single thing wrong with that engine.. Not sure if anyone has tried that with regular oil..
Mjgman is offline   Reply With Quote
NEW: 5th Wheel Airstream Airtrekker Boondocking 38 06-25-2016 09:52 PM
2005 Airstream Interstate 22' eBay Watch Airstreams on eBay 0 03-06-2011 07:20 PM
2006 Airstream 22 INTERSTATE eBay Watch Airstreams on eBay 0 02-04-2011 02:30 PM
2010 Airstream Interstate Mercedes Benz Motorhome eBay Watch Airstreams on eBay 0 01-29-2011 03:00 PM
2009 Airstream Interstate 3500 Mercedes Benz Diesel eBay Watch Airstreams on eBay 0 01-08-2011 01:20 PM
