Old 09-08-2015, 09:43 AM   #1
2014 Interstate Ext. Coach
Sequim , Washington
F65 Eagle Awning Issue
I have the F65 Eagle. It worked for the demonstration a year ago, but now will not extend. I tried to extend it once last year, but figured I had a head-space problem when nothing happened. There is power at the fuse, but no power at the switch under the passenger seat. I've emailed and called Airstream. Nothing yet.
mcaleer is offline   Reply With Quote
Old 09-08-2015, 01:14 PM   #2
73shark's Avatar
2011 Interstate Coach
Overland Park , Kansas
You said there's power at the fuse. Is the fuse good?
Old 09-08-2015, 02:11 PM   #3
Sequim , Washington
The fuse checks out OK
Old 09-08-2015, 02:29 PM   #4
73shark's Avatar
Has there been any work done between the fuse and the switch that might've affected the wiring or the connectors?
Old 09-09-2015, 11:27 AM   #5
Sequim , Washington
No work that could affect the awning wiring.
Are their known problems with the auto-retract switch. Are there adjustments on it that I can make?
Old 09-09-2015, 11:50 AM   #6
UKDUDE's Avatar
Sedona , Arizona
This thread was about adjusting the auto-retract mechanism:
http://www.airforums.com/forums/f240...xt-123587.html
Old 10-06-2015, 03:41 PM   #7
2015 Interstate Ext. Coach
Chicago , Illinois
Did you ever resolve your problem? I"m having the same one on a 2015 AI. The awning won't extend. I didn't have a spare fuse, so I switched with another 15a into F10, and nothing happened. I'll replace the fuse when my new ones arrive, but I"m thinking it's not a fuse.
Marks71 is offline   Reply With Quote
Old 10-07-2015, 07:45 AM   #8
Sequim , Washington
F65 Awning
I still can't extend the awning. Power is getting to the fuse and the fuse is OK. No power getting to the switch under the passenger seat. I suspect the auto-retract switch. It's going in to Airstream soon.
Old 10-07-2015, 08:31 AM   #9
Chicago , Illinois
ok thanks. How do you check whether power is getting to fuse and switch?
Good luck getting it fixed, and keep me posted. I"ll do the same.
Fiamma Eagle 65 Issue migriffin Sprinter and B-van Forum 9 06-08-2014 07:57 PM
War Eagle! nilesrob Off Topic Forum 4 01-05-2011 02:13 PM
Winter Trip recomendation: Eagle viewing Boondocker On The Road... 36 12-06-2007 04:07 PM
double/eagle double/eagle Member Introductions 1 09-15-2006 12:54 PM
Eagle Lake, California ?? myoung On The Road... 7 07-18-2006 12:01 PM
