Old 08-13-2016, 02:18 PM   #1
2016 Interstate Lounge Ext
Atlanta , Georgia
External Propane Line
We are new owners of a 2016 AI with an external propane line about 3 feet long. We wanted to hook up a Coleman lantern outside so bought a 10 foot line. Propane flows well in the shorter line but not through the ten foot line. Has anyone had success using a propane Coleman lantern off of an extension line? Thanks
Vanny is offline   Reply With Quote
Old 08-13-2016, 03:25 PM   #2
Houston , Texas
I have a 10ft line for my grill and it works just fine.
Mcrid is offline   Reply With Quote
Old 08-13-2016, 03:59 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Maybe Different pressure requirements???
MICHAEL
Old 08-13-2016, 06:14 PM   #4
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
Sometimes a longer line can cause the excess flow valve to trip....takes 3+ times the gas to fill the 10' line and if the valve is opened too quickly it will cause the EFV to trip. Resets itself in a bit of time.
FMCA # 436814
toskeysam is offline   Reply With Quote
Old 08-13-2016, 08:47 PM   #5
Boxster1971's Avatar
2024 Interstate 19
Fulton , Maryland
I have a 10 ft line on a portable NG heater on my deck. It takes a long time for the gas to reach the burner so I can light it. I recommend you hook up your Coleman lantern with the long hose and leave it sit for at least 30 minutes before trying to light it.
- - Mike
2013 Interstate Lounge EXT on 2012 Sprinter
- - Mike
2024 Airstream Interstate 19e AWD
Previous: 2013 Airstream Interstate 3500 Ext Lounge
Old 08-14-2016, 05:03 AM   #6
Sag Harbor , New York
We have a 10' quick-connect extension hose which has an integral on/off valve for our generator. The first time we used it, it took ages to get the gen started (for the propane to fill the line). So we got an extra male and put this in the female end fitting (so as to open up the line to gas flowing), and then opened all the master on/off valves until propane flowed freely out of the end near the genny.
Low pressure propane lines, it turns out, are very low pressure, such that you can put your thumb over the open end, and stop the flow of gas by manual pressure alone (IMO).
When the gas smell was strong, we turned off the valve, removed the extra male fitting, and connected the line to the generator. After priming the carb, it usually starts after 3-4 pulls. And this is true even if we use 2 10' hoses to hide the gen behind the trailer, so it is at the quietest spot in the campsite.
Good luck!
Peter
PS -- FYI extension hose with shut-off:
https://www.amazon.com/Camco-57282-P.../dp/B00CPYC9BC
Extra male: https://www.amazon.com/Camco-59903-P...Q9ANNEHF73QPCG
Old 08-16-2016, 08:12 PM   #7
2015 Interstate Grand Tour
Anywhere USA , USA
Propane flow rates of lantern
A quick search online shows the Btu/h of a lantern to be about 3500. I have a 12ft. hose on a 15,000 But/h single burner stove with a quick connect that I use to cook outside for various reasons. It takes roughly 10s for me to purge the line and light the burner. The quick connect on the outside supplies propane at a pressure of around 11" wc (less than 0.5 psi), in other words- low pressure. You either need to wait longer to light the lantern or the lantern requires high pressure. Check the pressure requirements for the lantern.
JayP is offline   Reply With Quote
External Propane Tank? FlaBucki Sprinter and B-van Forum 8 06-18-2015 07:40 PM
External Propane Hook up w/ Camp Stove weirdstuff Sprinter and B-van Forum 67 04-20-2014 06:56 PM
Int'l Bambi 19' External Propane Connection? jambie 2005 and newer - Bambi all models 1 03-06-2011 07:28 PM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 03:54 AM
Propane and Electrical Line Protection Tamara Electrical - Systems, Generators, Batteries & Solar 7 06-27-2002 09:42 PM
