Old 05-31-2014, 06:39 PM   #1
toskeysam's Avatar
2013 Interstate Coach
Townsend , Tennessee
Exterior Shower
It figures that the ONE thing we did not checkout during the walkthrough was the exterior shower.
Spent the day here...on the road.... flushing and sanitizing the system(s). When I went to hook up the exterior shower hose and nozzle...it would not go into the quick disconnect. The wire bails are retracting when I push the sleeve, but the hose fitting will not go in. I suspect it may be something as simple as a stuck spool in the assembly, but thought I would float a message here before I turned the ape-man loose on it.
Thoughts anyone??? The nearest dealer is miles away.....
FMCA # 436814
toskeysam is online now   Reply With Quote
Old 05-31-2014, 07:04 PM   #2
Kwils25's Avatar
2014 Interstate Ext. Coach
Taylor Ridge , Illinois
It takes a little more force than you would expect to connect it. I think it is because the system is under pressure. Try turning off your water pump and opening a faucet to let off some of the pressure.
Kwils25 is offline   Reply With Quote
Old 05-31-2014, 07:28 PM   #3
toskeysam's Avatar
Tried it with system drained and open....no joy
FMCA # 436814
Old 05-31-2014, 07:58 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Exterior shower connections on Interstates change from one model year to the next, and apparently even within a model year. Pictures of your particular connection may help.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-31-2014, 08:07 PM   #5
toskeysam's Avatar
Will post a pic tomorrow. It does not match the manual...or the parts list. It has individual valves for hot and cold water, with a stainless steel QD fitting in the center position. Looks like standard sink setup, but fitted with the QD in the center post position.
Have also sent a note to Airstream Customer support. Those guys have. Been very helpful in other areas.
FMCA # 436814
Old 05-31-2014, 11:17 PM   #6
David M's Avatar
Orange County , California
Exterior Shower
On mine, I had to take a screw driver and punch the plunger in with the palm of my hand. I think my dealer detached the hose with the pump on and the valves open, and the pressure pushed the plunger outward. Now, I make sure I turn the outside valve off and relieve the pressure before detaching the hose, and no more problems 👍
David M is offline   Reply With Quote
Old 06-01-2014, 05:03 PM   #7
toskeysam's Avatar
OK... Took off the quick disconnect fitting. Soaked it in hot water. It released....... All is well.
FMCA # 436814
Stainless exterior shower box dkrug 2011 - 2015 International 10 07-29-2013 07:53 PM
Possible to add exterior shower? air2stream Full-Timing 12 06-23-2009 11:29 AM
Exterior shower finished! Resorts Sinks, Showers & Toilets 23 07-25-2007 03:29 PM
Exterior Shower!!! Resorts Plumbing - Systems & Fixtures 17 07-11-2007 09:37 AM
Exterior Shower Leak Gkiesel Sinks, Showers & Toilets 5 06-12-2007 01:26 PM
